Old 21st April 2010, 22:54   #76
DKG
DKG's Avatar
Thanked: 969 Times
zoomed up the ramp, flew right over the bed and landed straight into the rear glass of the cab!
just like the Bond movies
Originally Posted by smsrini View Post
You may want to consider 2 a/c units
Would prefer to avoid that and have one off the truck that can cool the camper too. Also keep in mind the truck gets used more than the camper through the year. The a/c on the camper would get rusty !
DKG is offline   Reply With Quote
Old 22nd April 2010, 11:40   #77
motomaverick's Avatar
Thanked: 868 Times
Wow! saw this thread yesterday and I am quite amazed at the work. Great work! keep the tempo high.
So whats the current progress on the camper. The same kind of campers are built by overlander i think on the tata 207.
Old 22nd April 2010, 11:43   #78
DKG
DKG's Avatar
Thanked: 969 Times
I need to install insulation and complete the inner skin. Overlander does not make removeable campers from what I understand, also I am doing this at a fraction of what they charge
Old 22nd April 2010, 11:47   #79
absynthguzzler's Avatar
Thanked: 224 Times
If DIY is an option for the HVAC system as well , how bout a "distributor" for the AC ducts ? . You get to keep one compressor yet have the option of channeling the cooling to either cabin.
I'm sure a " T " type of gating should be feasible . A Roofmount assembly from existing vehicles should help in the task .
absynthguzzler is offline   Reply With Quote
Old 22nd April 2010, 11:48   #80
Thanked: 868 Times
Great. I read somewhere back that you are going to use foam that is used by refrigeration trucks. So has this been sourced. pics of the progress would be great.
1 question. before the insulation are you going to complete the water tank?
Yeah! overlander campers are non-detachable.
Old 22nd April 2010, 12:02   #81
DKG
DKG's Avatar
Thanked: 969 Times
Yes I plan on using polyurethane foam which is freely available. I still have a small problem that I need to address. The seams where the outer aluminium sheets meet need to be either welded or sealed together in a manner that inhibits water seepage. Aluminium welding is not easy so I need to consult an expert on how to have it welded. If not then I need to rivet a strip at the seam and seal with silicone before installing the PU panels.
The camper water tank for flush can go in much later. The main tank will be under the truck
Old 22nd April 2010, 16:46   #82
ajay2233's Avatar
My 2 cents,
In my opinion, there needs to be rubber layer/strip of insulation in betwen the rivet bearing strip and the original joint to avoid seepage. Rubber from used vehicle tubes can be used as they can withstand heavy temperatures and they have very high levels of elasticity.
I have a question, Aluminium is a great conductor of heat, how have you planned to insulate the interiors? would like to know more on this.
correct me if i am wrong..
ajay2233 is offline   Reply With Quote
Old 22nd April 2010, 16:56   #83
DKG
DKG's Avatar
Thanked: 969 Times
Good idea, can use that
Plan on using polyurethane foam, roughly about 1.5 inches in thickness. I feel that should reasonably insulate from the heat. The recommendation for PUF thickness in refrigeration trucks is 100 mm. I will have about 40 mm which I feel should be okay for human comfort
Old 22nd April 2010, 17:10   #84
ajay2233's Avatar
PUF is great option.... only now did i happen to go thru the old posts, think it was a redundant question by me....
Coir could also be used... may be the thickness for insulation can be reduced as Coir is dense , but it has its own drawbacks of being heavy and also absorbs moisture... In which ever spot there is a space constraint, Coir can be used.
we have put a layer of coir in our terrace to avoid summer heat.
Old 23rd April 2010, 07:09   #85
Mpower's Avatar
Thanked: 1,687 Times
But keeping the engine idling all night in the middle of a forest for the AC doesn't sound like a good idea.
Old 23rd April 2010, 09:41   #86
DKG
DKG's Avatar
Thanked: 969 Times
Most trips would be during the monsoon and cooler months so a/c really is not a big issue. Its more for highway travelling that one may want to have one for comfort.
Old 23rd April 2010, 15:05   #87
Anandg's Avatar
Thanked: 15 Times
Amazing daring DKG. Kudos to your project. I would like to add following:
1) Design the legs like a spider(w shape). This would give you enough stability in case of uneven roads. look at the borewell digging machines legs.
2) Keep the height low, as higher the head, center of gravity to throw the body out and pull up the truck from the road.
3) Ensure that head of the camper (above a drivers cabin) has a sheet sort of something that aids air dynamics else wind would play a spoil sport.
4) Keep inflatable furniture inside to reduce weight(I saw many on sony TV ate night adverts).
5) Use vinyle sheets to cover the body of the camper so that u can enjoy rainy areas as well.
6) Have a look at the link below. These guys might help:
Caravans; Camper Vans & SUV / MUV Campers Caravan IN;41826 products
Anandg is offline   Reply With Quote
Old 23rd April 2010, 16:54   #88
leadf00t's Avatar
Thanked: 12 Times
Amazing DIY idea DKG. I am all hooked to your project.
Do you have rough sketches as to how to plan to occupy the interiors of the camper.
leadf00t is offline   Reply With Quote
Old 23rd April 2010, 17:37   #89
DKG
DKG's Avatar
Thanked: 969 Times
The front of the cab over will have an acrylic sheet and has an incline. I have intentionally not focused on aerodynamics in the interests of interior comfort
Very interesting, never thought of that !!
That's a great suggestion. You just may have solved my headache of ensuring there's no water seepage. So many commercial trucks have laminated vinyl sides with adverts.
Will try to put some up. Basically two 6 feet adults can sleep comfortably on the cabover bed. An additional two people can sleep on a bed that converts to a 4 or 6 seater depending on how you configure it. You can have a dining/work table in between.
I want to package the kitchen and toilet in such a way that I have cargo space available to carry either luggage or a bike.
Now that I am close to finishing the interiors I will have to finalise and make the toilet and kitchen arrangement
Old 23rd April 2010, 21:55   #90
Anandg's Avatar
Thanked: 15 Times
HI DKG,
Few more:
1) Make the roof retractable--means when camper is moving you can have lever to bring the height of the camper down. It is like the ones you see retractable fancy shades in some shops(that have X type levers) where depending on sunlight the shopkeeper retracts / expands his shade. This would solve your dynamics problem and total area can be gained more when camper is stationary.
2) ensure that the roof of the camper is a flat surface so that you can use it as a base of those portable tents in case you go to area where you cannot camp on ground.
3) Get in touch with AC fabrication companies in your area. They can solve your insulation / heat problem.
4) search net for images interiors of the cabin. Google baba can be of great help in giving ideas.
5) look for birla-yamaha silent generators that run on kerosene. They can solve your electricity problems for sometime in outdoors.
An indian camper anyone? superavi The Indian Car Scene 64 18th May 2017 15:47
Tata Motors completes 60 years of truck building at Jamshedpur Aditya Commercial Vehicles 4 23rd November 2014 11:41
Goodbye to old faithful (MM540) hello to a new friend (Bolero Camper) desigNation 4x4 Vehicles 110 20th August 2014 12:38
French travelers need help in Bombay - Trying to bring camper in to India juva marc Route / Travel Queries 2 10th June 2010 12:46
Truck bumped into my car and ran away! rajushank84 Street Experiences 57 26th March 2010 11:30
