Old 21st September 2011, 10:12   #226
prince85's Avatar
Thanked: 117 Times
Default Re: Flippy Keys
Originally Posted by lavish_n View Post
The programming steps which was given to me for my SX4 was:
1. Unlock the car using your old remote.
2. Keep the driver side door open during the programming process
3. Insert the key into the ignition key slot & turn the key towards ON (do not start the car)
4. Press the Alarm switch once & then second time keep it pressed till you hear a beep sound. The Alarm switch will be found next to your headlamp leveling switch.
5. Now press the lock/unlock button on the new flip remote.
6. You can remove the key from the ignition slot to end the programming.
7. The new remote should now allow you to lock/unlock the car.
8. Check if both the remotes are working.
I couldn't get the beep for the first two tries. It worked on the third try.
Excellent! Congrats buddy for a fully functioning flippy key for your sx4. Could you put up pics of the same!
cheers
prince85 is offline   Reply With Quote
Old 21st September 2011, 10:29   #227
lavish_n's Avatar
Thanked: 18 Times
cheers
Some pics of the flip key. The quality is good. Not sure how long it will last.
lavish_n is offline   (1) Thanks Reply With Quote
Old 2nd October 2011, 00:59   #228
Thanked: 15 Times
I also got flip key for my Chevy beat from Harison, my overall experience was very good with them. The quality is nice, itís been around 6 months, no issue so far. I did the programming myself with help of the manual which comes with the security system, took me 4-5 attempts to do so.
raviacc2825 is offline   Reply With Quote
Old 1st December 2011, 16:48   #229
k2max6's Avatar
Thanked: 130 Times
I am planning to get one for my swift.
Any idea if this can be done anywhere in Delhi/NCR .
Otherwise i'll have to send my keys all the way to Panchkula.
k2max6 is offline   Reply With Quote
Old 2nd December 2011, 02:18   #230
Thanked: 15 Times
Send it to Panchkula, the guy know his work. I also searched for options in Delhi before sending it to him but all in vain.
Old 2nd December 2011, 09:36   #231
james's Avatar
Thanked: 541 Times
I emailed Harison thrice a coupla months ago regarding a flippy conversion but in vain. The least they could've done was email back stating they cant do the job. Im quite disappointed with them!
james is offline   Reply With Quote
Old 2nd December 2011, 13:07   #232
k2max6's Avatar
Thanked: 130 Times
I also mailed them and then informed them about the mail via phone. I got prompt response. (By Evening, imo they generally access the mails in the evening only)
Till Now Everything seems fine to me
Sending the keys today.Will get it back by monday here.Surely post the experience then.
k2max6 is offline   (1) Thanks Reply With Quote
Old 7th December 2011, 21:22   #233
k2max6's Avatar
Thanked: 130 Times
Got the Flip Key for my Swift Today
Works great ! Quality is good.Costed Rs.1800 + Courier
Here are some pics !
Would have looked better without the 'Exclusive' written.
A Size Comparo with My other Autocop Remote
Old 7th December 2011, 23:29   #234
scopriobharath's Avatar
Thanked: 1,255 Times
could you kindly repost the pics. The pics are not visible.
scopriobharath is offline   Reply With Quote
Old 7th December 2011, 23:30   #235
sajands's Avatar
Thanked: 142 Times
Hi k2max6,
Congrats on the keys, can we have the pics that i guess you forgot to attach
-Sajan
sajands is offline   Reply With Quote
Old 7th December 2011, 23:37   #236
k2max6's Avatar
Thanked: 130 Times
Originally Posted by sajands View Post
Hi k2max6,
-Sajan
They were showing on my system earlier but somehow disappeared
Old 8th December 2011, 15:06   #237
Thanked: 120 Times
Can anyone suggest if this can be done on any Maruti 800? Mine is an SS80
fx45 is offline   Reply With Quote
Old 8th December 2011, 18:42   #238
Thanked: 93 Times
Of course. The SS80 key is non RFID one. You can purchase a fob online & simply ask the local keymaker to remove the key blade from the existing fob & install it into a flip key fob. You can also get a duplicate key made for testing if you don't want to take chances with your original one. Good luck
JustCause is offline   Reply With Quote
Old 8th December 2011, 20:12   #239
k2max6's Avatar
Thanked: 130 Times
Yes it can be done. Do you have keyless entry in your car or only want the flip key without functioning lock/unlock buttons ?
As far as the key is concerned your original key would not be used.A duplicate would be made according to key fob and installed in it.
Since you don't have the RFID key,your key wont be cut.
Old 8th December 2011, 20:37   #240
SPEEDY_RACER's Avatar
Thanked: 170 Times
Hi Guys,
any one knows where can i get the flip keys for my safari.
currently i have the normal key and remote lock for my drive, but can i enable the Remote locks in the flop keys?
help required and appreciated.
SPEEDY_RACER is offline   Reply With Quote
Stylish Flippy Keys, Locksmith & Keyfob Repairs - Hitesh Mehta (Ghaziabad) Ace F355 Delhi NCR 14 22nd December 2016 16:53
DIY: Flippy Key paragsachania DIY - Do it yourself 59 23rd February 2016 10:52
Original remote's chipboard doesn't fit in flippy key shell. Now what? Soumyajit9 Technical Stuff 6 16th March 2015 14:48
Duplicate Keys z klasse Shifting gears 1 2nd April 2006 14:04
Locked the keys in the car bruce Technical Stuff 40 24th October 2005 01:18
