Old 10th December 2005, 17:42   #31
ex670c's Avatar
Thanked: 1,821 Times
Default Mahindra CLASSIC with NEF-TC-IC w NGT530 aka Scorpio Engine & Transmission
Originally Posted by GTO - Touring
Correct. Thats why I said the drivetrain parts will not fit.
The drivetrain can fit will require modification of floor boards.
M&M has produced a variant for the M&M CLASSIC with the
1 -Scorpio Diesel Engine Turbo Intercooler et. al.
2- NGT530 4WD gearbox which is a modified Bolero G-box.
This vehicle was made for export this year and the prototype is being used by Mr. Alan Durante of M&M.
Should you want more information you know where to Look for......;-)
Keepin' Jeepin'
Arka
Old 10th December 2005, 17:45   #32
ex670c's Avatar
Default How about an OM616
Some of my friends have successfully transplanted a OM616 in SWB JEEPs
namely WILLYS MBs, CJ2A/3A and CJ3B with Crankcase modification.
But on a MM540 the Fit is better. Also it is recommended to use the M&M KMT-90 4Spd 4WD g-box
Keepin' Jeepin'
Arka
Old 10th December 2005, 18:09   #33
Thanked: 103,670 Times
Thats why I posted in reply no.24
GTO : Well, I guess it is minutely possible but with a LOT of extensive modifications.
With extensive modifications, even a V8 engine will be possible (as many CJ3Bs around the world have successfully installed.) I am speaking more within realism / practicality, and within the scope of most Indian after market suppliers.
How about some more details on the Scorpio engine Classic? Pictures? Drive review?
Old 2nd November 2008, 10:30   #34
muneemmk's Avatar
Thanked: 18 Times
My Cousin Wants to replace his Peugeot Engined Willys , I suggested him the 2000cc Isuzu Engine found in the Ambys/Contis but he wants to Keep the 4 wheel drive intact , other wise it defeats the whole purpose of the Jeep. So what say ? Can we keep the 4 X 4 running with the Isuzu engine , if not why ? What other engine can we get under 20K for a Transplant into this 65 Willy ?
muneemmk is offline   Reply With Quote
Old 2nd November 2008, 14:25   #35
jeep540's Avatar
If u r interested in Isuzu engine than go for Isuzu G1, it is 2400 cc,
otherwise mahindra DI is best
jeep540 is offline   Reply With Quote
Old 2nd November 2008, 16:54   #36
muneemmk's Avatar
Thanked: 18 Times
Okay . but if i go for an Isuzu G1 will i be able to keep the 4 X 4 Running ?
Old 2nd November 2008, 17:25   #37
4x4addict's Avatar
Thanked: 2,669 Times
If you are retaining the existing jeep 4x4 gear box you may be able to attain your 4x4. You just need to make sure that the engine you buy is able to connect properly with the 4x4 gear box. You also need to make sure that any part of the engine will hit the front differentials or the front drive shaft. Basically, if the engine you are installing does not interfere with the 4x4 set up, you an retain the 4x4 set up.
4x4addict is offline   Reply With Quote
Old 9th September 2012, 16:41   #38
Default Re: What new engine for Jeep ?
hi i have heard of the OM 616 engine which was fitted on the Matador 305 I would like to ask our senior bhpians to enlighten us on this modification
pints12 is offline   Reply With Quote
Old 9th September 2012, 21:21   #39
Frankenstein's Avatar
Thanked: 300 Times
This engine requires certain mods to the existing Jeep.
For a mm540, the oil chamber needs to be cut
New engine mounts need to be fabricated
An adapter plate needs to be made to match with the mahindra gearbox.
New gearbox mounts are required.
Rear shaft needs to be altered
Incase of a low bonnet jeep , you have to cut short the air intake manifold.
Frankenstein is offline   Reply With Quote
Old 29th October 2012, 18:05   #40
hi i have just purchased a 1966 willys cj3b with the petrol engine the rockers have a powder formation on them getting it restored in pune with mr suleman arab can this engine be restored as the mechanic says its not possible i have posted some pictures for all our bhpians but unfortunately the size of the file is a bit large around 1.43mb request advice on how to scale down the image to 1 mb as permitted
Old 30th October 2012, 01:25   #41
chanu's Avatar
Thanked: 140 Times
Open the same image in a Microsoft paint and crop the size to 50% and then you would be able to reduce the size and can post here.
chanu is offline   Reply With Quote
How to drive an unknown JEEP for 1500kms - A Travel/Photologue by a n00bie JEEP'r dhanushs Travelogues 78 4th December 2011 15:00
2009 Jeep J8 Multipurpose 4WD.....return of the WILLYS JEEP!!! amit V8 The International Automotive Scene 14 27th July 2009 01:12
First offroading event with my Jeep: Coorg Jeep Thrills OTR 2008 Report Samurai 4x4 Excursions 115 21st June 2009 16:12
