Old 12th May 2010, 14:12   #16
Thanked: 93 Times
@alpha:Please look at my earlier post#8 where I have replied to planetrocker.The strobes are mostly for the time when the car is stationary.I dont intend drive with the strobes on in the traffic.
octane1002 is offline   Reply With Quote
Old 12th May 2010, 15:39   #17
thedreamcatcher's Avatar
Thanked: 62 Times
@Octane, no doubt something like a pulsar enclosure, will not have as much reflection , than what can come from a head lamp enclosure. Stobes outside, like behind the grill etc, is of no use at all. I tried it and it looked bad, Felt like the car was sparking or something, and I actually had a guy once stopping me, saying 'saar, engine see spark nikhal raha he'
Strobes in a headlight Enc is the best job. So go for it.
Hell no to Led Strips, Saw one on a Laura yesterday and I felt like playing crash and burn with him
thedreamcatcher is offline   Reply With Quote
Old 13th May 2010, 09:11   #18
Thanked: 93 Times
@dreamcatcher:Go for it I will.The headlamp assembly would be the best place as the finish would be uncluttered.Jus hope they are a direct fit to the parklamp socket.
Old 13th May 2010, 10:17   #19
Ricky_63's Avatar
Thanked: 394 Times
Messing with the OE headlight unit is not at all advisable. As some other members have pointed out, the stock headlamps on the RS are expensive, best not to take a chance. Just my POV. Yes if they are a direct fit into the parking light socket, then that should be relatively safer.
Old 13th May 2010, 12:04   #20
Thanked: 93 Times
@ricky63:Thanx man.So as of now, the Options for the Strobes Install is like this:
O#1:Check if the strobes are a direct fit to the parking light socket.If it is, installation complete.If not, go to O#2.But replaced strobe light to be controlled through the seperate module already supplied to ensure that they are on only when desired and not when driving with Xenons or Headlights.
O#2:Source an empty reflector housing(not keen on bike indicator reflectors, so what else then?Are cheap pear shaped rectangular fog lamp reflectors once popular on Zens,m800s,Omnis a good option??) and mount it behind the grille.Alternative to this is O#3.
O#3: Drill a hole in the seperate Indicator Assy. next to the H/L Assy., since that housing is relatively cheap.(To me this is also a good option since the risk involved is comparitively less)
What say guys?Any other suggestions??
Eicher introduces 3 reefer trucks - Pro 1059XP, Pro 1100XP and Pro 6025 Aditya Commercial Vehicles 0 22nd December 2015 18:01
Eicher launches Pro 8031XM, displays Pro 6025T trucks at EXCON 2015 Aditya Commercial Vehicles 0 26th November 2015 14:40
Strobe Lights libre sito Modifications & Accessories 241 6th December 2008 16:21
Strobe Lights passion4cars Modifications & Accessories 67 25th May 2008 15:47
