| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here! |
| | Thread Tools |
| | #2 (permalink) |
| Distinguished - BHPian ![]() | Hi I've heard of this piece of equipment, but not sure how it works. Can you give us more information on this product? Seeing that Pete is unlikely to bring out a tuning box for the Safari, I need to start looking out for alternatives. Question is - does this improve performance or is it just a protection device?
__________________ Cheers Steer Petrols Suck. Diesels Torque. Q.E.D Last edited by Steeroid : 18th September 2005 at 11:29. |
| | #3 (permalink) | |
| Senior - BHPian Join Date: May 2004 Location: Bombay
| Quote:
__________________ ______________ __________ ______ __ | |
| | #4 (permalink) |
| BHPian Join Date: Apr 2005 Location: Pune
| From what i have read and heard this is what a Universal Turbo timer does : A turbo timer is a device that allows your car to continue running after the key is removed in order to cycle oil through your turbo, preventing bearing damage and 'coking' of the oil lines. For certain vehicles, you will have to splice into your factory wiring for installation, while most Japanese vehicles have available 'plug-and-play' harnesses for a simple, splice-less installation. Cheers
__________________ Speed Thrillssss And Kills Every Other Car On The Road !!!!!!!!!--- EVO 6 |
| | #5 (permalink) |
| BHPian Join Date: Aug 2004 Location: Mumbai
| Is this really required for the newer generation turbo-diesels? I have seen caution stickers in older diesel cars like the Sierra etc. that suggested a one minute idle before shutting the engine. But in my 220, there is no such recommendation in the manual or otherwise GTO |
| | #8 (permalink) |
| BHPian | I guess you wouldnt need it for most TCs in the diesel cars. I guessing that this is because they are not being worked as much as say a turbo in a Supra??? Does it have something to do with the boost? BTW does a TC in a diesel car and a petrol car run upto the same rpms? I mean the engine speed in a diesel car is approx 75% of that of a petrol car. Does this mean that the TC will also be running at a lesser speed? (Sholud be according to a educated guess)
__________________ Its like turbo lag. But funny there isn't a turbo. |
| | #9 (permalink) |
| BHPian Join Date: Jan 2005 Location: chennai
| Hi , http://www.team-bhp.com/forum/showth...7&page=4&pp=15 (Pics: Speed Run 2005 [Saturday]) I think sideways has a problem of melting of turbo is this because of not using the turbo timer???? |
| | #10 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Turbo's typically would melt due to extreme operating temperatures and oil problems (vapourisation / stoppage of oil supply) while in use and not while stopping. As for most of the newer turbo cars you would notice the turbo coming on a little later on the rev band (Turbo Lag) this would allow for the turbo to spool down enough when you stop your car and shut off your ignition. However where turbo's start spooling at low RPM's (typically modded cars) you would defn need a turbo timer. One point that turbo'd owners should be careful about is when you start your car never rev it imm, wait for abt 30 secs for the oil to start flowing through your turbo.
__________________ Learning is a continuos job that keeps me busy. | |
| | #11 (permalink) | |
| BHPian | Quote:
(D - directly proportional; I - indirectly proportional) 1) Velocity of exhaust gas flowing through it. - D 2) Total mass flow of exhaust gas flowing through it. - D 3) Oil pressure lubricating the turbo's bearing/bush. - I 4) Restriction (back pressure) at the compressor outlet. - D Assume you have a petrol and a diesel of identical size and identical everything. Lets say a Indica petrol and Indica diesel. Then the following would be true: - (a) At low RPM, the diesel would have higher (2) than the petrol. This is due to there being no throttle present on the intake. (b) At low RPM, the diesel would have lower (1) because exhaust gas temperature (EGT) would be lower. (c) At low RPM, the diesel would have lower (4) because there is no throttle on the intake. a,b and c offset each other so it would be impossible to predict the relative speeds of the turbo at low RPM. It is impossible for a diesel to rev as high as an equivalent petrol because you would run out of air to burn the fuel. Assume therefore, that the diesel redlines at 4000 rpm and the petrol at 6000 rpm. Then, (d) At high RPM, the diesel would have lower (2) than the petrol. This is simply because the petrol is pumping more air due to its higher RPM, and the throttle on it is fully open (WOT condition). (e) At high RPM, the diesel would have lower (1) because exhaust gas temperature (EGT) would be lower. (f) At high RPM, the diesel would have higher (4) because both would be consuming the max. air they can, and as said in (d), the petrol would be consuming higher amounts of air. Therefore, you can safely say that the petrol would definitely be spinning the turbo much faster than the diesel at higher rpms. It is not possible to predict what happens at lower rpms unless the exact numbers are known. Ananth | |
| | #12 (permalink) |
| Team-BHP Support ![]() | TurboDiesels run cool and dont need timers. Turbo Petrols that run high boost do (even the Octy RS is only 8psi I think and can do without one. ) Recomended for after market turbo setups where the the lubrication systems were never designed for turbo's heat and ones that dont use oil cooler.
__________________ The difference between the men and the boys....................is the speed of their toys. |
| | #15 (permalink) |
| Newbie Join Date: Oct 2006 Location: Chandigarh
| The official definition: A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to run down in speed and cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed. So is it required still with the new Scorpio CRDe (Turbo-charged, Intercooled, DI, CRDe)?
__________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~ Up, up, up and away! |
| Thread Tools | |
Similar Threads | ||||
| Where to get a Turbo Timer in Bangalore | 500HP | Modifications & Accessories | 4 | 14th March 2007 11:09 |
| Lamda sensor and timer advancer | Fl|rty | Modifications & Accessories | 5 | 12th September 2006 19:44 |
| Hi from a young old timer | Psycho | Introduce yourself | 74 | 22nd August 2006 15:26 |
| Cars from Movies. Universal studios LA | chaxy | Shifting gears | 7 | 28th October 2005 00:01 |
| FIPK or just a universal air filter? | mustang | Modifications & Accessories | 5 | 21st April 2005 12:37 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
