Old 11th May 2011, 21:15   #271
Amey's Avatar
Thanked: 189 Times
Default Re: Engine swap/Performance mods in Lancer
Originally Posted by Born2Slow View Post
Truly amazing work Amey. I have a question for you thou. If your planning to turbocharge the motor does it matter that much whether its a dohc or sohc regarding the engine breathing part as long as you have 16 valves, or is it that you need some flexibility in the cam timings. Sorry if the question has been asked before.
You can Turbocharge a SOHC motor, its not like you cant but a DOHC head will definitely help thanks to its much better flow characteristics.
SOHC - DOHC swap was not part of the original plan, its a last minute addition
Wow the visuals are amazing !! It looks like a new engine - great patience & great work..so when does it hit the road ??
4-5 days maybe ? Clutch installed today,tomorrow gearbox will be installed and then the entire thing goes in.Then comes the reconnection part for sensors,installing manifolds,injectors,coil packs,leads and so on.
Drool pics man, very nice built. So, time for a turbo ? what boost you plan to run this thing on.
Forged internals can take 14 PSI and above. I mean I was surprised to read RPWs details of 4G94, where it said that the stock internals can also take up to 14 PSI of boost, ofcourse depending upon intercooler and tuning and an upgraded gasket.
Turbo was always the original plan, DOHC popped in between lol. The bottom end is strong enough for 18-20 psi boost or maybe even more.
I plan to use around 5-8 psi boost daily (Even thats gonna be a handful) but since I woul dbe having electronic boost control inbuilt in my ECU, i can crank it up whenever I want
Amey is offline   (1) Thanks Reply With Quote
Old 11th May 2011, 21:52   #272
Technocrat's Avatar
Thanked: 2,589 Times
Looks good Amey
Like the colorful parts, they came like that or you got the cover etc painted?
All the best with the Finish & looking forward to your drive experiences
Old 11th May 2011, 21:56   #273
Neil.Bhujbal's Avatar
Thanked: 59 Times
Any idea on what the compression ratio will be like ? Its needs to be low for the turbo right ?
Neil.Bhujbal is offline   Reply With Quote
Old 12th May 2011, 02:17   #274
m4ugr8's Avatar
Thanked: 123 Times
The engine pics look fantastic. Waiting for the engine bay pics of the complete engine goes in.
m4ugr8 is offline   Reply With Quote
Old 12th May 2011, 10:45   #275
Amey's Avatar
Thanked: 189 Times
Originally Posted by Technocrat View Post
Looks good Amey
The DOHC head isnt brand new.Therefore it was obviously looking old and used.Even though the head was completely worked on internally, the Rocker cover looked very dirty and old and thats why we go it painted.Since we built the engine completely with new internals,why keep the most visible part in unattended state and let it become an eyesore ?
As for the Cam pulleys, they arrived after the rocker cover was painted and Even though I had told Luis to send me black or blue ones, he deliberately sent purple ones.Thank god he didnt send pink ones as per his original plan.Would have killed him if he did that.
To be honest, We havent really checked as such. The stock engine had a CR of 9.5:1 and the 4G93 DOHC had a CR of 12:1 but then we are using deep dish forged pistons similar to the stock ones but with a slightly deeper dish and in addition to that we are using 1.8mm OE MLS gasket from the 4G93 DOHC Turbo.
Although we havent measure the CR, I am sure it is within safe limits.
Old 13th May 2011, 08:18   #276
moralfibre's Avatar
Thanked: 6,532 Times
I had no doubt on the output quality of this build considering that Amey had done his research to the "T". He would always recite part numbers, model numbers and specifications at the tip of his tongue and is very well prepared to have a modded car. Well deserved mate, can't wait for the car to be back on the roads.
All the best.
Old 15th May 2011, 00:48   #277
S_U_N's Avatar
Thanked: 383 Times
Maybe this is the most appropriate thread for my queries.
Where can I find spares for Cedia in Pune or Mumbai?
I am looking for a gear knob and maybe a few more parts subsequently.
Thank you for the rich experience sharing.
S_U_N is offline   Reply With Quote
Old 18th May 2011, 10:53   #278
Amey's Avatar
Thanked: 189 Times
If you are looking for OE parts then I think J.Williams & Co. is your best bet. If you are looking for aftermarket stuff then depends on what all you need.There are a couple of places like Poona Motors where you can pick up these accessories.
Old 19th May 2011, 10:30   #279
razor4077's Avatar
Thanked: 258 Times
Looking awesome! Can't wait to see everything in place. Will you be chroming anything? Would go well with the painted rocker cover etc.
Would love to see the car in person sometime. Will give you a call when I make it to Pune.
razor4077 is offline   Reply With Quote
Old 19th May 2011, 13:21   #280
Amey's Avatar
Thanked: 189 Times
No, I hate chrome!
You are most welcome to drop in anytime mate.Will definitely let you know whenever I plan to come to Mumbai with the car.
Amey is offline   Reply With Quote
Old 25th May 2011, 16:01   #281
Amey's Avatar
Thanked: 189 Times
After rebuilding the engine, and changing the head, we had never tried whether the custom made turbo manifold and the turbo fit well with the new head because the manifold was made after taking measurements with turbo installed with the old SOHC head.
So we thought, why not try out before the engine goes inside tomorrow.
It was such a relief to know that everything fit just fine.
Engine swap/Performance mods in Lancer-img_20110525_125845.jpg
Engine swap/Performance mods in Lancer-img_20110525_125901.jpg
Engine swap/Performance mods in Lancer-img_20110525_125910.jpg
Engine swap/Performance mods in Lancer-img_20110525_125920.jpg
Engine swap/Performance mods in Lancer-img_20110525_125929.jpg
Engine swap/Performance mods in Lancer-img_20110525_125939.jpg
The dump pipe is readymade but the manifold is made locally. A few modifications would be done to this manifold to make a port for installing the external wastegate.
Will up date this thread as and when I have updates.
Amey is offline   (2) Thanks Reply With Quote
Old 25th May 2011, 17:21   #282
pranavt's Avatar
Thanked: 274 Times
With the seperate runners, you know you need 2 wastegates. Your plans of merging the 2 set of runners to a single wastegate is going to cause boost-creep. Where the path to the wastegate provides resistance and cannot bleed all the extra air. Hope you have planned for that.
Old 25th May 2011, 18:59   #283
Amey's Avatar
Thanked: 189 Times
I know that buddy and still in a dilemma what to do about it.
Old 25th May 2011, 23:21   #284
jatinpatel's Avatar
Thanked: 191 Times
@pranav @amey
what is boost creep?
and is your manifold made of MS?
jatinpatel is offline   Reply With Quote
Old 26th May 2011, 01:02   #285
Amey's Avatar
Thanked: 189 Times
Originally Posted by jatinpatel View Post
@pranav @amey
Its Stainless steel mate.
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 61 13th July 2016 15:49
Esteem headlamp, tail lamp swap possible without mods? Raccoon Modifications & Accessories 24 15th December 2009 04:59
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 15:12
performance mods for a lancer... MIVEC engine transplant drunk.monkey Modifications & Accessories 21 17th June 2008 13:28
Performance Mods. for Lancer toogoodforyou Modifications & Accessories 6 7th March 2006 03:00
