Old 19th April 2006, 14:51   #46
ksethuram's Avatar
Originally Posted by venkatrx
I am ready to risk melting my headlight, but i cannot risk breaking my head on a highway accident
so i have decided to go for 100/90 with good realy, good holder, and taking break every 2 hrs.....and praying that headlight dome will not melt.
Well said ....
I have driven continiously 8 hrs with my 140/100 bulb. No melting happened. When you are driving in the highway the air flow will cool down your headlights. So need not worry much. Only in city driving when you drive slow make sure that you swith off the lights when waiting in signals.
ksethuram is offline   Reply With Quote
Old 19th April 2006, 14:54   #47
venkatrx's Avatar
Originally Posted by ksethuram
Well said ....
Hey you have driven 8 hrs with 140/100? great whats the model and year of your baleno? is it bs-II or bs-III?
how many times have cops pulled you over
venkatrx is offline   Reply With Quote
Old 19th April 2006, 15:28   #48
ksethuram's Avatar
Sorry, It is not Baleno, it is a Swift. I never show up high beam within city limits and hence never got caught.
Old 15th June 2006, 07:05   #49
Ram
Ram's Avatar
Thanked: 149 Times
Default About driving lights
Hi friends:
I propose to join the Team-BHP Baleno Club, by going in for a Pearl Silver Baleno VXi BS-III in the next couple of weeks.
Of course, brighter head lights and driving lights will be top on the list of add-ons.
Which are the biggest driving lights that will fit the slots in the bumper-apron?
Will the changed headlamp bulb holders (Roots) and aftermarket bulbs affect the Baleno's headlamp levelling system?
Ram
Ram is offline   Reply With Quote
Old 15th June 2006, 13:08   #50
v1p3r's Avatar
Thanked: 27 Times
Ask your dealer to throw in the Baleno's OE fogs as part of the deal.
Old 13th October 2009, 10:18   #51
johy's Avatar
Thanked: 373 Times
Infractions: 0/1 (5)
Default Baleno poor lighting - add Hella foglights or replace headlights?
I got a used 2006 Baleno (B III) recently. Now the light were very poor, one could hardly see on the "sides," most of the light is focused on the road - that too is pretty dim. I don't feel confident to take left/right turns on poorly-lit roads. Once I nearly banged into a rickshaw coming from the right; I just could not see it. It is particularly bad when it is raining or has just rained.
I got the bulbs changed to 100/90 using relays, holders, but the light is still pretty poor. Mechanic said to go for headlight change (which costs around 3.5K for a pair - these are the non-leveling ones, which will work fine for me as I never use the leveling feature).
Another option someone suggested is going for Hella Micro FF which is available for around 3200 or whereabouts for a pair. In Hella there are two variants, one what they said were "fog" lamps and the other "driving" lamps.
What is the best route I should take to make my lights better? Without spending too much. Cause with 3.5K I could do one of the below..
1) Change from stock leveling headlights to a new pair of nonleveling headlights. (3.5K)
OR
2) Change to Hella Micro FF (Fog). (3.4K)
3) Change to Hella Micro FF (Driving). (3.2K)
Suggestions please.
johy is online now   Reply With Quote
Old 13th October 2009, 10:32   #52
rjstyles69's Avatar
Thanked: 795 Times
John most likely that you got a set of fake bulbs. What brand of relay and bulbs have you installed ? I just got a pair of fake Philips 90/100's ,they were dimmer than my stock bulbs. Changed to Mico and the light throw is a better.
Mech's will tell you things to make their pockets heavier at times. I would suggest you 1st check the bulbs and the relay in use.
rjstyles69 is online now   Reply With Quote
Old 13th October 2009, 10:39   #53
johy's Avatar
Thanked: 373 Times
Thanks RJ,
Relay is from Roots and bulbs are Lumax.
Problem is light throw was poor from the beginning, since I acquired this car.
First I had changed bulbs to Phlilips Vision Plus (55/60) - I had a spare pair with me. They are original pieces.. Was not hugely satisfied (same lights work fantastically on my Wagon R). Then went to 90/100 (Lumax), found improvement, but the throw of lights in the sides is not there... seems like reflectors are not working optimally. So now I was wondering what to do... change the headlights themselves or augment the lighting using Hella Micro FF (fog/driving).
Old 13th October 2009, 11:37   #54
Hey John,
I replaced the stocks bulbs in my Baleno with Osram offroading 90/100 (gives a yellowish light) bulbs. The light throw is found quite convincing. Even a hill station trip was okay with this setup.
Has the relay got something to do with ? Gurus please explain.
firestorm is offline   Reply With Quote
Old 13th October 2009, 13:45   #55
shuvc's Avatar
Thanked: 287 Times
Can you post a close up pic of your headlights? In daylight.
A 3 year old car should not have dull reflectors.
Old 13th October 2009, 14:14   #56
Ram
Ram's Avatar
Thanked: 149 Times
Default Go for the Hella Micro FF fog lamps
johy @ Siliguri : Congratulations on your 2006 Bharat-III Baleno.
I have a 2006 Baleno VXi B III, myself.
You say, most of the light is focused on the road and there is not enough spillover on the sides. Well, changing to non-leveling headlamps is not going to change that one bit.
Go for the Hella Micro FF.
Driving lights are designed to focus sharply on the road ahead. They are meant for high speed driving. That won't help your cause either.
Fog lights on the other hand are designed to spill light all over the place
and are deliberately mounted low, so they won't blind you with a wall of illuminated fog nor bother oncoming drivers.
My guess is that the fog lights should do the job for you.
Hope this helps.
Ram
Old 13th October 2009, 14:36   #57
johy's Avatar
Thanked: 373 Times
Shuvc, posting pictures please comment.
Ram. Thanks a lot for the technical information. I hope going for the Micro FF fogs helps.
Old 13th October 2009, 16:57   #58
D3NZ1L's Avatar
JOHNY: are you sure about the 3.5K a PAIR for the non leveling ones??
D3NZ1L is offline   Reply With Quote
Old 13th October 2009, 16:58   #59
johy's Avatar
Thanked: 373 Times
Yep, as per Shuvc; he got his changed some time back.
Old 14th October 2009, 14:44   #60
shuvc's Avatar
Thanked: 287 Times
Reflectors look fine. So better go the fog way. I wanted Micro FF. Tried a few shops. Did not find them, so without taking further pain, went for Lumax. A MASS guy sourced it for me through his contacts.
They were between 3.5 to 4K. Probably 3.7ish with tax. This was 2 years ago. The auto levelling ones were around 12-13K for the pair I think.
poor headlights in Getz !! chandan Technical Stuff 11 5th October 2009 19:42
Turn your headlights off and only use the horn! Rtech Street Experiences 37 13th April 2006 16:04
Good Headlights hellmet Motorbikes 16 16th March 2006 04:05
Info on Baleno Headlights nipun_kr The Indian Car Scene 8 21st August 2005 14:35
