Old 2nd February 2010, 16:48   #1
gd1418's Avatar
Thanked: 656 Times
Default Bull Bar, Rallye 3003 & Pintle Hook
This has its origin here - http://www.team-bhp.com/forum/street...an-2010-a.html (The Bull's day on 1st Jan, 2010)
The new Bull bar & the Hellas were fitted on 27th Jan, '10. A few weeks ago I had picked up a pintle hook from Mayapuri, Delhi. This was fitted yesterday. It practically took the whole day to do the needful.
The step was removed, bumper and the inner casing were removed and two metal plates of 12mm thickness was elctrically welded to the pipe at the rear and holes drilled. After the contraption cooled down, the bumper was refitted and two neat holes were created, thus eliminating the need to cut the bumper. And the pintle hook was bolted on.
Pictures will explain..
Bull Bar & the Hellas
Pintle Hook - rear view
Side view
Another side view
Open view
Close-up
Comments solicited....!
Old 2nd February 2010, 17:34   #2
SS-Traveller's Avatar
Thanked: 11,630 Times
Now that makes it a true Scorpio - a scorpion with a tail! Congrats, GD-saab. And when are the old Hellas coming in for treatment?
Old 2nd February 2010, 19:31   #3
rjstyles69's Avatar
Thanked: 795 Times
gd that bullbar some how looks real mean. Custom made or off the shelf ? How much did the hella 3003's cost you and also what about the bulbs in the 3003's, H1 -12V or H1 - 24V ?
Old 2nd February 2010, 20:03   #4
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
@gd1418 please use plain+spring washers wherever you are using such hardwares(for heavy duty applications) this will help distribute the forces generated during drawbar pull to a greater area thereby reducing induced stresses, in short less chances of failure.what is the bolt specification? is it M12x1.5 or is it BSW?
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 3rd February 2010, 12:21   #5
gd1418's Avatar
Thanked: 656 Times
Thanks RJ and was provided by my accessories dealer. I forgot to give the breakup. Here it is:
Bull Bar: Rs. 4950.00
Rallye 3003: Rs. 7100.00
Pintle Hook: Rs. 550.00
Parking bulb: Rs. 800.00
Total: Rs. 12850.00
The main bulbs of the Hellas are H1-12V 100W Hella
@SPIKE: This has totally gone above my head. But I've understood this much that you are enquiring about the holding strength of the Pintle Hook mount.
Now the hook is designed to pull a load of 5 ton, hence I'm sure the bolts that came with it can take that stress. In a regular 4x4 Scorpio, a pintle ball hook is provided by the company designed to take a load of 3+ ton. That is mounted on a plate that is welded to the pipe running at the back hidden by the bumpers and the pipe in turn is welded to the chasis.
In my case two iron plates of 12mm thickness have been electrically welded with each other and then welded to the pipe and to the mount on which originally the step was bolted. Holes were drilled and the hook fitted. The welder told me that it may shear off but the welding won't give way.
Spike
Hyundai Verna: Rear Torsion Bar / Front Stabilizer Bar? ph03n!x Modifications & Accessories 14 24th April 2014 12:34
Help needed for installing a rear tow hook on Ford Endeavour Gill22g 4x4 Vehicles 6 27th September 2011 14:22
Bull bar for scorpio renamo Modifications & Accessories 14 30th March 2009 20:32
Help to hook up a mp3 NOTORIOUS In-Car Entertainment 11 13th January 2009 11:08
