Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 18th October 2005, 11:14   #1 (permalink)
Default Retractable rear sun screens
As an alternative to sunfilm i'm interested to know about retractable screens for my NHC.
If any one in Bangalore is already using it, can you point me to any place where i can pick it up ?
Is there anything bad about using this screen? in terms of visibility to the driver?...obviously.. during the day!!
Neel is offline   Reply With Quote
Old 18th October 2005, 12:29   #2 (permalink)
My C220 has a factory fitted rear retractable screen, and it is fabulous. Visibility is not at all an issue whether day or night. And this is with dark tints. The cabin cools up significantly faster with the screen up.
However, I wouldnt recommend an after-market fitment for the rear sunscreen.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 18th October 2005, 15:24   #3 (permalink)
what is the best alternative to sunfilm?? I have seen a few vacum based plastic's that do the job....but they look sick...
I just walked out and asked about the retracable screen at Hot Tracks...he said it would cost Rs. 1100/-.....
I have seen one on a Coroalla, not sure if it is standard Eq?
Neel
Old 18th October 2005, 19:02   #4 (permalink)
aah78's Avatar
Post rear sun-blind
Neel:
what car are you planning to do this project on? depending on whether an electric sun blind is available for your particular car model, it'll be a simpler or tedious affair. are you planning to do the fixing yourself or get it done from a shop?
if you have a hatch-back, then this project isn't going to work, not without extensive modifications, and will turn out to be very expensive.
retro-fitting an electric sun blind isn't a bolt-on affair, even if the toy is available for your car. modifications need to be made - mechanical and electrical - and a lot of money will need to be spent.
modifications range from simple removal of the rear-seats and C-pillar trim, to re-desigining the rear shelf to compensate for the weight of the blind assembly (the assembly is very heavy).
electrical connections, however, will not be very complicated. expect a lot of trial and error runs though.
i've worked on this project earlier but haven't found the time to complete it yet though.
let me know if you wish to proceed - i'll try to help you out.
my recommendations - putting it bluntly - if your car isn't already fitted with one, then don't do it. it'll never work like you wan't it to and it'll break down all the time.
ad
ps. the same project would be much much simpler for the mechanical window sun-blinds but you'll need a good fabricator to design the thing for you. if you find one, you're all set.
__________________
Ein bißchen Frieden
aah78 is offline   Reply With Quote
Old 3rd May 2007, 01:38   #5 (permalink)
Please help this thread rejuvenate, i am also in search of such a thing after seeing it in a corolla.
swathyd is offline   Reply With Quote
Old 4th May 2007, 08:46   #6 (permalink)
rdas45's Avatar
If your living in Bombay, I know one shop which has the electronic one. Its the 1st shop in AUTO LANE, opera house... Next an energry milk stall... I cant remember the name... But hes the wholesaler in the market.. and I have seen it at this shop....
rdas45 is offline   Reply With Quote
Old 4th May 2007, 12:14   #7 (permalink)
Today i went to a shop at tvpm, they show me a retractable rear sunscreen. It is manual, and it costs rs 650. They informed me that it can be only fitted with sedan s and not estates, so i have to take my vehicle to check it.
Thread Tools
Retractable ORVM's The_Warrior Technical Stuff 7 18th September 2008 00:51
sun screen to help while parking under direct sun sathya_nars Modifications & Accessories 12 20th May 2008 20:14
F1 on big screens where??? paras211 Shifting gears 2 13th May 2007 11:18
LCD screens and how to conect?? chaxy Ask the Gurus 38 7th August 2006 19:18
Car Entertainment + Screens indizen Ask the Gurus 2 31st May 2005 12:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
