Old 12th May 2010, 16:33   #16
jocreative's Avatar
ahhh... three screws... did not know about that. I have seen these videos earlier and knew that they should be at a straight line... thats why I had a gut feeling that something is off somewhere. The three screws should be the answer. Where are they located by default?
jocreative is offline   Reply With Quote
Old 12th May 2010, 16:36   #17
ElantraGT's Avatar
Thats a neat looking projector for Altis. Except for the side visors I feel the altis is really looking Hot. Do your tire upgrade with a nice set of alloys.
ElantraGT is offline   Reply With Quote
Old 12th May 2010, 16:55   #18
naveen.raju's Avatar
Thanked: 3,725 Times
These should be behind the projector assembly. For the swift projectors (Old model), this was a common problem. Adjusting these screws should solve the problem and you should attain the perfect cutoff.
naveen.raju is offline   Reply With Quote
Old 12th May 2010, 17:02   #19
jocreative's Avatar
@ElantraGT - Thanks. Yeh the side visors is a love it or hate it deal. I like the narrow window look it gives.
@naveen.raju - Have to check on that when I get home. I just pm'ed you with a pic of the rear. Sorry for the trouble
Old 12th May 2010, 20:54   #20
jocreative's Avatar
Here are the low and high shots of the lights on a wall 10ft away.
Its taken through my mobile so the quality is quite low. I think these need a lot of tune up...
Modded Toyota Corolla Altis- Projector CCFL Angel Eyes, Spoilers, Side Visor-imag0202.jpg
Modded Toyota Corolla Altis- Projector CCFL Angel Eyes, Spoilers, Side Visor-imag0203.jpg
Old 12th May 2010, 22:27   #21
jocreative's Avatar
Well I did a bit of reading and found out that these things need to be adjusted from the behind! There are screws that would move them either up-down diagonally, or up-down and left right. I have to check and see how these work for my lights.
Also they say you are not supposed to have hot spots and they are supposed to be spread evenly across and as you can see... these have ridiculous hotspots!! And the high beam is aimed quite high!
Most of these guys got them right after trial and error of removing and re-adjusting the screws like 10-20 times... some even had to remove the bumpers!!
Fingers crossed....hope its something I can fix myself.
Old 12th May 2010, 23:02   #22
jkdas's Avatar
Thanked: 1,436 Times
Makes a big difference in the looks! Looks great IMHO; more Carmyish too.
Drooled at the pix atleast 5 times in the last 2 minutes!
Do post more pix. Would also love to see the DVD player in action.
Old 12th May 2010, 23:04   #23
jocreative's Avatar
LOL... Thanks!
Planing on taking a video soon, after tuning up the headlights. Will capture the video player then too.
BTW, keep me posted on the TVM meets
Old 13th May 2010, 00:29   #24
Thanked: 152 Times
There is a way you make the car MUCH MUCH better. Paint the Chrome on the Grille and the Rear Chrome Garnish Black.
Cyrus43 is offline   Reply With Quote
Old 13th May 2010, 00:47   #25
jocreative's Avatar
Yep, will marinate on the thought too
Old 13th May 2010, 01:49   #26
abk
abk's Avatar
Thanked: 9 Times
jocreative, the headlamp assembly is wow!
Regarding your concern and doubt about the headlight beam pattern - i think you have got the correct beam pattern. Though I must confess I do not know if HID is supposed to follow the same beam pattern as incandescent bulbs. If it is supposed to, then this is what the low beam pattern is designed for and should appear. Also, bear in mind, one of the headlamps would be a long throw & the other (driver side) would be short but wide. This further prevents dazzling oncoming driver even whilst on the low beam.
abk is offline   Reply With Quote
Old 13th May 2010, 01:59   #27
jocreative's Avatar
@abk... so no adjustments need to be done?
Old 13th May 2010, 02:20   #28
Sahil's Avatar
Thanked: 2,712 Times
Nice!!
Where did you get the lip spoiler on the trunk from ? Price?
Old 13th May 2010, 02:28   #29
jocreative's Avatar
@sahil - Ordered them from ebay too. Seller - bmwchop168
Old 13th May 2010, 03:30   #30
iamback's Avatar
What about adding some undercar neons or LED's ???
iamback is offline   Reply With Quote
My Modded Corolla (Angel Eyes,TRD grill & more) karan561 Modifications & Accessories 171 4th March 2015 18:10
Difference between Xenon-Angel Eyes-HID-Projector headlamps Abhi_Automobile Modifications & Accessories 27 11th October 2011 21:25
Corolla Mods - Eibach Springs, Xenon HIDs and Angel Eye Projector Headlights novice Modifications & Accessories 14 2nd July 2011 03:46
Projector Headlamps/ Angel Eyes for Logan ashutoshb Modifications & Accessories 43 18th January 2009 09:20
Angel Eye projector headlamps for Corolla Altis Ym-enjn Modifications & Accessories 2 6th December 2008 17:42
