Old 17th November 2015, 17:52   #316
Default Re: The Hella Experience - 500 FF
Hi Folks
I have got my Thar a set of Hella Rallye 1000 series Black Magic lamps and I wanted to get some information on the lock nuts that I should be getting as well to get it some protection. Are there any specs that I should be watching out for when looking for these lock nuts? Some help here please.
Thank you.
bigfootraj is offline   Reply With Quote
Old 23rd November 2015, 00:35   #317
antardaksh's Avatar
Thanked: 227 Times
Originally Posted by Red Liner View Post
Hella 50ff alone switched on. Am pretty stoked with these lights.
Hi Red Liner,
Could you please tell where in Bangalore did you buy and get it installed. Is it mounted on the bumper or fabricated clamp?
Regards.
antardaksh is offline   Reply With Quote
Old 25th November 2015, 08:24   #318
antardaksh's Avatar
Thanked: 227 Times
Originally Posted by akshay4587 View Post
On my highway drives i have found 500FF(with stock bulbs),just about adequate,nothing exceptional.
50FF's are way better than 500FF.
Hi akshay4587,
I am also planing to buy these lights, however price quoted (approx 10k) now is way higher than what it was in 2014.
Would you be able to share feedback about Hella 50ff after using these for over an year. Did you upgrade bulbs on these lights, I was not able to find higher wattage replacement for H7 bulbs.
Regards.
Old 25th November 2015, 08:59   #319
Red Liner's Avatar
Thanked: 1,481 Times
Originally Posted by antardaksh View Post
Hi Red Liner,
Regards.
Sachins auto shop in koramangala.
Red Liner is offline   (1) Thanks Reply With Quote
Old 25th November 2015, 23:59   #320
akshay4587's Avatar
Thanked: 1,686 Times
Hi akshay4587,
Regards.
I havent upgraded bulbs on the 50FF.
The stock ones are good enough.
Btw i just purchased 80W Phillips H7 bulbs for my linea few weeks ago.
akshay4587 is offline   (1) Thanks Reply With Quote
Old 26th November 2015, 00:06   #321
condor's Avatar
Thanked: 4,907 Times
Hope you will be using a relay with the bulbs ?
Old 26th November 2015, 01:08   #322
antardaksh's Avatar
Thanked: 227 Times
Hi Akshay,
Are these available online?
http://www.p4c.philips.com/cgi-bin/c...n=924007117121
Regards.
Old 30th November 2015, 19:01   #323
akshay4587's Avatar
Couldnt find a H7 relay.
Being +25W over stock, these are working just fine.
Hi Akshay,
Regards.
Purchased from a local store, no idea about online.
Old 30th November 2015, 21:20   #324
condor's Avatar
Being +25W over stock, these are working just fine..
A relay is not specific to a bulb. The relay (or cut-out as some call it) will help to provide the required current to the bulbs. While the +25 bulbs will work initially, still go for the relay.
Also look for ceramic holders if you can find some.
Old 1st December 2015, 18:58   #325
I am currently located in Pune and would anyone recommend a good mechanic whom I can entrust with getting my fog lamps installed?
Thank you folks.
Old 7th December 2015, 18:55   #326
antardaksh's Avatar
Thanked: 227 Times
Hi Red Liner,
Could you please help with another question about Hella 50FF. How are these mounted on the bumper? Have you installed these using steel bracket or bolted to plastic bumper. It would be great if you can post a picture of these lights installed on the bumper.
Regards.
Old 8th December 2015, 10:26   #327
Red Liner's Avatar
Hi Red Liner,
Regards.
Sorry, sold the car and don't have pictures. Remove the front bumper and cut holes in the air dam to fit the lamps. I also added a small clamp for each. This is for the Figo.
Take your car there. He is quite experienced to figure out the best solution.
Old 1st January 2016, 08:22   #328
arjithin's Avatar
Thanked: 1,415 Times
I upgraded from Neolite 801 to hella 500FF 2 weeks back. Bought the set from USA, it costed around INR 3200 after all the thanksgiving discounts and a relative brought it to India.
Here are some pics of the light in action.
Focus: left light is focused towards the curb to highlight the pedestrian standing beside road and right one is focused 30-40 meter in front of the road to see the road condition ahead clearly even when blinded by oncoming high beams. Both lights won't blind oncoming traffic.
Bulbs : Philips bluevision H3, Rs 500 a pair.
Only low beam( note- the road is slightly inclined upwards)
Only High beam, middle position in leveling switch.
High beam + fog lights
Only hella
High beam + Hella
Low beam + Hella , now my preferred one for 2 lane roads.
All photos are taken using a cellphone in automode, so don't compare the light output from the pics.
Issues
1. The hella's are slightly aligned to the left, it is giving a driving position discomfort. I am used to lights which are parallel to the direction of travel. But over a week of driving, the discomfort has been reduced to a great extend.
2. In Hella + High beam mode, the High beam seems very weak as eye is adjusted to the brightness of Hella. I may move back to the stock bulb to reduce the intensity of light.
arjithin is online now   (6) Thanks Reply With Quote
Old 3rd March 2016, 22:36   #329
d3mon's Avatar
Thanked: 622 Times
Does anyone have experience in using the Hella 60mm Low Beam projector module?
This is a standalone low beam projector, which takes in HB3 (65W) bulbs and produces a nice cut off. This means that it can be used all the time, unlike other aux lamps, which can only be used on the highways.
Another major plus point is that these are surprisingly cheap (~1300 for one).
The major unknown is how difficult they'd be to install on my Figo Aspire, without replacing the stock fog lamps.
http://www.amazon.in/gp/product/B00SHLA4I2/
d3mon is offline   Reply With Quote
Old 3rd March 2016, 23:23   #330
condor's Avatar
from the looks of this, and the drawings that you have shared, it can be tricky. You will need a way to mount these using the mounting socket. If you use a mounting bracket, then where will you fix this bracket to ?
Also, the lamp is about 16cm long. Will be best to keep it inside and not completely protruding outside). If you want to do this, then you will need almost 20 cm of depth to mount it.
DIY: Fixing the Hella Red Grill Horns abhipuru16 DIY - Do it yourself 5 30th April 2017 20:13
HELLA dealer / availability in India gbpscars Modifications & Accessories 35 1st March 2017 09:12
Hella develops LED HeadLamps Stratos Technical Stuff 19 31st October 2010 18:43
Bangalore Kanyakumari Rameshwaram Trichy Bangalore - One Hella Trip !!!!! lancersfx Travelogues 21 5th July 2010 14:01
Hella Auxillary Xenon Lamps Ajay Narayan Modifications & Accessories 7 9th June 2010 20:20
