Old 13th November 2005, 15:45   #16
Ford Rocam's Avatar
Thanked: 16 Times
Thats a great news ,2 dynos, one in mumbai & other in banglore , At last we will get to see the actual HP figures ,not the hyped one
Ford Rocam is offline   Reply With Quote
Old 13th November 2005, 18:29   #17
ananthkamath's Avatar
Thanked: 63 Times
Great news, Karan & Domnic.
About time we started taking MHP (mental horsepower) out of the tuning equation.
ananthkamath is offline   Reply With Quote
Old 13th November 2005, 19:09   #18
Hello guys,
I am gettting an inertia dyno,with 30" rollers.This is by far the most accurate system,not because I am buying it,but because such heavy rollers can stimulate the weight of the car better.
I dont need to take the wheels off the car.So the reading a very accurate,just like the real world where the engine has the turn the wheels and tire also
It is good up to 1200 Hp,not that we have any car here over 500hp(power at wheels)Ranjit`s Supra to name one
Mine is a DynaMite!
Thank You.
Karan Shah is offline   Reply With Quote
Old 13th November 2005, 19:22   #19
nitrous's Avatar
Thanked: 285 Times
Gr8 going, KS and dom.
Why didnt u get Dynojet??? Is it very expensive?
Old 13th November 2005, 21:56   #20
Mumbaiya's Avatar
Is it an 4 Wheel Drive or a 2 Wheel Drive System?
Mumbaiya is offline   Reply With Quote
Old 13th November 2005, 22:40   #21
nitrous's Avatar
Thanked: 285 Times
It must be a 4 wheel dyno,mumbaiya
Old 14th November 2005, 00:24   #22
Mumbaiya's Avatar
What are you going to charge for each Dyno Report?
Old 14th November 2005, 12:05   #23
tsk1979's Avatar
Thanked: 16,422 Times
Thats good news. But one question. The manufactorers measure at crank. So a 100bhp car may produce just 70hp at the wheels. So if a modded car produces 90bhp at the wheels it means an output jump by 25% but since original manufactorer claim was 100bhp, the modded car will still show lower results. How are you going to factor that in your tests
Old 14th November 2005, 12:23   #24
Psycho's Avatar
Thanked: 95 Times
Most of the real world applications would require us to know the WHP and it is understood there are trasmission losses there are generic rules that can let you determine the true engine output. However most of the tuners around the world prefer to work with WHP figures as it would typically represent the on road figures.
Another point Karan does this system also have enviroment controls to give you true repeatable results. Also an inertia dyno you would only be doing single gear pulls, typically the second.
Old 14th November 2005, 12:29   #25
Hello Psycho,
Yes u can do consistant runs.The inertia dyno will only show u the max whp.1 full pull in the third gear.
Old 14th November 2005, 17:50   #26
Thumbs up Thats the way to go
Way to go KARAN !!!!!!!!!!!
BTW how much r u gonna charge
take care
Aditya
Aditya0202 is offline   Reply With Quote
Old 14th November 2005, 20:33   #27
Thanked: 63 Times
Karan one question here..how are you going to correct for atmospheric conditions..humidity, altitude etc (SAE corrected horsepower) ?
Old 15th November 2005, 01:04   #28
EVO6's Avatar
Hey Karan,
Congrats...
Inertia dyno mean simply drive you car on the test bench and make the runs ... Finally things are moving in India now...
EVO6 is offline   Reply With Quote
Old 15th November 2005, 01:37   #29
The Wolf's Avatar
Thanked: 58 Times
Originally Posted by v1p3r
Great to see that we can confirm figures now!
Do you really need one?? Tu to chaltaa phirtaa dyno hai!!!
The Wolf is offline   Reply With Quote
Old 15th November 2005, 02:24   #30
fieroid's Avatar
Thanked: 287 Times
woo thats good new man! It will bring the raw truth out for sure!
fieroid is offline   Reply With Quote
All about Dynamometers + DYNO visit with GTO's Vtec! Rehaan Modifications & Accessories 109 5th September 2014 09:27
dyno in india? adilshah Shifting gears 23 31st March 2010 12:24
Dyno facility in mumbai.... Finally !! amit_13 Modifications & Accessories 122 1st October 2007 20:44
Dyno Tuning Ford Rocam Modifications & Accessories 1 8th May 2005 08:33
Dyno tuning Sam Modifications & Accessories 11 2nd May 2004 04:15
