Old 23rd May 2010, 21:39   #1
Thanked: 152 Times
Default Improving Zen MPFI brakes by fitting an Esteem Type II brake booster etc
I have a 2003 Zen MPFi .I hate its brakes .They are really very poor , Below 80-90 kmph they are fine .Above 100 they progressively loose out and i hate burning the clutch each time for decent stops.So i have decided to fit in the Esteem Type II brakes booster to start with .
I am posting a pic of Esteem Type II brake booster .
Can anyone say will it be a direct fit or any changes i need to make .
This is for now .If this suffices my requirements then fine else i will have to swap the discs and other stuff from Esteem type II .(What other stuff ? Please clarify)
MODS : I have read complete Zen threads but unable to get a clear answer to this .
Trust_In_Thrust is offline   Reply With Quote
Old 24th May 2010, 08:23   #2
scorpian's Avatar
Thanked: 235 Times
Infractions: 0/1 (5)
am planning to do the same,but just not getting the right information and direction even from such a big forum in which this must have been done by so many with swapped esteem engines in zen.Maybe its a secret
i did cut my discs and they have improved the braking but yes on high speed they do not inspire confidence and are a sure shot remedy for a crash,if you do happen to find the info pls let me know as well.
scorpian is online now   Reply With Quote
Old 24th May 2010, 09:25   #3
Thanked: 152 Times
@scorpian : From what all i have read before here i have never read a clear reply .Some say type II swap , Some say get ZenD brakes or a mixture of these.
Hope this time someone replies in clear terms.
Old 26th May 2010, 20:41   #4
scorpian's Avatar
Thanked: 235 Times
Default @ thrust
have pmed u the required info
Old 27th May 2010, 09:26   #5
Thanked: 152 Times
@scorpian : Thanks a lot .I am putting faith in you and will get the booster fitted coming weekend.Also do you know will the acc cable in firewall will need to re-routed or even with the Type II booster it will work .
Rest all will have to wait as recently fitted new 12inch tyres .And i believe to swap the discs rim should be 13inch.
Old 27th May 2010, 11:14   #6
Dear Scorpian and Trust,
Would it be possible for you to please share the info on the thread itself. I too am very interested in getting the same done for my Zen.
Thanks.
Cheers,
Harsha
harsha.cs1 is offline   Reply With Quote
Old 27th May 2010, 16:43   #7
Thanked: 660 Times
Zen brakes are fine and adequate. It may be a case related to your car only. Instead of such retro fit, just get it checked properly.
How much kms has your car run.?
Old 27th May 2010, 17:02   #8
scorpian's Avatar
Thanked: 235 Times
SMS / Slang is STRICTLY prohibited on this community. We would much appreciate your using full & proper English in posts, for the benefit of other forum users.
Please view our board rules carefully before proceeding any further.
ok ..
@thrust,
I think u will need to drill another hole and pass the cable through that,its not a big deal,just make the hole pass the cable and use sum rubber adhesive to keep the heat away....
parts rquired for the swap are...
1)type 2 brake booster assembly.
2)type 2 callipers
3)type 2 ventilated discs...
4)type 2 hubs.
i got this info froma reputed tuner and have reconfirmed the same with his mechanic who does the fitment....
regards,
manoj....
Last edited by GTO : 28th May 2010 at 14:44. Reason: SMS / Slang is STRICTLY prohibited on this community. We would much appreciate your using full & proper English in posts.
Old 27th May 2010, 17:03   #9
black12rr's Avatar
Thanked: 274 Times
@thrust , please take pictures when work in process and also the parts . .
black12rr is offline   Reply With Quote
Old 29th May 2010, 11:20   #10
Thanks Scorpian - this is useful!
Old 29th May 2010, 14:19   #11
Thanked: 127 Times
ok ..
@thrust,
2)type 2 callipers
4)type 2 hubs.
regards,
manoj....
Thank you, we now have some clarity about the parts required.
Please do this. Although many guys have done this swap, it would be first time some one is documenting it.
heavy_foot is offline   Reply With Quote
Old 29th May 2010, 16:38   #12
Thanked: 660 Times
ok ..
@thrust,
2)type 2 callipers
4)type 2 hubs.
regards,
manoj....
why do you need to change so many things. especially calipers and hubs.
Old 29th May 2010, 16:49   #13
Thanked: 152 Times
@siralec : The Esteem type II discs are thicker than Zen's .So the Zen calliper cannot be used on those so the new calliper of Esteem type II are required .
Regarding hubs I believe the PCD of the Discs is different in Esteem to those of Zen's so with type II discs you need Type II hubs.Also note that PCD of wheel/tyre is same though.
Also with these items we need the 13inch rims as 12inches will be small.
This is what i have been told but hope some one can confirm this.
Old 29th May 2010, 18:02   #14
nitrous's Avatar
Thanked: 285 Times
Tip: Use KBX (white and blue box) brake pads.
The MGP pads (made by TVS-Girling) fade like crazy.
Old 29th May 2010, 18:42   #15
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by Trust_In_Thrust View Post
@siralec : The Esteem type II discs are thicker than Zen's.
Is that because type1 is solid and type-II is vented.
Fade on the street or track? Is KBX semi-metallic?
Improving your car's brakes: Options and costs Rtech Modifications & Accessories 152 26th September 2017 02:09
Booster Brake Adjustment - Is it possible? mail4ajo Technical Stuff 31 30th September 2015 21:31
Brakes Catch Fire / Brake Bed in procedure / Brake Shudder : Solved Indian1979 Technical Stuff 35 4th October 2013 13:42
Brake booster Assembly of the Indigo joecherian Technical Stuff 22 9th June 2009 14:27
esteem type 2 instrumentation in type 1 rdkarthik Modifications & Accessories 3 3rd February 2006 14:43
