Old 17th August 2010, 08:56   #166
Amey's Avatar
Thanked: 189 Times
Had gone for a short drive to Lonavla on Independence day.Took a couple of videos on the way.It was fun to drive her flat out since it was dry, no wet roads,no rains nothing,perfect weather.
Since high speed speedo pics or videos aren't allowed here, will only post a small video showing the acceleration.
Amey is offline   Reply With Quote
Old 17th August 2010, 15:55   #167
Neil.Bhujbal's Avatar
Thanked: 57 Times
Got to know the top speed car hit & time taken to reach lonavla from Mr lonkar I was wondering what will those figures be like ones the car is turbocharged
Come to Tune Up Plus next time & you will see one rising bhpian working under a expert bhpian.
Neil.Bhujbal is offline   Reply With Quote
Old 22nd August 2010, 23:54   #168
GreaseMonk's Avatar
Thanked: 85 Times
@Amey, I hope you don't mind if I post a friend's query here regarding his lancer.
2000 lancer petrol - stock car had 95 bhp.
its still got a good amount of power, yet underpowered for a lancer - 1L odd kms would explain that
things that are cocked up - exhaust, clutch, brakes, suspension also AC but thats on the B-list
not much torque - struggles to accelerate after 100 kmph
do i do the reboring and then work on the exhaust etc.. - i know this will definately make the car faster
or do i change the filters, exhaust, tyres now and let the engine run a little longer - how much faster will option A be then option B?
GreaseMonk is offline   Reply With Quote
Old 24th August 2010, 23:01   #169
Amey's Avatar
Thanked: 189 Times
When did Lancer have 95 BHp ? The Indian Lancer had 87 Bhp or so.Had he done mods?
Before jumping on to reboring and stuff, I would say give the OWS stuff a try. Its worth it.
Get a engine,radiator flush done.Replace engine oil with OWS synthetic oil (there is some special oil meant for high run engines) replace gear oil,change air filter, fuel filter etc.
Even throttle body cleaning should be given a shot.
See if these things help in performance.
Assuming that your friend has a stock lancer which mean it had the 4G15 engine,then I am afraid, there isnt much that he can do.In all fairness, that engine is a sad unit made by Mitsu. It can never generate good power with whatever mods.
I wouldnt waste time working on that engine, would do the basics first as mentioned above and see if it helps. Also he could try Iridium spark plugs,should make tiny difference.
From what I have read till now, the fuel delivery for the lancer is its weak point, tuned for efficiency and not performance.So FPR and a bigger fuel rail with a high pressure fuel pump should help in improving the performance by a decent amount.
Old 7th September 2010, 08:34   #170
Amey's Avatar
Thanked: 189 Times
Started wiring up the motherboard and the connector board yesterday. Almost there now
Engine swap/Performance mods in Lancer-06092010086.jpg
Engine swap/Performance mods in Lancer-06092010088.jpg
Lets hope this thing works..lol
Old 9th September 2010, 11:39   #171
leadf00t's Avatar
Thanked: 12 Times
Real Clean work Amey.
I am in awe for your DIY. Back in college days i did a lot of DIY but never got the whole circuits right.
Manually soldering a ECU is amazing.
This car is going to be an epic.
leadf00t is offline   Reply With Quote
Old 4th October 2010, 01:20   #172
Amey's Avatar
Thanked: 189 Times
Next phase begins,
Engine swap/Performance mods in Lancer-03102010092.jpg
Engine swap/Performance mods in Lancer-03102010093.jpg
Engine swap/Performance mods in Lancer-03102010095.jpg
Engine swap/Performance mods in Lancer-03102010094.jpg
A few goodies arrive
Old 8th October 2010, 00:12   #173
Amey's Avatar
Thanked: 189 Times
Engine swap/Performance mods in Lancer-06102010100.jpg
Engine swap/Performance mods in Lancer-06102010099.jpg
Manifold almost nearing completion
Old 8th October 2010, 02:53   #174
Technocrat's Avatar
Thanked: 2,479 Times
Good Going Amey
Do you have the pic of original manifold? Would be interesting to compare the before & after :-)
Old 8th October 2010, 11:26   #175
pranavt's Avatar
Thanked: 272 Times
I hope you end up losing the AC and PS because of that manifold
Old 8th October 2010, 13:26   #176
Amey's Avatar
Thanked: 189 Times
Originally Posted by Technocrat View Post
Good Going Amey
Dont have the pic of manifold on the car, but have the manifold lying around somewhere,will click some pics.
Sorry, your wish wont come true! muahahahahah as I get to keep both, AC as well as PS
Old 8th October 2010, 18:25   #177
kutlee's Avatar
Thanked: 194 Times
nice looking ramhorn mani. why those extra cantilever support? i think those can bit more artistic by adding some veins over the pipes..
kutlee is offline   Reply With Quote
Old 8th October 2010, 21:02   #178
good work dude.
when are you planning to start the engine.
armotosport is offline   Reply With Quote
Old 9th October 2010, 01:25   #179
Born2Slow's Avatar
Thanked: 42 Times
Great work Amey. I wish i lived in pune. I am a big fan of engine mods, but have no experience more than working on a couple of single cylinder engines. I went through the whole thread and i am overwhelmed, wish i could do something like this on my sx4.
I have a question for you as i got lost reading the threads.you started with a 16v sohc engine and i suppose you still have the same head, correct me if i am worng. My question is how will a dohc increase power as i saw some mention of it somewhere.
Born2Slow is offline   Reply With Quote
Old 9th October 2010, 01:26   #180
Amey's Avatar
Thanked: 189 Times
Engine swap/Performance mods in Lancer-08102010102.jpg
Engine swap/Performance mods in Lancer-08102010103.jpg
Engine swap/Performance mods in Lancer-08102010111.jpg
Engine swap/Performance mods in Lancer-08102010112.jpg
Engine swap/Performance mods in Lancer-08102010120.jpg
Engine swap/Performance mods in Lancer-08102010121.jpg
Engine swap/Performance mods in Lancer-08102010123.jpg
Received the Turbo Dump pipe in mail today, took a trial with it bolted on the turbo and installed in the engine bay along with manifold.
Everything fits perfect!
And yes, it doesnt interfere with the AC Compressor so I get to keep the AC...woooohoooo!
Figured out Intercooler piping also.Suddenly things have started rolling fast.
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 61 13th July 2016 15:49
Esteem headlamp, tail lamp swap possible without mods? Raccoon Modifications & Accessories 24 15th December 2009 04:59
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 15:12
performance mods for a lancer... MIVEC engine transplant drunk.monkey Modifications & Accessories 21 17th June 2008 13:28
Performance Mods. for Lancer toogoodforyou Modifications & Accessories 6 7th March 2006 03:00
