Old 19th August 2010, 16:07   #1
Thanked: 41 Times
Default Dual Exhaust, How good are they?
I just came acros to the following picture of dual Exhaust for ANHC.
Just want to know how efficeint are these.
How good the secondary exhaust will be in this type pf setup.
I think the 2nd one will not be as efficient as the 1st one, unless there is a "V" spliting the exhausts.
monty9991 is offline   Reply With Quote
Old 19th August 2010, 16:21   #2
pranavt's Avatar
Thanked: 272 Times
All depends on the shape of the muffler inside. Most of the exhaust will flow from the RHS tailpipe though.
Old 19th August 2010, 23:00   #3
RedMM340's Avatar
Thanked: 23 Times
Dual exhausts are great for V8 engines and other large capacity motors.
For a small 4 cylinder engine, such as the Honda City, it is purely cosmetic. In fact it just adds unnecessary weight to your vehicle.
So take your pick: Either make your car look faster, or actually go faster.
RedMM340 is offline   Reply With Quote
Old 20th August 2010, 00:51   #4
Mpower's Avatar
Thanked: 1,682 Times
What you have shown is more of a 'dual muffler' set up and not really a dual exhaust.
Old 20th August 2010, 01:06   #5
CPH
Thanked: 33 Times
The first one is terrible and the second one is nothing to bragg about. Both are not professional solutions. I would not want to have the box in the second picture on its own either.
CPH is offline   Reply With Quote
Old 20th August 2010, 11:33   #6
Thanked: 41 Times
Thats what I think , RHS will work more but at high revs there will be no exhaust thru LHS.
How about having a dual exhaut by from 2 clyinders on right and other 2 on the left? just 2 to 1?
Excatly, actually I wanted to make sure on this if its just an cosmetic setup.
Old 20th August 2010, 12:46   #7
Sprucegoose's Avatar
Thanked: 38 Times
this again will be better with a V[6/8] engine.
because you will have exhaust ports coming out of each side of the engine.
In our cars with transversely mounted engines, if you split both pipes, they might end up longer and be more restrictive.
Sprucegoose is offline   Reply With Quote
Old 20th August 2010, 12:47   #8
pramodkumar's Avatar
Thanked: 857 Times
Infractions: 0/1 (5)
Your car would be extremely sluggish in the low mid region with very low back pressure, but amazing top end.
Pramod
Old 20th August 2010, 13:25   #9
pranavt's Avatar
Thanked: 272 Times
You can do dual exhausts and still maintain exhaust velocity by using pipes of a lesser diameter. Backpressure is irrelevant, it's all about velocity. The cross section area of the pipes determines the airflow at peak exhaust velocity. Tune it for high amount of airflow and it will be bad at low RPM, tune it for medium amount of airflow and it will be restrictive at high RPM.
pranavt is offline   (1) Thanks Reply With Quote
Old 20th August 2010, 15:06   #10
Thanked: 41 Times
So, in all I should stick to single exhaust type.
Will be soon opting for a Universal Magnaflow muffler for my ANHC.
What model do you guys suggest? Few of the followings are my requirements
1. Should'nt be loud I just want a nice sound.
2. Have to take this car for shopping with family.
3. Have to drive daily to office.
And does the round mufflers sound different from Ovals?
"Facelifts" - Do they strike a chord? Do they make THE difference? libranof1987 The Indian Car Scene 24 21st November 2011 15:23
Power valves - What are they / how do they work? chetanhanda Technical Stuff 10 9th June 2009 16:51
Economic Bubbles - Why they form and why they burst ? DCEite Shifting gears 49 20th October 2008 16:04
Santro - Dual Exhaust High Torque Modifications & Accessories 5 27th September 2008 07:26
VTEC with cut exhaust- good or bad? superunknown Technical Stuff 12 7th April 2006 07:03
