Old 15th July 2010, 09:56   #136
pramodkumar's Avatar
Thanked: 947 Times
Originally Posted by Amey View Post
I am using the old one, the petrol lancer and cedia have a thinner radiator,so I think this will work pretty well.
Amey, i have heard a lot of issues about lancers overheating when turbocharged, your engine is bigger and going to be turbocharged so i feel a bigger radiator might do the trick, i may be wrong here.
Pramod
Old 16th July 2010, 07:26   #137
Hey Amey congrats I thought you were still in Jakarta. Cant wait for your wideband readings. I am also using my stock ECU and was told that since its on closed loop it will work fine. I'm also planning to go for Megasquirt. Already started doing research on the same. i wish there was someone on team bhp who had done it. But last I heard our ECU's cant be re chipped the way HM has bought them out. I may be wrong but you will have to confirm. Are you using the INNOVate wideband? Where are you hooking it up because the OE O2 sensor will also be required for the stock ECU. So I guess you will need to drill another bung into your primaries.
wildwheels is offline   Reply With Quote
Old 16th July 2010, 09:11   #138
Amey's Avatar
Thanked: 189 Times
I have an Innovate wideband but am not using it right now.Will do so later on, first need to get the car moving fine and sort out minor issues and improve the reliability factor a bit.Then comes the tuning and data logging part.
Amey is offline   Reply With Quote
Old 16th July 2010, 09:28   #139
Amey's Avatar
Thanked: 189 Times
Wink
Test drove her for the first time yesterday.Although it was just a few hundred meters, it's still a big step for us
Old 16th July 2010, 19:50   #140
ImmortalZ's Avatar
Thanked: 312 Times
Whoohoo! Nice to see real progress happening Amey.
Old 17th July 2010, 07:07   #141
Amey's Avatar
Thanked: 189 Times
Wink
Thanks Immortalz.
Bumper fitting, headlamp,indicator,dash assembly done,just waiting for the MAF-Air Filter flange to arrive today so that we can install the filter and then its time for some on road trials
Old 22nd July 2010, 11:51   #142
Amey's Avatar
Thanked: 189 Times
Wink
After waiting for 4 months, the car is finally back on the road.
We did drive her a couple of times in the garage itself, sorting out minor issues but now she is properly on the road, already drove around 100-120 kms and boy I am already loving it!
Here are a few pics,
Engine bay after completing engine swap in all respects,
Engine swap/Performance mods in Lancer-22072010068.jpg
Custom made MAF sensor to Air Filter adapter.The filters have round mouth and the sensor has a square one...Arrgh
Engine swap/Performance mods in Lancer-22072010070.jpg
UCAl/Mikuni Fuel Filter from Maruti 800..Lol
Engine swap/Performance mods in Lancer-22072010071.jpg
Look at my innovative battery bracket!
Engine swap/Performance mods in Lancer-22072010072.jpg
Still on Michelin XM1+ 165/80/R13 tyres.
Engine swap/Performance mods in Lancer-22072010073.jpg
She comes home after a looooong time. Home sweet home
Engine swap/Performance mods in Lancer-22072010074.jpg
Initial impressions: She is quick, very torquey and eager.Thanks to the TDM ECU, she revvs right upto 7k rpm (more but havent pushed yet). The intake note is pretty aggressive. Still on stock headers and remaining plumbing till end can is still the old one.
On Monday I should get the exhaust done after the headers as current one is pretty restrictive. That should help a lot.
Very silent and sedate at normal speeds and rpm but things start getting interesting past 3k rpm mark and after 5k rpm its transforms into some sort of a beast, with its deafening growl and a scary sprint.
Loving every bit of it. There are still a few niggling issues but the joy of driving her is far more overpowering.
Still a long way to go,I know but then this is sort of a major stage completed.
Body/Chassis of a diesel lancer + Loom from a non power window Lancer with 4G93 engine + 4G94 engine from an indian Cedia
So it wasnt exactly a straightforward job atleast for us since me or my friend, Abhijit have no experience of doing engine swaps. Removing engines for rebuilding, removing looms and dismantling cars for painting or body work is no big deal for him but this is the first time he did such a job.
That's why it is a big achievement atleast for us to have accomplished till here. A good morale boost for the work to be done in the future.
Unfortunately I have no video but will take one and post it pretty soon.
Thanks,
Amey
Old 22nd July 2010, 12:29   #143
pranavt's Avatar
Thanked: 274 Times
Congrats! Does this engine have variable valve timing (MIVEC right?)? Have you prepped up the Megasquirt and the LC-1?
Old 22nd July 2010, 12:59   #144
jatinpatel's Avatar
Thanked: 191 Times
@pranavt
as this is a cedias 4G94 engine it does not have variable timming MIVEC
jatinpatel is offline   Reply With Quote
Old 22nd July 2010, 13:23   #145
Thanked: 947 Times
Originally Posted by jatinpatel View Post
@pranavt
But the heads are swappable right?
Pramod
Old 22nd July 2010, 13:45   #146
Amey's Avatar
Thanked: 189 Times
No this engine does not have variable valve timing aka MIVEC.Its the 4G92 1.6L engine from the same family that had MIVEC. So theoretically, even this engine can be made into MIVEC by swapping the head
Now that the car is running, I can concentrate on the Microsquirt and LC-1.
Old 22nd July 2010, 14:06   #147
pranavt's Avatar
Thanked: 274 Times
Swap the head then
Old 22nd July 2010, 17:12   #148
Thanked: 947 Times
Sweet, i wish they had a MIVEC head for 4G15 as well.
Pramod
Old 22nd July 2010, 20:48   #149
Amey's Avatar
Thanked: 189 Times
Swap the head then
4G94 block with MIVEC head with Turbo.....wow! exciting proposition but for now, I think I will stick with the SOHC turbo plan for now
Old 22nd July 2010, 21:45   #150
Technocrat's Avatar
Thanked: 2,589 Times
Good to know its going well with the trial runs Amey
Btw whats wrong with the doors? If its oil & dirt then this is the first car of yours which I have ever seen dirty.
Technocrat is online now   Reply With Quote
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 61 13th July 2016 15:49
Esteem headlamp, tail lamp swap possible without mods? Raccoon Modifications & Accessories 24 15th December 2009 04:59
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 15:12
performance mods for a lancer... MIVEC engine transplant drunk.monkey Modifications & Accessories 21 17th June 2008 13:28
Performance Mods. for Lancer toogoodforyou Modifications & Accessories 6 7th March 2006 03:00
