Old 19th August 2010, 23:35   #16
vasanthn21's Avatar
Thanked: 306 Times
So, are you saying that if I procure Swift nozzles, and I can manage to remove the nozzles on my Zen and fit the new one's in its place, it will work fine, nothing else needs to be done.
No change in the water pump (or whatever does it behind the scene), no change in hose leading to the nozzle (if there is one), no additional washers (anything for sealing) required? Is it so simple?
I would hate to see water leaking from the base of the nozzle, there are chances of this happening if the job is not done properly right?
vasanthn21 is offline   Reply With Quote
Old 20th August 2010, 19:42   #17
amalji's Avatar
Thanked: 1,524 Times
Thumbs up
1) The hose fits perfectly on to the nozzle. So, there is zero chance of a leak here.
2) The only difference is in the way, nozzle is attached to the body of the car. The swift nozzle is a bit more broader. But, it'll fit nicely into it.
3) You don't need to make any other modification. Just the nozzle is all what you need to buy. Get it done by your service center and ask them to calibrate the direction of the water.
To conclude, it's so simple.
amalji is online now   Reply With Quote
Old 23rd August 2010, 13:39   #18
yogisays0909's Avatar
Thanked: 173 Times
I got this thing done today, spray is actualy good , loved it , thanx Amalji
yogisays0909 is offline   Reply With Quote
Old 23rd August 2010, 17:37   #19
suzuki san's Avatar
Thanked: 310 Times
Hi Amalji,
Thanks a lot for the tip.
I got this fitted on my Esteem on Friday.
Works great! Covers almost the whole windscreen.
Got it done at Sah & Sanghi.
A bit of a struggle getting the old nozzles out.
No problem putting the new ones in.
SS
suzuki san is offline   Reply With Quote
Old 23rd August 2010, 17:59   #20
motomaverick's Avatar
Thanked: 864 Times
I guess with this mod we need to increase the size of the water container as well since alot will be spent for one wash
I will try this tomorrow
Old 27th August 2010, 16:28   #21
amalji's Avatar
Smile
Glad to hear it was of use to you.
Originally Posted by suzuki san View Post
Hi Amalji,
SS
Yeah, I was also having problems, getting the old nozzle out. Been there for almost a decade. So, quite natural.
Infact, the durability of water has been OK. I use it frequently. I haven't changed the water since the time, I fitted this mod on my car.
Old 31st August 2010, 16:34   #22
pulsar56's Avatar
Thanked: 319 Times
After seeing this thread, I too went in for the upgrade of the wiper nozzles!
Tried out the Wagon R's nozzle (3 directions) and it is also a direct fit on the Zen. Only problem is it's a SGP (not MGP) and costs INR 298/- for a single nozzle!
The water got over super fast with the Wagon R's nozzles and I had them changed to the Swift Nozzles at 102/- for the pair!
Thank You Amalji for sharing this information.
pulsar56 is offline   Reply With Quote
Old 19th August 2016, 10:01   #23
sharma_sanjeevi's Avatar
Thanked: 62 Times
Default Re: Windshield Washer nozzle upgrade for Esteem/Zen
Reviving an Old thread!!
Dear Amalji,
Can you please share the Part Number if available with you ?
Want to get this Modification done to my M-800.
As there is lots of part sharing in Maruti Cars. I assume, it would be a direct fit in M-800 as well.
Thanks for sharing this very useful & simple DIY.
sharma_sanjeevi is offline   Reply With Quote
Old 19th August 2016, 12:25   #24
amalji's Avatar
Post Re: Windshield Washer nozzle upgrade for Esteem/Zen
Dear Amalji,
I don't have the part number with me now. What I would recommend is to take your car to a MASS where you have some workers whom you know off.
Tell them that you need a better nozzle with more holes to spray the water. Swift / Wagon R or any other Maruti. They will be able to suggest you which one has a higher probability of replacing the one in your M800.
I called up Rajan Sir of Autoteam Maruti Service Zone, Kochi and he told that if it's Maruti 800 Type 2 ( where the nozzle is fixed on the bonnet and not on the grills below the windshield ), this mod is possible. The Swift's nozzle should work fine.
amalji is online now   (1) Thanks Reply With Quote
Old 19th August 2016, 13:03   #25
Thanked: 62 Times
Thanks a Lot Amalji for the quick response!!
Yes, mine is a M-800 Type-II. Hence, assuming this would be an easy DIY.
Will procure the same this weekend & update.
Many Thanks!!
Old 20th August 2016, 20:36   #26
Thanked: 62 Times
Today, went to Local Spare Parts shop near my home.
Got the Nozzles with Dual Jets for Rs.40 & Installed them.
They are a direct fit, No Modifications required at all.
Now, the Spray is excellent from 4 Jets. 2 each Nozzle.
Thanks Amalji, for the information
Best Windshield Washer Fluid? Epic Modifications & Accessories 144 22nd June 2017 12:52
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
DIY: Replacing the windshield washer pipe (Tata Nano) honeybee DIY - Do it yourself 0 29th September 2013 12:04
DIY: Cleaning The Windscreen Washer Nozzle soumobakshi DIY - Do it yourself 10 15th August 2013 00:31
