View Poll Results:
0%
Voters: 0. You may not vote on this poll
Old 11th October 2005, 12:41   #1
Default Baleno - Low ground clearence
If 4 people sit in Balano, it often scaps the speed brakers. I have based on the advise of the dealer, got the height raised by putting the spacers.
I would like to know that is this going to affect the suspension of the car and is this the right solution.
Rajesh Jain is offline   Reply With Quote
Old 11th October 2005, 13:37   #2
satan_crazy's Avatar
actually i realized the same thing only recently ... never had 4 people in my car before ... and the other day, the bottom got scraped ... well, we were going over a mountain shaped speed breaker though ... but under normal conditions, if one goes over the speed breakers at reasonable speeds, the bottom shouldn't get scraped. out of curiosity, why would one want to have spacers if the tyres are stock? i think the car is designed properly for stock tyres.
satan_crazy is offline   Reply With Quote
Old 12th October 2005, 20:59   #3
karthik247's Avatar
Thanked: 16 Times
Raising the suspension would affect handling won't it?
Isn't it better to simply upgrade the alloys and tyres?
karthik247 is offline   Reply With Quote
Old 12th October 2005, 21:59   #4
revtech's Avatar
Thanked: 35 Times
yeah raising the suspension would definitly affect handling specially while cornering and at high speeds.
Karthik
how would changing to alloys and better tyres raise or reduce height and more so stop the bottom from scrapping.
rev
revtech is offline   Reply With Quote
Old 12th October 2005, 22:59   #5
karthik247's Avatar
Thanked: 16 Times
I dunno ...it wz a question, not a statement. I just thought gettin bigger alloys would help. i'm stupid
Old 12th October 2005, 23:12   #6
revtech's Avatar
Thanked: 35 Times
oh .bigger alloys will just enhance the look and performance of the car as it will have a smaller side wall which will help while cornering.how ever the ride will become bumpier and if upgraded to a much biggersize , the tyre may even scrape the wall.but theres noy way changing the size of the alloys is going to help the car from scrapping the bottom less often.
rev
Old 13th October 2005, 01:05   #7
binz's Avatar
Thanked: 411 Times
My baleno scraping was the biggest problem i faced on my trip to ooty.THe car fully loaded with 4 adults and luggage scraped every friggin bump.I was following in another car and noticed that the exhaust pipe (either from the cat to the muffler or the expansion cham. to the muff.) is bent downwards.Its like that on all balenos.
My 2 cents
binz
binz is online now   Reply With Quote
Old 13th October 2005, 03:01   #8
revtech's Avatar
Thanked: 35 Times
yeah it is like that on my baleno too.at first i thought it got bent but then realized that it came like that only.any reason why ?? the only reasons i can think of is
1) so that the harmfull gasses coming out from the exhaust go down and not directly into the face of some biker behind or someone standing behind the car
2) the bumpers are body coloured so its bent downwards to prevent the bumper from becoming black due to the deposition of the gases coming out of the exhaust
i know the reasons i have posted are stupid but thats what i thought.so what is the real reason.
Rev
Old 13th October 2005, 22:56   #9
karthik247's Avatar
Thanked: 16 Times
Maybe to just hide the whole exhaust sys
Old 13th October 2005, 23:10   #10
revtech's Avatar
Thanked: 35 Times
if thats the reason then they did a pathetic job as it is very promonent and easily visible.i doubt it was to hide it its not really concealed , its jus bent downwards so i doubt its because of that.
Rev
Old 16th October 2005, 15:14   #11
Thanked: 56 Times
I thought (and have heard) its the soft suspension that causes the scraping when you take a speed breaker faster than you should.
The ground clearance officially is better than or equal to several other cars in India. Stiffening the suspension may help but at the cost of your ride.
Luckily , in Mumbai, where I drive, all non standard and illegal speed breakers are gone.
Ravich is offline   Reply With Quote
Old 16th October 2005, 20:41   #12
Mpower's Avatar
Thanked: 1,682 Times
How much did you raise it by? An inch? Did you get your alignment checked after that.
Old 27th December 2005, 18:00   #13
Thanked: 439 Times
Are you happy with the results after getting the car's suspension raised? Any problems felt while cornering?
directinjection is offline   Reply With Quote
Old 31st December 2005, 12:00   #14
nsbhat's Avatar
My 2 cents
binz
Probably the tailpipe is bent downwards so that if the car is stuck in a flood, the trapped air / exhaust gas will not allow water to enter
nsbhat is offline   Reply With Quote
Old 3rd April 2006, 11:39   #15
venkatrx's Avatar
Default Baleno ground clearance
Hi Guys,
During my long drives of about 700-800 kms my baleno's underbody scraped at 4 places (with 5 passengers). I got the underbody inspected and found the scratches on the following.
1. silencer tail pipe
2. a metal strip
3. catalytic converter
All these looked ok, no major dent, just scraping.
The maruti guys told that they can add 'spacers' and increase the ground clearance. Before I get this done I would to ask two things.
1. poll : if you have got spacer added to improve ground clearance.
2. opionino : what are the drawbacks of adding the spacers?
venkatrx is offline   Reply With Quote
The "Low Mileage" Car Thread! How low is your running? saket77 The Indian Car Scene 135 23rd September 2013 22:51
Repeat EXAMM! The ghost of 1st low vs 2nd low descent haunts us again... and how! Tejas@perioimpl 4x4 Excursions 41 23rd September 2010 14:16
