Old 14th November 2015, 01:32   #16
rohitkadam's Avatar
Default Re: i10 Headlamp Bulb Upgrade
Hello,
I am using a Roots relay and wiring harness with 100/90w bulbs in my i10. But every now and then either the fuse goes off or the ceramic holder burns or the bulbs burn out.
I had to make a hole in the cap to upgrade to 100/90w, however the guy who worked on it really left a bigger hole and whenever it rains water makes its way into the headlamp assembly.
My friend uses a 100/130w bulb and faces a similar issue. We have used all brands of bulbs, Philips, Bosch, Osram etc but still no respite.
Does anyone know what could be the actual problem. I am using a fuse of 30A on the relay.
Thanks.
rohitkadam is offline   Reply With Quote
60/55w Bulb Holder 4 ZMA eagle_f1 Motorbikes 40 26th December 2007 20:10
Which Bulb for HeadLamp for a good bright vision RishiSuri Modifications & Accessories 2 11th December 2007 12:01
Headlight bulb upgradation help required. Dragonov Modifications & Accessories 9 22nd September 2006 13:57
Xenon Bulb for Pulsar adityaac Motorbikes 0 17th July 2006 20:56
