Old 8th May 2010, 00:09   #1
Default High beam halogen for Skoda Superb V6 TDI
I have a slight problem, whenever I use full beam the xenon gives out a bluish white light and the halogen(full beam bulb) gives out a yellow light which cause two different types of colors from each headlight.
Please can anyone suggest me what bulb to change to? Keeping the phrase in mind "Brighter the better".
indra_slk is offline   Reply With Quote
Old 8th May 2010, 01:41   #2
Akshay1234's Avatar
Thanked: 6,670 Times
the superb has projectors for high beam also. im surprised theyre not xenon too. if you put normal white bulbs in the high beam the light given out will be a better match for the low beam but the beam wont be as good as yellow. of course xenons will be a better choice but then who wants to mess with skoda electricals. i suggest you leave it how it is.
Old 30th August 2015, 01:32   #3
somebodystopme's Avatar
Thanked: 15 Times
Default Re: High beam halogen for Skoda Superb V6 TDI
Hi I have similar problem with my Superb's Headlamp. First the low beam is really too low, much lower than my Punto's Halogen. Anyway will have to live with it but I want to have xenons for high beam, halogen looks plain Ugly when the lights get mixed up. How can it be done? Please guide.
somebodystopme is offline   Reply With Quote
Old 17th October 2015, 08:47   #4
Thanked: 13 Times
Hi, I am new to the forum and this is my first message on Team BHP. While Superb's xenon is a bi xenon, but when the high beam is switched on, a pair of halogens also light up giving the yellow light as against the white given out by the projectors. I had two questions to ask -
1. What is the colour temperature of the bi-xenons for skoda superb (mine is a 2010 model)?
2. Any suggestions on which bulbs to put in as the replacements of the halogens so that the car doesn't throw up any error messages?
Thanks.
AR123 is offline   Reply With Quote
Old 17th October 2015, 19:08   #5
Ricci's Avatar
Thanked: 920 Times
Thanks.
1. OEM HID is almost always 4300k, this is considered the best in terms of visibility and whiteness with less glare compared to higher kelvin kits sold aftermarket.
2. If matching the color is the intent, Try Crystal Vision (4300k) or Diamond Vision (5000k) , but these bulbs have color filters on them to produce the bluer/whiter light , which means more glare and LESS light. All other good bulbs ( that focus on illumination mainly and not color) are more yellowish-white compared to HID, though whiter than stock halogens.
Ricci is offline   (2) Thanks Reply With Quote
Old 22nd October 2015, 19:30   #6
Thanked: 13 Times
Thanks, Ricci.
Are these Crystal Vision lamps available in CANBUS compliant versions so that the car doesn't throw up error messages with these on? I believe that the high beam bulb is H3 for Superb.
I got the day time running lamps changed to Morimoto LEDs (5500 K) which have vastly improved the way the car looks. Also these don't show any error messages. The day time running lamps are W5W. Am very tempted to go the LED way for the high beams as well but not sure if there are LED solutions for H3 size which would offer better light and less glare while being CANBUS compliant.
AR123 is offline   (1) Thanks Reply With Quote
Old 22nd October 2015, 21:19   #7
Ricci's Avatar
Thanked: 920 Times
Thanks, Ricci.
Crystal Vision/Diamond Vision/Xtreme Power are all in standard wattage for their type ( H4 60/55W , H1 55W , H7 55W ), they are intended as plug and play replacements for the standard OEM fitment bulbs, so worries about CANBUS or wiring.
H3 is a fog lamp application, 35W. If it's in the high/low beam, that is a big surprise. High/low beam halogens are either H1, H7, H9 or H11 , or the US equivalents. Check in your car manual, it will likely be H7 or H11.
LED aftermarket kits leave a lot to be desired. The better/effective ones come as a LED+reflector kit complete as auxiliary lights, the drop-in replacements for the halogen bulbs aren't all that good for high beams - they tend to lack range.
Ricci is offline   (1) Thanks Reply With Quote
Replacing a Superb - BMW GT, Mercedes C220 or 3rd-gen Skoda Superb? Epic Luxury, Imports & Niche 52 24th December 2016 22:41
Skoda unveils updated Superb and Superb Combi in Europe Abhinav667 The International Automotive Scene 59 15th January 2014 21:17
BMW Nightvision & High Beam Assist karthik247 The International Automotive Scene 13 27th February 2010 19:14
