Old 20th June 2015, 10:06   #106
Default Re: Best Windshield Washer Fluid?
I think the best possible way is to dilute the solution into required quantity of de-mineralized/distilled water(battery water), which lacks all micro ingredients(good and bad).
This could prevent the mechanical/metal parts in contact with the mix to stay good in there life.
sulivan is offline   Reply With Quote
Old 4th August 2015, 09:43   #107
sunilyk's Avatar
Thanked: 13 Times
Tried Proklear. The first wipe itself did a wonderful job. I haven't seen my windshield as clean as this before. It’s a magic of only 5 ml for the entire tank. Quite economical and very effective. It seems to be very good on wipers as well.
Mod Note : Please do NOT cut-copy-paste text from other word processors (MS Word etc.). That results in a formatting error on our Forum.
Click here to know how to remove FONT Tags from your post (Removing [FONT] [SIZE] and [COLOR] tags from your post).
Going forward, do keep in mind that it's best to type directly into Team-BHP.
Last edited by Gannu_1 : 4th August 2015 at 11:23. Reason: Please refer the note posted above.
sunilyk is offline   Reply With Quote
Old 4th August 2015, 10:21   #108
comfortablynumb's Avatar
Thanked: 917 Times
Where did you buy it from and for how much?
Cheers,
Vikram
comfortablynumb is offline   Reply With Quote
Old 4th August 2015, 10:32   #109
sunilyk's Avatar
Thanked: 13 Times
Cheers,
Vikram
From Flipkart. Rs.199 for 250ml. The product name is Proklear Prkwwc liquid vehicle glass cleaner.
sunilyk is offline   (2) Thanks Reply With Quote
Old 4th August 2015, 11:21   #110
MSC
MSC's Avatar
Thanked: 102 Times
Easiest mix for windscreen washer.
Any of liquid dish washers like dettol or pril or vim mixed with water in ratio 1:10.
MSC is offline   Reply With Quote
Old 4th August 2015, 17:01   #111
Thanked: 46 Times
Are you sure you about the ratio? It means 100ml per litre of water!
I have also used pril liquid, about 5-6 ml in a litre of water and that works OK.
But I feel that products formulated for this specific purpose should work better.
Recently, I got MGA branded sachets costing Rs 15 each, which are working fine.
anuragn is offline   Reply With Quote
Old 4th August 2015, 17:40   #112
iamahunter's Avatar
Thanked: 441 Times
I use Collin with some old expired shampoo. Mix these well with water.
Not much quantity needed as well.
Cheap and gives a clean swipe to the glass. Really happy with it.
iamahunter is offline   Reply With Quote
Old 5th August 2015, 07:06   #113
itwasntme's Avatar
Thanked: 1,419 Times
Bought a Proklear windscreen washing fluid off Flipkart to try it. Have always used Sonax which is wonderful. Will report how it works.
itwasntme is offline   Reply With Quote
Old 6th August 2015, 17:36   #114
themonster's Avatar
Thanked: 93 Times
Hello everyone !!
I use Sonax Clear View Windshield Washer Concentrate since the last 1 year. I think its is already discussed in the thread earlier.
I add 15-20ml of concentrate to 2 L of water (capacity of windshield water reservoir in Honda City 2014). I cleans the windshield very well and the need of repeated wipes is not necessary and it removes thick layers of dirt/dust on the windshield with ease and no marks are left behind.
The only issue which I feel, is that when driving and the fluid is released/sprayed onto the windshield, the areas that don't get wiped get covered with foam and later that mixes with the dirt and those parts become hard to see through.
Cost: around Rs.400/- per 250ml bottle
Brought from: Auchan/Spar, Mantri Mall, Bangalore
Also Available on Snapdeal: http://www.snapdeal.com/product/sona...entrate/189592
Disclaimer: I am not associated with Sonax or any of the dealers/sellers which sell the product. I am just sharing my personal view of a product.
themonster is online now   Reply With Quote
Old 6th August 2015, 18:40   #115
PADAS's Avatar
Thanked: 51 Times
I started using the PROKLEAR™ WWC Windshield Wash Additive Concentrate from last week and it does a good job of cleaning the windshield. But now there's a squeaking noise at times when I use the wiper during rains. Never had this issue before. Wondering if cleaning with the additive is the reason. Any one else faced this issue ? The blades are new and looks ok.
PADAS is offline   Reply With Quote
Old 14th August 2015, 09:05   #116
sunilyk's Avatar
Thanked: 13 Times
I am using Proklear since 3 weeks, but haven't faced this issue. Try cleaning the wiper blades manually.
sunilyk is offline   (1) Thanks Reply With Quote
Old 28th September 2015, 02:11   #117
dumdum's Avatar
Thanked: 15 Times
It might just be the fact that all grease/oil on your windshield has been wiped clean. So clean that it is now "Squeaky clean"
On a side note, I've had an amazing experience with Proklear's WWC.
I have 4 cars, I have atleast 10 litres of WWC pre-mixed with demineralized water lying in storage at any given time. The guy who washes my cars uses only this to top up any windshield fluid reservoirs going empty.
I use demineralised water mainly because I have an easy cheap source for it and I don't want calcium deposits etc. messing up the pump or the thin pipes leading to the nozzles.
I've used it with tap water as well and visually there is no noticeable difference in effectiveness.
I highly recommend this product to all BHPians.
dumdum is offline   (1) Thanks Reply With Quote
Old 28th September 2015, 08:09   #118
itwasntme's Avatar
Very happy with Proklear, cheap too compared to Sonax.
itwasntme is offline   (1) Thanks Reply With Quote
Old 29th September 2015, 23:06   #119
aditya.bhardwaj's Avatar
Thanked: 224 Times
Even i am using the Proklear windshield wash additive and facing the same squeaking problem since the first month of usage . Even tried cleaning the wiper blades manually several times but the same squeaking noise persisted. I have filled the Proklear in a spray bottle and every morning i spray and clean the glass manually. The squeaking noise does irritate a lot while driving therefore i am back to normal water for the washer fluid fill up.
aditya.bhardwaj is offline   Reply With Quote
Old 30th September 2015, 09:58   #120
PADAS's Avatar
Thanked: 51 Times
Smile Re: Best Windshield Washer Fluid?
Same here Aditya. I have gone back to using normal water as well. May be it's a case of "squeaky clean" as dumdum mentioned .
Just to add, I had this noise coming only from the front wipers. I used the liquid for the rear one too, but didn't observe this noise with that. Probably the quality of wiper blades/pressure on glass matters.
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Windshield Washer nozzle upgrade for Esteem/Zen amalji Modifications & Accessories 25 20th August 2016 20:36
DIY: Replacing the windshield washer pipe (Tata Nano) honeybee DIY - Do it yourself 0 29th September 2013 12:04
