Old 13th August 2010, 15:43   #1
Thanked: 1,645 Times
Thumbs up Windshield Washer nozzle upgrade for Esteem/Zen
Dear Bhpians,
One of the frustrating negatives of the cars of the last decade - Esteem/Zen is the inefficiency of windshield washer used. Water comes only in one direction which makes the process of cleaning the dirty windshield inefficient.
Accidentally, I noticed that the nozzle used in Maruti Swift ( which pumps in 2 direction per nozzle ) will fit in correctly on Esteem as well. Changed it to swift's windshield cleaner nozzle and cleaning the windshield became all the more efficient.
I guess the same mod will work on Maruti Zen and 800 as well.
Cost = Rs. 51/- per nozzle ( So, a total of Rs. 102/- ) for water pumping to 4 directions. :-)
Thanks to Autoteam, Cochin who made this modification for me.
Amal
Last edited by Rehaan : 26th August 2010 at 16:56. Reason: TBHP rules permit 2 smileys max per post. Please make sure you read the rules before continuing. Thanks.
amalji is offline   Reply With Quote
Old 13th August 2010, 16:35   #2
autexy's Avatar
Wow, this is nice.
But is it possible for 800 also, will the water jets be inside the windscreen for an 800?
As, swift has a wider windscreen.
autexy is offline   Reply With Quote
Old 13th August 2010, 19:30   #3
Smile
Originally Posted by autexy View Post
Wow, this is nice.
It should be compatible with 800 too.
Regarding water jets, you can calibrate it according to your requirement. So, narrower windscreen doesn't matter.
Last edited by Rehaan : 26th August 2010 at 17:11. Reason: Hi Amalji, your signature has been removed as we do not allow external links, as well as try to avoid brand mentions. Thanks
Old 13th August 2010, 19:50   #4
black12rr's Avatar
Thanked: 273 Times
@amalji , excellent , could you post pics of yours ? .
It should be Do it Yourself ? .Also is the water pump powerful to squeeze water from 4 holes ? .
black12rr is offline   Reply With Quote
Old 14th August 2010, 08:41   #5
Thumbs up
Yes, will post the pics by tonight.
Yeah, it's simple to fix it. If it gets too tight, doing it under the supervision of a workshop personnel will be better.
[/quote]
Yes, powerful enough.
Old 14th August 2010, 11:16   #6
motomaverick's Avatar
Thanked: 864 Times
good and simple solution....i hope the water isnt sprayed outside the windshield. When i was driving a bike there were cars where the water used to be thrown all over the place
Old 14th August 2010, 19:33   #7
dhanushs's Avatar
Thanked: 4,472 Times
Its good to know that the spray is powerful enough.
btw, do you have any idea if it can be fitted to any other cars than maruthi ones?.
I will be awaiting pics.
Old 14th August 2010, 21:19   #8
it's because the nozzle direction is not adjusted properly. We can do that easily with the help of a strong pin.
Old 15th August 2010, 18:19   #9
Smile
Pictures of the windshield washer's nozzle upgrade.
Old 16th August 2010, 06:23   #10
Smile
Not sure about that part. Which car do you own? Maybe, I can check it out for you.
Old 16th August 2010, 12:03   #11
yogisays0909's Avatar
Thanked: 188 Times
Dude, thats excellent and the first thing i will do is change the washer nozzle once i am back in mumbai this weekend.
yogisays0909 is online now   Reply With Quote
Old 16th August 2010, 22:50   #12
Smile
Fitted the same mod on Mom's Maruti Zen. Works well.
Old 17th August 2010, 18:22   #13
nc1bad's Avatar
Thanked: 15 Times
hey nice install, can you tell me whether the nozzle bonnet hole had to be enlarged to fit the new nozzle?
nc1bad is offline   Reply With Quote
Old 17th August 2010, 22:14   #14
Smile
No modification needed for the hole. Even though, a bit tighter than the default nozzle, it will get in.
Old 19th August 2010, 22:32   #15
dhanushs's Avatar
My ride is a Ford IKON. Considering the pictures above, I guess I will have to modify my bonnet. Also there would be the OE washer hole, which will be unattended.
hmmm... this would be a difficult affair, I guess.
Best Windshield Washer Fluid? Epic Modifications & Accessories 145 18th June 2018 20:07
VW Polo DIY: Windshield washer low-level sensor & dash warning Gannu_1 DIY - Do it yourself 27 27th August 2016 08:53
DIY: Replacing the windshield washer pipe (Tata Nano) honeybee DIY - Do it yourself 0 29th September 2013 12:04
DIY: Cleaning The Windscreen Washer Nozzle soumobakshi DIY - Do it yourself 10 15th August 2013 00:31
