Old 3rd January 2014, 23:41   #46
ashkamath's Avatar
Thanked: 318 Times
Default Re: Best Windshield Washer Fluid?
I have been using the 'WAXPOL' Wind shield Concentrate for my car windshield. A 200 ML bottle is priced at around Rs. 60/-. Every time I refill my windscreen water reservoir, I add a teaspoon of the concentrate and I am pretty happy with the outcome.
And also every time I fill diesel in my car at my regular BP pump, I avail their services (clean both the front / rear windscreens). Sometimes If I am passing by the pump and the windscreen is dirty, I just drive in there for getting the windscreens cleaned and they do it with a smile. I use the windscreen washing mechanism mostly during long drives outside city.
ashkamath is offline   Reply With Quote
Old 3rd January 2014, 23:46   #47
SunnyBoi's Avatar
Thanked: 2,829 Times
I've been using 1 rupee shampoo packets since some time for Washer fluid. Recently switched to Meguiars NXT Car wash since I got something better for the body. Does the job beautifully and much better than shampoo.
Best part is when I have bird poo on the windscreen, I spray, wait 10 seconds for the poo to soak in the fluid and wipe. Comes off clean every time!
SunnyBoi is offline   Reply With Quote
Old 4th January 2014, 09:21   #48
sachinj12's Avatar
Thanked: 162 Times
Does it have the ability to remove oil film and grime? I don't think so
Haven't faced any problems in the last 4 years-windshield becomes clean. So I safely presume it does the job
It has the ability to moisturise the windshield
Yeah, the windshield is silky smooth to touch
sachinj12 is offline   Reply With Quote
Old 4th January 2014, 11:13   #49
sagarpadaki's Avatar
Thanked: 1,328 Times
That's good to hear. Which baby shampoo in particular are you using? There are so many in the market
sagarpadaki is online now   Reply With Quote
Old 5th January 2014, 11:28   #50
sachinj12's Avatar
Thanked: 162 Times
Johnson's baby shampoo
sachinj12 is offline   (1) Thanks Reply With Quote
Old 5th January 2014, 18:48   #51
stuntfreak's Avatar
Thanked: 463 Times
Guys pls avoid the use of detergent or shampoo. In the long run they clog and damage the washer motor. Use a windshield wash liq that you get. Or Colin if you want a cheaper option.
stuntfreak is offline   Reply With Quote
Old 5th January 2014, 18:57   #52
Thanked: 14,310 Times
I have been using the Screen wash concentrate from Maruti.
Part No.: 99000 M 99027
MRP: Rs 15
Quantity: 50 ml
I mix this is concentrate in 1 litre water then pour it into the washer bottle.
Anurag.
a4anurag is online now   Reply With Quote
Old 5th January 2014, 19:25   #53
MRP: Rs 15
Quantity: 50 ml
Anurag.
Is that the recommended dilution?
Old 5th January 2014, 21:12   #54
Yes,
Have been following this from 4 years.
Please finger the attached image of the Screen Wash Concentrate Sachet.
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 5th January 2014, 22:03   #55
Yes,
Anurag.
How well does it do it's job? Does it clean well? Bird poop oil film etc?
Old 5th January 2014, 22:49   #56
Does is job well. No issues since I have started using it. It is also depending on the wiper blades condition.
Dried up stuff (Bird poop, dead insects with blood stains) does take a two or three washer jets but normal dirt is off in one stroke.
Anurag.
Old 5th January 2014, 23:03   #57
sachinj12's Avatar
Thanked: 162 Times
Anurag.
If there is dried up poop/sap from plant, I always prefer removing them with a paper or cloth with water being poured from a mug. I would not advice using the wipers on dried poop/plant sap. I accidentally ran my wipers once and have long scratches on my wind-shield . I'm lucky that its not in my field of view.
Old 5th January 2014, 23:15   #58
If there is dried up poop/sap from plant, I always prefer removing them with a paper or cloth with water being poured from a mug. I would not advice using the wipers on dried poop/plant sap. I accidentally ran my wipers once and have long scratches on my wind-shield. I'm lucky that its not in my field of view.
You are right Sachin but what i meant the same if the quantity of these droppings etc are more I manually clean them post which I use the wipers.
Anurag.
Old 6th January 2014, 16:24   #59
fine69's Avatar
Thanked: 877 Times
Compared to plain water, a shampoo/car wash mixed with water is definitely better. However, at times, it does clog the openings. The solution to that is that whenever I'm mixing the car wash liquid in water (I use Amway's car wash) I ensure that I run it at least once or twice a week.
I've used it on a lot of long dusty drives to Spiti / Rajasthan and it gets rid of all sorts of insect stains / dirt / tree sap stains. I carry the car wash in the backpocket of my seat and use just about less than a teaspoonful with ~2.5-3 litre of water and have never felt the need for any other type of windscreen wash fluid.
fine69 is offline   Reply With Quote
Old 7th January 2014, 23:52   #60
Thanked: 189 Times
Waxpol concentrate, 200ml bottle for Rs.65 works out to be the cheapest of all and effective too.
Another product by Motomax, Rs.30/- per sachet gives a nice fragrance when the windshield washer is used when the AC is on fresh air mode.
Even the company recommends using the washer every now and then
I am using this currently and the fragrance is very strong.
interc00led is offline   Reply With Quote
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Windshield Washer nozzle upgrade for Esteem/Zen amalji Modifications & Accessories 25 20th August 2016 20:36
DIY: Replacing the windshield washer pipe (Tata Nano) honeybee DIY - Do it yourself 0 29th September 2013 12:04
