Old 27th April 2010, 11:24   #1
HAFI's Avatar
Unhappy H&R Springs On Stock Shocks For A Skoda RS
Hey Guys,
As you all know i own a Skoda RS.I have been noticing for a while.Compared to all other Octys only the RS has the rear suspension lifted(may be to make it more aerodynamic).But i find it really awkward as the car looks slanted slightly to the front.
Hence i decided to make it normal without spending much.I called up petes and asked him about the H&R Sports OE Springs.What he told me was that,if i change only the springs the wheel bearing could create problems and shocks also will be non-functional after a while.The springs only cost 18-25k,but including the shocks,it costs around 75 k.
I dont intend to use the car for any track purposes and therefore i dont need such costly suspension.Only thing that i need is to alter the looks of my car.
I need all your suggestions.Should i go in only for the H&R Springs or should i get another set of Skoda Octavia stock Rear Springs.Please do help me with this.......
HAFI is offline   Reply With Quote
Old 27th April 2010, 12:27   #2
pranavt's Avatar
Thanked: 274 Times
If the springs are stiffer than stock, they will kill stock shocks soon. See if you can get the stock shocks revalved, it's an inexpensive way to make them stiff enough to handle stiffer springs.
Old 28th April 2010, 21:57   #3
HAFI's Avatar
what is re-valving of shocks?...and does Petes do that?
Old 29th April 2010, 09:33   #4
NOS Power's Avatar
Thanked: 55 Times
Re-valving is a method to either overhaul or stiffen stock shocks. Its done by replacement of shock oil, oil seals, shock springs etc.
Dont think Pete's will do that. Rather look around at local garage's or shock repair shops. But i dont think revalving will help your cause as you want a lower rear end.
Check with Skoda whether there is a difference in the specs of the rear shocks and/or springs. If so try get the appropriate part from the other Octy's and it should be suffice.
NOS Power is offline   Reply With Quote
Old 29th April 2010, 09:37   #5
Psycho's Avatar
Thanked: 95 Times
Have you thought about raising the front a bit with spacers instead of going through all this hassle of replacing the rear suspension?
Does anyone know if the 1.9 tdi coils will sit on a RS?(I haven't done it but could be the simplest solution)
Old 29th April 2010, 10:11   #6
HAFI's Avatar
I inquired about the octy 1.9 shocks,its a bit better than the atock rs shocks..but don't know whether it could fit the rs,and thats the confusion,the rear springs of octy 1.9 cost around 3k in the local market and in skoda authorized service centers around 10k.
And if it was h&r springs it would have been lot easier for me.I got a deal for used h&r for RS.The price quoted was 15k(only springs) and it looks a stunner.
Old 29th April 2010, 10:25   #7
NOS Power's Avatar
Thanked: 55 Times
@HAFI,
you only need to replace the rear springs with that of the 1.9. And that too it'll be OEM. IF u go for the stiffer springs, you will have to replace all four shocks faster than you can imagine. Considering the prices of shocks for Skoda's i dont think that's something you will want to do.
Old 29th April 2010, 23:04   #8
HAFI's Avatar
@HAFI,
Yeah so that's good huh?...i inquired about the rear springs and it cost only 3k in the local market...will it lower the rear end considerably? ...
Old 30th April 2010, 06:24   #9
16v100bhp's Avatar
What H&R springs are you getting? Sport or race? Race would be too low imo. Sport is comfortable too and easier on the shocks.
Installing performance shocks along with the springs is always better. Else you will decrease the life of the stock shocks significantly but hopefully not quicker than you can save for the sport shocks.
Also, probability is that your current shocks will die before the bearing or the control arms.
If I was you, considering the labor costs in India of doing a suspension overhaul twice, I will give this a try.
16v100bhp is offline   Reply With Quote
Old 30th April 2010, 10:31   #10
PJSPEED's Avatar
If you are lowering the car then you have to change the S-Bar too.If you are running on stock S-Bar it will throw fault code from head lights.
PJ
PJSPEED is offline   Reply With Quote
Old 30th April 2010, 22:45   #11
16v100bhp's Avatar
Originally Posted by PJSPEED View Post
PJ
You should be able to get the leveling sensors re adapted using the COM tool in case there is a code.
Here is a diy on an a4 - clicky
Old 1st May 2010, 10:13   #12
HAFI's Avatar
PJ
does that apply for even stock Octy 1.9 coils?And what is S-Bar?
Old 1st May 2010, 10:15   #13
HAFI's Avatar
I have been offered for a set of Sports OE Springs for 15k.
Old 2nd May 2010, 00:43   #14
16v100bhp's Avatar
So that is 20 + 15 for spring and shock combo?? pretty good deal i guess.
Did you check the price on coilovers?
S-Bar -> Sway bar
Old 5th May 2010, 22:09   #15
HAFI's Avatar
Did you check the price on coil overs?
S-Bar -> Sway bar
Sorry for the late response.I was out of internet connection.
Nope.The shock plus spring combo is offered for 40k.
And is new coil overs necessary for suspension change?
H&R Lowering springs from Germany for my Maruti AStar! Sankar Modifications & Accessories 34 7th August 2014 11:08
Integrating maps & bluetooth with stock audio system of Skoda Laura L&K 2011 Paco In-Car Entertainment 2 13th December 2011 14:06
Skoda Octavia VRS - H&R Springs Modification Query HAFI Modifications & Accessories 2 2nd November 2011 07:16
SKODA VRS lowering springs any problems Frank Zappa Technical Stuff 1 25th June 2010 16:32
