Old 1st November 2008, 11:37   #16
Shakensoul's Avatar
Thanked: 222 Times
I also preach that gear lock is one of the most essential accessory in a car.
I have U type one from xenos installed.
Xenos Technologies Ltd.
Shakensoul is offline   Reply With Quote
Old 1st November 2008, 14:30   #17
ankitahuja's Avatar
Thanked: 46 Times
Can someone please clear a doubt. Some while back I found about gear locks for the OHC. I was told that the 'pin' type can not be installed in the OHC and I would need the U type gear lock.
Is this true?
Old 1st November 2008, 14:43   #18
Thanked: 245 Times
Is this true?
For some vehicles wherein a pin-type cannot be fitted, U-Type is used.
Indica - U-type
Santro - Pin type
Old 1st November 2008, 18:03   #19
ankitahuja's Avatar
Thanked: 46 Times
@Dadu: I agree with what you said, but my question is that can the OHC really not accommodate the pin type lock. I do not like the U ones since they look bulky and fugly!
Old 1st November 2008, 18:23   #20
Thanked: 253 Times
The more visible a gear-lock is the better it is as a deterrant to the potential car thief!
Worldwide, it is steering locks that have prevented maximum number of thefts.
Old 2nd June 2010, 21:50   #21
NFS
NFS's Avatar
GTO, you mentioned about Kryptonite gear lock. Do they have a website for India (for me to search for a dealer in Chennai)? Can I know the exact name of the product that you use?
Thanks a bunch in advance,
NFS is offline   Reply With Quote
Old 6th August 2010, 01:20   #22
Does fitting a pin type lock require us to do anything that would potentially void any kind of warranties on the vehicle or is it a clean install?? Im not familiar with what exactly they do to fix it. Anyone who has got it can may be advice?
liquidmetal99 is offline   Reply With Quote
Old 6th August 2010, 01:39   #23
BANDHAV's Avatar
Thanked: 278 Times
Gear lock either pin or u-type doesn't void the warranty, so go ahead and get one for your car. In which car you want to get this fitted?
BANDHAV is offline   Reply With Quote
Old 6th August 2010, 01:47   #24
Im looking at getting one for my i20. Just took delivery today. I got the xenos remote locking done and i was looking at getting a gear lock since the place where i park is not too safe. I know hyundai has a pin type lock but was not readily available or so i was told. i have to place an order it seems. So i decided i'd just go get one from outside but wasnt sure if it involves something that would void any kind of warranty or something. Thanks for the info. Now i know
Old 6th August 2010, 01:59   #25
BANDHAV's Avatar
Thanked: 278 Times
All the components of gear locks are same apart form the plate, plate differs from model to model. So it must be the specific plate of I20 which is not available with them. You can get either a Minda, Autocop or Nippon gear lock all these are good and retails at around 1000-1200 bucks.
Old 22nd October 2010, 13:12   #26
Recently got gear lock installed. It is U-type from multicop( autocop ). Now the gearlock is engaged in neutral position please tell me is it safe to have gearlock engaged in neutral position? as anyone can drag the car and then cut the gearlock plate.
SidzPolo is offline   Reply With Quote
Old 3rd July 2011, 14:33   #27
sumeethaldankar's Avatar
Thanked: 1,160 Times
Default Re: Which Gear Lock?
Which gear lock would be suitable for a Honda Civic (2007) model ?
thanks
sumeethaldankar is offline   Reply With Quote
Old 3rd July 2011, 15:01   #28
libranof1987's Avatar
Thanked: 4,221 Times
Originally Posted by sumeethaldankar View Post
Which gear lock would be suitable for a Honda Civic (2007) model ?thanks
You could go to a Honda A.S.S.; they generally have a good supply of gear locks.
I have the Terminator brand gear-lock fitted on all 3 of my cars (Zen, ANHC and Corsa). Found them to be pretty good.
The one with ANHC is amazingly sleek; it is fitted on the left of the gear-box and has a small rod-type arrangement. You slot the gear into 1st and shove the small rod (about 10cm) into the hole and that is it! The conventional U-type can be an eye-sore.
libranof1987 is offline   (1) Thanks Reply With Quote
Old 16th July 2011, 13:04   #29
My Local accessories shop whom i had contacted for getting a gear lock for the civic got back to me saying that it's not possible to fit a gear lock in the civic.The guy had contacted Autocop and some other brand co downtown both said that civic it's difficult to fit a gear lock in a civic and they do not make one for the same.
Question what else can i get.I am not interested in electronic gizmos but have more faith in strudy mehcanical locks.I do have a club typed pedal to steering wheel kind of lock but hasn't anyone got a gear lock for a civic.
thanks
Old 16th July 2011, 22:59   #30
Thanked: 113 Times
Quick question guys - what kind of gear lock is suitable for Gypsy? Pin type or U type?
--Rahul
Ragul is offline   Reply With Quote
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Can a gear-lock cause the gear cable to loosen up? libranof1987 Technical Stuff 0 22nd December 2011 21:29
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
