Old 6th February 2010, 08:29   #1
driverace's Avatar
Thanked: 142 Times
Question Need to reduce bulbous shape of headlights.
I feel like, I need a reduction of the "bulbous" shape of the headlights of i10..
wonder if thats possible!
well thats one of the reasons why i wouldnt go for Beat!
if anyone agrees, from a certain angle, you can see the body curve and headlight-curve like 2 separate entities!!
i want to integrate both the curves into a smooth continuous curve..
can do?
care.
Ace
driverace is offline   Reply With Quote
Old 6th February 2010, 12:51   #2
pranavt's Avatar
Thanked: 272 Times
You'd probably have to fabricate new headlights.
Old 6th February 2010, 12:59   #3
Daewood's Avatar
Thanked: 223 Times
can do?
care.
Ace
Yes the i10 headlights protrude when seen standing 2 feet away from the rear door. i20 has headlights that merge with the shape of the car.
Try if you can fit i20 headlights to an i10
Daewood is offline   Reply With Quote
Old 6th February 2010, 13:01   #4
Tejas@perioimpl's Avatar
Thanked: 4,918 Times
That's the only option. Will be expensive and not reliable in terms of water proofing. And also if you break them, getting them fabricated again is an issue. Not to mention the aerodynamics. These cars are windtunnel tested.
What's the whole idea behind changing them? They don't look bad. Rather modify them to projector type if you interested in changing the look.
Most of the new cars have these bulging type headlamps: look at the accord, camry, altis.
Tejas@perioimpl is offline   Reply With Quote
Old 6th February 2010, 22:26   #5
Thanked: 152 Times
Infractions: 0/1 (5)
Yes it can be done but with gentle pressure and a heat gun .
Trust_In_Thrust is offline   Reply With Quote
Old 7th February 2010, 11:00   #6
driverace's Avatar
Thanked: 142 Times
Arrow Really!? Anybody done this!
Has anybody done this!?
I really think its very risky!
Possible issues:
1. unwanted deformation.
2. Discoloration.
3. any other side effects.
Please do give some more feed on this, thank you.
Care.
Ace.
Old 7th February 2010, 17:50   #7
Thanked: 152 Times
The headlight covers are made of acrylic sheet/plastic. Check out youtube and how the fabrication if custom headlights is done .There is no damage as long as proper stress and heat is applied.You can try it first on a broken headlight too.
Old 7th February 2010, 20:30   #8
tintin82's Avatar
Modifying the existing dome will change the characteristics of the light throw. You'll have some unwanted refraction, angular diffraction as the refractive index of the plastic will change.
tintin82 is offline   Reply With Quote
Old 7th February 2010, 20:32   #9
smokin's Avatar
Thanked: 13 Times
don't even think of it !!!!!
the acrylic sheet of the headlight is of different quality than compare to the aftermarket acrylic sheets .
Heat gun will not heat in uniformity and it will let you in deformation and and second;ly most point it has some chemical inside the headlight which if gets spoiled then it cant get rectified
smokin is offline   Reply With Quote
Old 7th February 2010, 22:52   #10
Thanked: 152 Times
@titntin82 : It is clear lens headlight an dwe are not doing anything to the reflector so no change in direction of reflection of light .Also please note the piece that he wants to change is not in the direction of throw of light in either high or low beam.
@smokin : Yes it is of different quality but it is still acrylic .I agree i may not be uniform in inexperienced hands but the bulge can be suppressed a lot (remember the chemistry lesson where we used to heat a glass tube and change its shape ).
And i do not know of any chemical in a headlight except for the silicone for sealing off .Please clarify ?
Old 7th February 2010, 23:23   #11
tintin82's Avatar
Ah, I see. I haven't taken a keen look at the i10's headlamps. I just remember the toad eye bulge .
As for the acrylic, using a heat gun on certain types of acrylic will make them turn slightly milky. I do not know if this will be case on headlamp domes as well.
Old 7th February 2010, 23:29   #12
vasanthn21's Avatar
Thanked: 303 Times
yes I agree. In fact, my wife had nick-named the i10 as "crocodile" as the headlights would pop out of the car like the eyes of a crocodile
vasanthn21 is offline   Reply With Quote
Old 8th February 2010, 08:46   #13
smokin's Avatar
Thanked: 13 Times
sir i agree withyou that is acrylic but still the quality is different than the one available in aftermarket this is rigid one (needs high temperture to get it bend )
still heatgun cant be upto the mark for heating it uniformly all over headlights,for this i can prefer the oven
for chemical even i dont know which one the use but you can do a experiment
buy a headlight ,on the inner side use a rubbing/polish in a paricular area with some force and you will see the removal of coating on that area
I am into this work that's why i know i have faced a lot of issues when one of m mechanic accidently drop some elfy on the civic headlights
we try to remove it by using rubbing and there was this thing happened
Afer that we went to the specialist guy who rubbed the whole coating of the headlight ,then i got to know about this
Old 8th February 2010, 09:32   #14
Shardul.YamahaF's Avatar
there is one thing that you can do
take a headlight of similar size and shape ( I20)
fabricate the bonnet and the fender and make it fit exactly in place
fabricating the whole headlamp is also a better option but i don't think there are any good fabricator for the same in India
and if there are I don't know
Shardul.YamahaF is offline   Reply With Quote
Old 8th February 2010, 12:14   #15
driverace's Avatar
Thanked: 142 Times
Smile preparing for i10 homecoming :)
Aww, dont say that.. the 'beautiful' i10 celebrates homecoming at my place on 12th !!
-You are invited too!!
yes, I too strongly feel heat treatment will cause some kind of discoloration!
- just a feeling though, not very sure.
Ok! Lol alright!
first an amphibian, now a Croc !! thats much better!!
<my young bro seems to agree a lot with your wife's opinion!! --now even more, that-he has read it here!!>
Well, I am not afraid of it!, but what I say is, instead, replacement is very simple solution, just the need of a replace-fit!
i20 solution here- I will check out surely with the dealer/mechanic.
<anybody done that yet?>
Care,
Ace.
Need to restore mclaren1885's baleno back to shape. Need all your valuable inputs. mclaren0111 Modifications & Accessories 142 5th September 2009 22:27
Need help for Viva CRDi Headlights goel.honey Modifications & Accessories 7 18th April 2009 23:34
Need Opinion on buying used Old Shape Honda City 2001 1.5 ExiS Model SumitBahl Sedans 27 20th May 2008 14:38
Do we need to change the Halogen headlights often ? mithun Technical Stuff 8 11th December 2006 19:39
