Old 25th May 2014, 22:53   #76
fazonater1911's Avatar
Thanked: 52 Times
Default Re: Best Windshield Washer Fluid?
Originally Posted by hrman View Post
Do try to get the larger capacity Sonax bottle. I think it is 250 ML and costs in the region of Rs.350. Will last about 10 times longer than the small bottle, and costs about 4 times. Should be a better option for you, considering you spend almost 1000 bucks per annum.
I got mine from Tyre empire on Varthur road, but it should be available at Shell pumps, Shopping malls or good automotive shops.
On Snapdeal the Sonax clear view 250ml costs Rs86. So aren't the Shell people overcharging? Or is it the same product. Hrman can you please confirm whether its the same product in the below link?
http://www.snapdeal.com/product/sona...e-250ml/678683
Thanks in advance
fazonater1911 is offline   Reply With Quote
Old 25th May 2014, 23:00   #77
100kmph's Avatar
Thanked: 92 Times
Clinic plus shampoo sachets @ Re.1 worked good and fine for 5 years on our A-Star.
A showroom driver said about the shampoo.
I had once bought a washer fluid from a car accessory shop for 120 bucks which hardened the wiper blades within a month. Then we reverted back to the cheap and effective clinic plus.
100kmph is offline   (1) Thanks Reply With Quote
Old 25th May 2014, 23:23   #78
lapis_lazuli's Avatar
Thanked: 449 Times
Thanks in advance
Its for the 25ml. It is a misprint and they will never fulfill the order, finally offering a refund. The 250ml is much costlier, MRP being in the tune of 350INR.
lapis_lazuli is offline   (1) Thanks Reply With Quote
Old 26th May 2014, 09:05   #79
ank.nsit's Avatar
Thanked: 164 Times
Which brand was the washer fluid?
When I tried Clinic plus shampoo in my santro, the water spraying holes use to block like crazy. So tried the Maruti washer fluid & ever since the clogging never occurred & the washer fluid works better than the shampoo in cleaning.
And I did not find any hardening of wiper blades either.
ank.nsit is offline   Reply With Quote
Old 6th September 2014, 16:35   #80
Sushubh's Avatar
I have used both Honda made Fluid and Sonax. In my experience, Sonax wins hands down. I suffered from fogging issues with Honda Fluid on highways and noticed slight distortion to oncoming traffic lights. With Sonax, didnt experience these issues at all.
The key is to get the ratio right, i dont dump the fluid and add water to the reservoir, i premix the exact ratio and add this premix into the reservoir. The effect of sonax will be noticeable when the entire reservoir gets empty and you refill it with Sonax premix.
Sushubh is offline   Reply With Quote
Old 14th January 2015, 19:47   #81
sukhoi30's Avatar
Thanked: 395 Times
I had recently parked my vehicle near some place where some building was being painted. Upon return, I found that a few drops of paint has dropped on my car's windshield. Any idea, how to clean this? I don't want to use thinner as I fear it might damage the glass.
Anything else that I can try?
sukhoi30 is offline   Reply With Quote
Old 14th January 2015, 20:16   #82
shifu's Avatar
Thanked: 386 Times
You can use clay to remove those drops.
shifu is offline   Reply With Quote
Old 14th January 2015, 21:03   #83
sukhoi30's Avatar
Thanked: 395 Times
The paint spots have dried up now. The clay could cause scratches if I try on the glass, right?
Old 14th January 2015, 22:02   #84
SunnyBoi's Avatar
Thanked: 2,829 Times
Using a clay will not scratch glass. Thinner will not affect glass too.
SunnyBoi is offline   (2) Thanks Reply With Quote
Old 17th April 2015, 22:21   #85
Gannu_1's Avatar
Thanked: 10,427 Times
Got this concentrate from the VW service center today:
Cost me Rs. 310. Just a couple of capfuls for the whole tank. Smells like Listerine.
Gannu_1 is offline   (2) Thanks Reply With Quote
Old 18th April 2015, 08:12   #86
Sheel's Avatar
Thanked: 5,586 Times
I have been using Amway's car wash shampoo. Around 20-30 ml for the tank & rest with water. Works really good.
I have the habit of using too much wash-wipe, so concentrates by Ford, VW will turn out to be expensive :|
Old 18th April 2015, 13:29   #87
Grr7's Avatar
Thanked: 190 Times
Glass is amongst the most non-reactive materials. Thats why most laboratories uses glass ware for storing most notorious chemicals(including all strong acids).
So, you can freely use acetone/thinner to clean the glass surface. However, make sure that acetone/thinner is used in minuscule amounts(preferably a clean cloth dipped with acetone) so that it should not come in contact with the paint/plastic or else the thinner may leave nice irreversible marks on plastic and paint.
Grr7 is offline   (1) Thanks Reply With Quote
Old 22nd May 2015, 10:54   #88
Thanked: 41 Times
Attachment 1361817
Attachment 1361818
Fairly certain that what you''ve bought is primarily a winter anti-freeze concentrate. You're meant to buy the G-052-162-A2 for normal use.
RoadTrippin is offline   Reply With Quote
Old 22nd May 2015, 11:02   #89
Gannu_1's Avatar
The autobox transmission fluid?
No thanks, I'll stick with the one I've got. Have got satisfactory results so far.
Old 22nd May 2015, 11:05   #90
Thanked: 14,356 Times
Any feedback regarding Proklear windshield wash concentrate?
I am currently using the washer solution given by MASS. No complaints though, just want to try something different.
Came across this Proklear. Want to know before I purchase it.
a4anurag is online now   Reply With Quote
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Windshield Washer nozzle upgrade for Esteem/Zen amalji Modifications & Accessories 25 20th August 2016 20:36
DIY: Replacing the windshield washer pipe (Tata Nano) honeybee DIY - Do it yourself 0 29th September 2013 12:04
