Old 14th September 2005, 23:01   #16
BUSA's Avatar
It will cost around 1 lakh or so! Power will be around 40bhp or something more depending on responsiveness of your engine!
Old 14th September 2005, 23:07   #17
dadudeonfire's Avatar
and are u sure it does not affect the fe...???because many people have told me that the fe drops drastically by 2-3kmpl
dadudeonfire is offline   Reply With Quote
Old 14th September 2005, 23:20   #18
BUSA's Avatar
Depends from engine to engine. But i dont think FE should drop since Pyscho has tried it on his conti and considering the engine is 1.8 mill from HM the FE incresed, so it should increase even on a Opel Corsa. Buttt Corsa engine is very sensitive and can blow up!!
Also with your car giving 7 kpl its really astounding. Why dont you put LPG and then NOS. Problem solved for 60K. 25K for LPG and a NOS EFI Kit(35bhp on tap) will set you back by another 35K!
Get a LHS mirror from a local side garage. Will come for less then 1000Rs.
Old 14th September 2005, 23:37   #19
yeah dude buying it next week...getting it for 900 bucks
Old 15th September 2005, 23:13   #20
karthik247's Avatar
Thanked: 16 Times
hey dude, could u post a few clear, big pix of ur car
karthik247 is offline   Reply With Quote
Old 16th September 2005, 05:08   #21
no man..just have 1 camera that also phone cam...i-mate jam...i thought the camera is good enough dude...anyways will try to click some good pics and post them...
Old 16th September 2005, 11:11   #22
turbo_lover's Avatar
corsa doesnt have a strong engine block ..i dont think adding a blower is of much use ,you'll end up friying the rings or something..
not too responsive to engine modds ..
see how it feels after the modding ..
i suggest you get a Air induction kit instead of the K&N filter..couple it with a decent exhaust system.. the throttle will lighten up a lot.
turbo_lover is offline   Reply With Quote
Old 17th September 2005, 11:19   #23
navin's Avatar
Thanked: 4,282 Times
Originally Posted by turbo_lover
corsa doesnt have a strong engine block ..i suggest you get a Air induction kit instead of the K&N filter..couple it with a decent exhaust system.. the throttle will lighten up a lot.
Hey, this makes sense.
Q1> can you recommend specifics. (air induction kit and exhaust).
Q2> anyone in Mumbai who I can trust to do this without making a mess.
navin is online now   Reply With Quote
Old 14th March 2007, 17:30   #24
adman77's Avatar
Hi guys,
My Corsa 1.4 gives me around 8.5 to 9 kmpl. I've got Iridium plugs, an FSE fuel pressure regulator, K&N cold air induction kit, 4x2x2 free flow exhausts and that too with 2mm throttle body expansion. If you don't do the throttle body expansion, it should give you at least 9 to 9.5 with the other mods. The iridium plugs in particular help quite a lot.
adman77 is offline   Reply With Quote
Old 16th March 2007, 09:24   #25
navin's Avatar
Originally Posted by adman77 View Post
I've got Iridium plugs..K&N cold air induction kit
Where would one get these 2 in South Mumbai?
Old 16th March 2007, 10:10   #26
Akshay1234's Avatar
Thanked: 7,241 Times
i think you can get them at 4 seasons. just opposite crossroads in tardeo.
Old 16th March 2007, 10:47   #27
gkrishn's Avatar
Thanked: 37 Times
One problem i have is at lower RPM, upto 2k, the response is pretty sllugish. I have no idea about this air induction kit. Is this 57i kit that sAP was talking about?? Will this help in improving this low end???
gkrishn is offline   Reply With Quote
Old 16th March 2007, 10:57   #28
navin's Avatar
Originally Posted by gkrishn View Post
One problem i have is at lower RPM, upto 2k...this low end???
This is exactly what my wife tells me. She has to rev it beyond 2K which make the ride noisy to get teh car to go. I want her to have a quieter ride and get the power she needs at lower revs.
Old 16th March 2007, 11:08   #29
adman77's Avatar
Default Corsa mods
My corsa flies the moment I foot the pedal. But the mods done were quite extensive. The low end sluggishness was solved by a 2mm throttle body expansion and an FSE fuel pressure booster. But keep in mind that these mods were done purely for performance (drags and stuff). If your wife's car is just used for daily driving, I suggest you stay away from it. Try getting a cold air induction kit and free flow exhausts from 4 seasons. That'll reduce the low end sluggishness quite a bit.
Old 16th March 2007, 11:33   #30
navin's Avatar
Thanks Adman. No need for the Iridium plugs then?
ANy idea what the Induction Kit and Free Flow exhausts shoud cost?
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
Opel Corsa Sail 1.4 performance modifications stevie Modifications & Accessories 2 5th May 2006 14:30
Changing Headlamps in my Opel Corsa Sail 1.6 Stolichnaya Technical Stuff 3 19th February 2006 11:33
opel corsa sail 20,000 kms report dadudeonfire Long-Term Ownership Reviews 12 26th December 2005 21:19
Opel Sail 1.6 shamishchandras The Indian Car Scene 6 8th June 2004 13:27
