| LinkBack | Thread Tools | Search this Thread |
| | #46 |
| BHPian | @ Pramod, There was no need to rebuild the engine, it is in perfect condition,doesnt make sense to rebuild an almost new condition engine. We had just plonked it in to make sure the mountings are right. The engine is out, we removed it yesterday. |
| | #47 |
| BHPian | Good progress and well researched Amey, All the best. I am watching this rebuild. Next time I am in Pune, we will try and make it the workshop for seeing the progress. |
| | #48 |
| BHPian | Here's the big boy getting his hands dirty ![]() |
| | #49 |
| BHPian | |
| | #50 | |
| Senior - BHPian | Quote:
Yes that is a 6 cyl automatic. Been there for years now. Though tread cautiously. His body kit work may be brilliant BUT as far as his mechanical work goes (that too a swap) BEWARE !!! There are enough horror stories you will find on this forum itself. The famous BMW mess up, MIVEC mess up, GTO mess up & various others that may have chosen to keep quiet. Nothing personal - just don't want fellow members suffering the same fate I & quite a few others did. Best of luck | |
| | #51 |
| BHPian | Guys, why is that putty filler used on the welds? It is supposed to be primed & painted/power-coated. Using the filler in the welds will only enhance the rusting process as it can hold moisture more. I think there is a misconception with the painting/coating people where a putty/metal-paste/filler is considered to be a anti-corrosive material. Actually IT IS NOT! Does anyone seen any of these material used from the factory? Answer is 'NO'! They do a galvanizing after the welds & then prime it, then finally paint it! So why this filler in welds? PS: The basic material in making a filler is clay. Clay / mud is good in retaining moisture. Last edited by tantragna : 15th April 2010 at 10:59. |
| | #52 |
| BHPian | Update : Chassis member painting is completed. Ready for fitting once bushes are replaced. ![]() ![]() ![]() ![]() 3 angle valve cut job, ![]() Head faced (shaved a few microns) to check warpage and to ensure perfect installation on the block. ![]() Porting almost done, little bit of polishing remains. ![]() First of my aftermarket parts to arrive. Not a major one but still, its first to come ![]() ![]() ![]() ![]() More later. |
| | #53 |
| Senior - BHPian | An intercooler, sweet . which turbo are you going for? i hope you are also going for a rear disc conversion, PM me if so i would like to do that as well.Pramod |
| | #54 |
| Newbie Join Date: Mar 2010 Location: Hyderabad
| Hey 'Amey' I've been following the thread and i love your work. This august i will have to decide on a city or a lancer depending on the engine i can procure. Would it be okay if i sent you a PM asking you a few questions? Thanks |
| | #55 | |
| BHPian | Quote:
yes,i have ordered for rear disc conversion and bigger front brakes. | |
| | #56 |
| BHPian | hey, i have absolutely no issues whatsoever if you want to shoot any queries at me,would be glad to answer them to the best of my capacity and knowledge. |
| | #57 |
| BHPian | mm turbo..going to be interesting. Google shows that turbo is evo stock turbo? |
| | #58 |
| BHPian | |
| | #59 |
| Senior - BHPian | |
| | #60 | |
| BHPian Join Date: Feb 2005 Location: Mumbai-India
| Quote:
Similar Threads | ||||
| Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? | mclaren1885 | Modifications & Accessories | 60 | 17th December 2010 22:10 |
| Performance Mods for Premier Padmini using the stock engine | D.V.R | Modifications & Accessories | 14 | 20th April 2010 17:38 |
| performance mods for a lancer... MIVEC engine transplant | drunk.monkey | Modifications & Accessories | 21 | 17th June 2008 13:28 |
| Performance Mods for M-800 Carb Engine | sumeethaldankar | Modifications & Accessories | 3 | 15th May 2007 00:07 |
| Performance Mods. for Lancer | toogoodforyou | Modifications & Accessories | 6 | 7th March 2006 02:00 |
