Old 13th September 2005, 09:14   #1
jigarmuni's Avatar
Default Tuned ECM for Vtec??
hi guys, posting after a long time but i really need some urgent help.
I need to change the ECM of my car.....so does anyone know from where i can get a tuned or modded ECM for HONDA VTEC 2001????
jigarmuni is offline   Reply With Quote
Old 13th September 2005, 09:25   #2
viper's Avatar
Thanked: 9 Times
Hey Jigar,
From what I know of you will have to send the ECM abroad for readjustment and instruct them to calibrate it as per the mods you have in your car. It costs around 10-12k for the total exercise.
Or you can fit a piggy back controller like a GReddy Emanage which can help to an extent.
Viper
viper is offline   Reply With Quote
Old 13th September 2005, 11:14   #3
Thanked: 11 Times
Hi Viper could you give us some more details on the piggyback controller?
How does it work, what are the gains, where we can get one, how much it costs etc?
Boom Shiva is offline   Reply With Quote
Old 13th September 2005, 11:56   #4
Psycho's Avatar
Thanked: 95 Times
The best piggy back controllers for the Honda cars are Hondata they can provide you with kits as well as reprogramming the existing one itself. However kits like the Apexi - VAFC will let you do a lot more much easily. However a note programming an ECU (even a piggy back one) is not as easy as it seems, any wrong data being entered can literally damage your engine. Please locate a person who is capable of programming the ecu for you before you go in for the purchase. My personal reccomendation would be the Apexi - VAFC.
As for the Chip change / remapping would suggest to contact Hondata.
The piggy back ECU monitors the incoming signals from various sources and alter the outgoing signals to your needs. This alteration happens over and above the working of your current ecu (hence the term piggy back).
Old 13th September 2005, 12:02   #5
Rtech's Avatar
Thanked: 221 Times
I think what Jigar needs is a completly new ECU as I am guessing his car suffered some flood damage??
Old 13th September 2005, 12:12   #6
hey the g-reddy emanage as far as i know...is a very good setup...will try and post some info on it...also i would like to know more abt the apexi-vacf...psycho could you send me a little more detailed info on this via a pm..if it's not an issue for you buddy...thaks a lot...cheers...happy revvin...!!
dragger is offline   Reply With Quote
Old 13th September 2005, 12:14   #7
Thanked: 10,997 Times
check out my post on vtec mods - psycho clearly explained everything.
Old 13th September 2005, 18:58   #8
Mpower's Avatar
Thanked: 1,687 Times
Go buy one from Honda dealership in KL or Bankok.
Old 14th September 2005, 01:07   #9
jigarmuni's Avatar
i need a new ecm also guys. I think the best alternative i have as of now is buying a thai Vtec spec ecm, which is meant for the DOHC. Where else our Vtecs are SOHC. But i still heard that those DOHC Ecms work well with our cars...!
Old 14th September 2005, 09:46   #10
Domnic's Avatar
The honda city vtec was launched in thailand also, the ecm on the type-z city is the same as our indian ones, infact i had got a few and sent some to mumbai and sold some here in bangalore. They work perfect, they infact feel faster also. The indian pj1,p2s etc series ecm are not programmable. You can shift only the revlimit. You can use alternatives like the Twincam ecm preferably an obd1. The ecm will run pretty much the same and could add about 10+ horses, and give you a revlimit of 8500. To install this ecm however you will need to either buy an obd2- specb to obd1 conversion harness. Otherwise i can send you a wiring diagram where you can jump the wires and convert it (this is a cheaper option) but you have to be carefull while wiring. I have one vtec running this ecm, i have chipped it and running a JUN program, slightly rich map as we are running pretty high compression and stage 4 cams. The best thing in the twincam ecm is that its chippable, for changing programs all you need is a motorola rom, burn the program using a willem burner.
So go for the ecm, will be quite fun running, dont buy the b18 ecm's, get the b16a obd1, as the b18 base program runs a rich map and you may have driveability issues like flat spots etc....
Dom
Domnic is offline   Reply With Quote
My Vtec (1st-gen City): Tuned by Race Concepts speedfreak Modifications & Accessories 46 7th October 2017 08:03
OMG!! A Hummer H2 tuned by Germans! Stratos The International Automotive Scene 20 25th June 2008 19:48
My beloved Tuned Honda City Vtec 2002 54k ajmat Shifting gears 1 18th December 2007 09:04
Novitec tuned Ferrari 360 X-Machine The International Automotive Scene 13 22nd September 2004 21:56
HQ Pics of S-class tuned by A.R.T M POWER The International Automotive Scene 6 9th August 2004 22:32
