Old 1st October 2015, 13:05   #121
aditya.bhardwaj's Avatar
Thanked: 224 Times
Originally Posted by PADAS View Post
Same here Aditya. I have gone back to using normal water as well. May be it's a case of "squeaky clean" as dumdum mentioned .
Just to add, I had this noise coming only from the front wipers. I used the liquid for the rear one too, but didn't observe this noise with that. Probably the quality of wiper blades/pressure on glass matters.
Yes, the noise is coming only from the front wipers. Can i please know what wipers are you using. Mine are OEM from fiat. Many people are extremely happy with this product and there are no squeaking noises with their usage.
aditya.bhardwaj is offline   Reply With Quote
Old 1st October 2015, 13:40   #122
Thanked: 222 Times
Default Re: Best Windshield Washer Fluid?
Read somewhere that acetone will clean glass, where others have failed. Mainly because of the kind of dirt it dissolves vs the regular ammonia based cleaner. Acetone may strip paint though.
mvadg is online now   Reply With Quote
Old 25th October 2015, 23:43   #123
sagarpadaki's Avatar
Thanked: 1,271 Times
Default Proklear windshield washer fluid
Was using sonax windshield wash concentrate till now. So this time I thought I would try the proklear one. This product is good and cleans as well as sonax. One more good property is this does not create a lot of soap froth and residue which was an issue with sonax. Not to mention it's cheaper than sonax. Will continue using this product. Happy with it
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 26th October 2015, 09:55   #124
Thanked: 34 Times
http://autokart.buildabazaar.com/car...01-87348207229
Happened upon this portal that is retailing Sonax clear view concentrate for about a 100 bucks lesser than flipkart / amazon
Apart from that, the description claims product suitability for purposes other than windshield washing.
famousshoes is offline   Reply With Quote
Old 26th October 2015, 11:20   #125
Thanked: 32 Times
There is a washer liquid from Wurth available at DRM Car Care in Bombay. I haven't used it till date but intend to very soon. Will update with the quality. But since it's Wurth, safe to assume, it'll be OK.
polo_ankit is offline   Reply With Quote
Old 26th October 2015, 17:03   #126
SunnyBoi's Avatar
Thanked: 2,794 Times
Default Re: Proklear windshield washer fluid
+1. Excellent Stuff.
I have 4L x 2 pre-mixed bottles at home with Proklear WWC diluted with fresh river tap water (no minerals). Makes it easy to just put in a funnel and pour it in
SunnyBoi is offline   (1) Thanks Reply With Quote
Old 9th June 2016, 21:32   #127
HalfOctave's Avatar
Thanked: 27 Times
Few months back, I was reading few of servicing experiences shared by fellow BHPians. Some of them had specifically mentioned that they were strictly against the Windshield Washer Fluids.
But on the contrary, this thread features most of members using it. Why so discrepancy?
Edit:
Links: http://www.team-bhp.com/forum/offici...ml#post3429434
I am trying to find out more.
HalfOctave is offline   (1) Thanks Reply With Quote
Old 9th June 2016, 22:18   #128
Tanveer_2558's Avatar
Thanked: 2,029 Times
I personally too haven't tried any windshield liquid in any of cars, But i think ill give one of the washer liquid a shot, Will order one soon and post my experience here.
Tanveer_2558 is online now   Reply With Quote
Old 9th June 2016, 22:49   #129
PratikPatel's Avatar
Thanked: 644 Times
I have been using washer concentrates from Ford for past 10 years. One pouch mixed with water is good for one tank full of washer fluid. Cost about Rs. 75/- per pouch. It's very good at cleaning.
PratikPatel is offline   Reply With Quote
Old 10th June 2016, 09:58   #130
navpreet318's Avatar
Thanked: 837 Times
I was suggested to use diluted Colin glass cleaner in the wind screen washer tank. Tried it and results were similar to that of good washer fluids.
navpreet318 is offline   Reply With Quote
Old 10th June 2016, 10:44   #131
Thanked: 232 Times
I started using the PROKLEAR™ WWC Windshield Wash Additive Concentrate ....
Originally Posted by aditya.bhardwaj View Post
Even i am using the Proklear windshield wash additive and facing the same squeaking problem ....
The wipers of my less than 3 months old XUV500 have started squeaking as well. I have a couple of windshield wash additive pouches from Maruti, and am using those. So I guess, it has nothing to do with Proklear. As per instructions, I use one pouch per one litre of water, maybe I will dilute a bit more and see.
Actually my wipers squeak even when I do not use the windshield water additive. Its been raining in Bangalore for the past few days, and I can hear the irritating squeak whenever my wipers go past the windshield
ajayclicks is offline   Reply With Quote
Old 18th October 2016, 01:16   #132
gearedup's Avatar
Thanked: 21 Times
Wanted to buy Proklear WWC from Amazon. Here is what a review says
Is this possible?
There are so many people using such and similar products - can car paint get damaged even if such liquids are used as diluted as possible? (especially rear hatch)
gearedup is online now   (1) Thanks Reply With Quote
Old 18th October 2016, 11:35   #133
Thanked: 644 Times
Was just browsing through amazon and found this;
http://www.amazon.in/Rain-X-RX11806D...=sr_1_5&sr=8-5
One bottle will suffice for 15 liters of washing fluid so while a bit expensive is worth the results.
Old 18th October 2016, 12:55   #134
Awaiting Email Confirmation
Thanked: 318 Times
This is for the reservoir capacity of the Cruze. 50ml of Lime Teepol mixed with 1 teaspoon of synthetic vinegar poured into the reservoir and then filled with water to the brim. The end result in four swipes is a thoroughly clean glass bereft of the diesel oil film too which causes haze in night driving. I have been using this concoction in various cars for the past 26 years. At one time this Teepol was only available in the Armed forces Canteen but now its available in super markets.
http://www.mouthshut.com/review/Teep...iew-msqnqlqnrm
This negative review and rant is the best accolade that the company can ever get. The writer does not know that Teepol is meant to be completely gentle on the hands and hence is not as corrosive or effective as Vim dishwasher concentrate. It is extremely mild on paint too which is one of the prerequisites of a wind shield washer.
drpullockaran is offline   (1) Thanks Reply With Quote
Old 14th April 2017, 17:15   #135
intoxicangel's Avatar
Unhappy Old car - cloudy windshield when it rains
I have seen other posts related to this, but I really haven't found a post that talks about what can be done for old oil/road films that make the windscreen quite cloudy and spotty when it rains.
The story so far:
I moved to Auckland, New Zealand last year and picked up a 10-year-old Honda Fit Aria (essentially the Honda City GD8) and I am the first owner in this country. Before that, the car was in Japan and I don't know how long it was sitting at the port there and here before it was picked up by the dealer to sell.
The issue I am facing is purely when it rains or early in the morning when the dew needs to be wiped off the windscreen. Wiper blades are new & smooth on the surface, but there is either a really old coat of road film/oil film/staining of the windscreen which makes it extremely hard to see through the glass at such times. Otherwise, when the sun is out and the wipers are not running, no issues what so ever.
What all have I tried?
- Toothpaste scrub
- Hot water scrub
- IPA cleaning
- Glass scrub with a deep cleaning glass liquid
Results
Pretty much, just marginal improvements for a while and then we are back to square one.
My question, what can be done for something like this other than replacing the windscreen (which is an expensive affair here even with windshield cover with the insurance)?
intoxicangel is offline   Reply With Quote
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
Windshield Washer nozzle upgrade for Esteem/Zen amalji Modifications & Accessories 25 20th August 2016 20:36
DIY: Replacing the windshield washer pipe (Tata Nano) honeybee DIY - Do it yourself 0 29th September 2013 12:04
