Old 18th March 2010, 13:18   #31
nitrous's Avatar
Thanked: 285 Times
OT:
Originally Posted by PramodKumar
Have you noticed a lot of swift GTI DOHC heads are available for sale these days?
Thats because people keep the bottom end and don't need the twin-cam head since we already have a 16v head in the esteem engine.
Old 18th March 2010, 13:43   #32
pramodkumar's Avatar
Thanked: 947 Times
Originally Posted by nitrous View Post
OT:
So you are saying there is no relative power difference between a 16 V head and a DOHC?
Pramod
pramodkumar is online now   Reply With Quote
Old 18th March 2010, 14:24   #33
nitrous's Avatar
Thanked: 285 Times
Pramod
Yes and No.
You tell me why there would be a difference with a DOHC and SOHC even if both run 16 valves?
Old 18th March 2010, 14:35   #34
moralfibre's Avatar
Thanked: 6,533 Times
Let us take the DOHC v/s SOHC comparison to - > (Which engine is better? SOHC vs DOHC).
Old 21st March 2010, 22:45   #35
Delta Wing's Avatar
Thanked: 112 Times
Hey Amey, where have you reached with the transplant? Where did you source the engine from and where are you getting the work done from in Pune? Hope to see you next time in pune meet with the new ride?
Delta Wing is offline   Reply With Quote
Old 22nd March 2010, 09:08   #36
Amey's Avatar
Thanked: 189 Times
Hey,
Work is going on slowly and steadily.Have removed the old engine and gearbox.Faced some problems with the bell housing, sorting that out (Almost done)
I am getting the work done at Tune Up Plus,Baner.
It will be some time before I get it working.Another month or so assuming all parts arrive in time.
Amey is offline   Reply With Quote
Old 22nd March 2010, 10:33   #37
Delta Wing's Avatar
Thanked: 112 Times
Originally Posted by Amey View Post
Hey,
Cheers. Could you post some photos of the ongoing works?
Old 24th March 2010, 19:05   #38
Amey's Avatar
Thanked: 189 Times
Update :
Few days back or rather last week, we pulled out the existing diesel engine and gearbox to confirm that the gearbox fits the new engine. To our horror, it did not!
Thing is Lancer Diesel and Petrol both had F5M41 gearbox BUT different bell housing. The cedia has F5M42 gearbox which is same as F5M41 with some differences in internal mechanism, basically the body of both the gearboxes is same.
Anyway, so with a non matching bell housing we had reached a road block. So either we needed a petrol lancer bell housing or the entire gearbox. This did dampen our spirits a bit.
After searching a bit, we luckily found a used petrol lancer gearbox for cheap in decent condition, immediately picked it up.
It arrived today afternoon and we immediately tried fitting it and Voila ! it works!
The shaft matches, the 4G94 flywheel,clutch,pressure plate matches!
Now comes the cleaning and overhauling part for the gearbox.
Before that, we will try plonking everything in just to make sure everything fits well.
Once we are sure, we will start chassis strengthening, engine bay painting and so on.
Thats all for now, will keep updating the thread from time to time.
Old 25th March 2010, 02:05   #39
Ford Rocam's Avatar
Thanked: 16 Times
Hi Amey one quick query, Are Gear ratios & final drive (O.E.M) for Petrol lancer & Cedia gearbox are identical? there must be some difference i.m.o.
Ford Rocam is offline   Reply With Quote
Old 25th March 2010, 08:37   #40
Amey's Avatar
Thanked: 189 Times
Yes Jeetu, I am aware they are different and both have different models of different Gearboxes too.
The 4G15 comes with F5M41 and Cedia comes with F5M42 box. But you can use the F5M41 box on the 4G94 engine.
Anyway here are the ratios,
Lancer Petrol -
1st - 3.583
2nd - 1.947
3rd - 1.343
4th - 0.976
5th - 0.804
Reverse - 3.416
Final - 4.052
Lancer Cedia -
1st - 3.583
2nd - 1.947
3rd - 1.379
4th - 1.030
5th - 0.767
Reverse - 3.363
Final - 3.722
Interestingly, the diesel and petrol lancer have same ratios except for the final drive. The cedia and diesel lancer final drive ratios are same.
No issues to get the car running, can figure out the drive ratios later on. I have something in mind for that too.
Old 25th March 2010, 21:06   #41
regnex's Avatar
It can be done, I know someone who has done it and can arrange one for you if you want. If you are really keen, let me know, will let you know all the details.
Amey,
great stuff you got going there, love your in-dept research. as always, pramod and the rest are contributing to a great deal too, love this thread.
i myself am keen to get a DOHC for my 1.5, but have no clue where to start, could you share some of your info or PM me the same?
cheers buddy
regnex is offline   Reply With Quote
Old 26th March 2010, 09:18   #42
Amey's Avatar
Thanked: 189 Times
Originally Posted by regnex View Post
Amey,
cheers buddy
Hey,
Thanks man.Its still a long way to go but atleast I have got going.
Anyway I will PM you the details regarding the DOHC conversion thing,its a bolt on thing
Old 26th March 2010, 09:27   #43
Thanked: 947 Times
Hey,
Already PMd him . BTW, can you please post some pics of the WIP?
Pramod
Old 26th March 2010, 23:41   #44
Amey's Avatar
Thanked: 189 Times
@ Pramod,
I work on the car whenever I find time from work buddy,so progress is going to be slow.
Anyways a few updates :
Engine swap/Performance mods in Lancer-img_3511.jpg
Engine swap/Performance mods in Lancer-img_3513.jpg
The engine with the 4G15 Gearbox, perfect fit, Bolt on. 4G94 clutch,flywheel,pressure plate fit well.This means I can use OEM/Performance clutch meant for Cedia.
Then it was time the see if the mounts fit in stock brackets.
We had guessed that the Driver side mount would not work from the diesel engine but still we tried, this is what happened,
Engine swap/Performance mods in Lancer-img_3524.jpg
It didnt align well and the bushing was twisted under pressure. This also caused the cross member holes to mismatch.
So it was pretty evident that new mount was needed. Called the local Mitsu dealer, know the service advisor there well and he said he had one piece in stock.
Since the 4G92,4G93,4G94 belong to the same family, getting 4G93 mount would be possible since it was sold in India in Invex version. As mentioned above, we got one piece from the dealer on approval basis,
After trying,
Engine swap/Performance mods in Lancer-img_3539.jpg
It fits perfectly!
This is the only mount that had us worried.With this mount used, the cross member also aligned perfectly.So basically all four mounts fit well,bolt on!
Then it was time to check the axles,whether they fit (since this is 4G15 gearbox,we sort of knew it would but its best to practically try to install)
Engine swap/Performance mods in Lancer-img_3517.jpg
Engine swap/Performance mods in Lancer-img_3521.jpg
The axles too fit well,correct length, no need to get different ones or alter the existing ones.
Here is the final outcome at the end of the day,
Engine swap/Performance mods in Lancer-img_3542.jpg
Engine swap/Performance mods in Lancer-img_3547.jpg
Engine swap/Performance mods in Lancer-img_3548.jpg
Good progress according to us. Major worry of fabricating new mounts or brackets was taken care of, everything fit perfectly.
Now we can take the next step.
Thats all for now More as things proceed.
Old 28th March 2010, 01:24   #45
Thanked: 947 Times
@ Pramod,
Thanks for posting the pics, Nice and detailed posts, Looks like my car, its of the same color and moreover the grill is body colored like mine . BTW one question did you not rebuild the engine?
Pramod
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 61 13th July 2016 15:49
Esteem headlamp, tail lamp swap possible without mods? Raccoon Modifications & Accessories 24 15th December 2009 04:59
Safari TCIC 2.0 Engine swap with 3.0L DICOR Engine gd1418 Modifications & Accessories 34 6th July 2009 15:12
performance mods for a lancer... MIVEC engine transplant drunk.monkey Modifications & Accessories 21 17th June 2008 13:28
Performance Mods. for Lancer toogoodforyou Modifications & Accessories 6 7th March 2006 03:00
