Old 15th October 2009, 12:03   #61
johy's Avatar
Thanked: 373 Times
Infractions: 0/1 (5)
Thanks all of you folks.
Decided to go with Hella Micro FF Fog lights. Will update with results and pics soon.
johy is offline   Reply With Quote
Old 15th October 2009, 13:42   #62
gigy's Avatar
Thanked: 41 Times
Which of the Hella Micro FF Fog lights have you chosen?
Old 15th October 2009, 14:08   #63
johy's Avatar
Thanked: 373 Times
I believe Hella Micro FF itself if the model (Fog ones, not driving ones). Like the ones in the picture in the link. Or are there subvariants?
2814-8830.jpg - 2004,suzuki,baleno
I have placed the order and the lamps should be here soon.
Old 15th October 2009, 15:38   #64
shuvc's Avatar
Thanked: 287 Times
Originally Posted by johy View Post
II have placed the order and the lamps should be here soon.
Would be following the install closely ! I might want to switch too. Please post pics of the install if possible.
How much?
Old 15th October 2009, 15:40   #65
johy's Avatar
Thanked: 373 Times
3200 or whereabouts.
Old 6th June 2016, 19:41   #66
unni246's Avatar
Thanked: 79 Times
Default Re: Baleno Headlights
Guys,
Apologies on opening up a 7 year old thread.
I just bought a 2006 Baleno lxi and as expected not happy with the lighting. The left one is actually a new unit (replaced in 2015) and hence brighter whereas the right is a bit dull, obviously as it's close to 10 years now. And both lamps are with auto levellers.
My query is - Would it be possible to just swap the headlamp unit and retain the leveller motor (as the normal headlamp unit costs less than 2-3K) and connect the motor to the new unit? Sorry if on this
Also looking at options for the best possible fog lamps out there, that could help with some better light spread.
unni246 is offline   Reply With Quote
Old 7th June 2016, 07:41   #67
Ram
Ram's Avatar
Thanked: 149 Times
I need to do this too, as the original Plexiglas headlamp lenses on my 2006 Suzuki Baleno VXi, are slowly vignetting due to microscratches.
New leveling-headlamps for the Baleno are roughly Rs. 13,000 a piece.
I believe that retaining the headlamp leveling unit, while changing only reflector and lens, requires:
(1) Substantial reverse-engineering skills of your own. (I am not saying, I don't have these skills! ;-) )
(2) Appropriate raw material -- new plain headlamp with facility for the leveling unit fitting.
Ram
Ram is offline   (1) Thanks Reply With Quote
Old 26th March 2018, 10:12   #68
unni246's Avatar
Thanked: 79 Times
Ram
[/left]
[/center]
Hi Ram, did you get this done or tested yet?
I managed to survive with the buffing the headlamp glasses, however the right one is quite old now and does have evident and visible micro scratches
poor headlights in Getz !! chandan Technical Stuff 11 5th October 2009 19:42
Turn your headlights off and only use the horn! Rtech Street Experiences 37 13th April 2006 16:04
Good Headlights hellmet Motorbikes 16 16th March 2006 04:05
Info on Baleno Headlights nipun_kr The Indian Car Scene 8 21st August 2005 14:35
