| LinkBack | Thread Tools | Search this Thread |
| | #16 |
| Senior - BHPian | Some pictures from my side. Cant wait for the mior tweaks to be fixed, so we can take the car out for a try. Last edited by m4ugr8 : 22nd September 2010 at 11:55. |
| | #17 |
| BHPian | Powder coated head cover. The car should be back in 1-2 more days. |
| | #18 |
| BHPian | Fired up again after a few mods and tweaks, Took some test drives. Now the problem comes down the gear box, The 5speed gearbox does not match the housing of the current grear box, Need shorter ratio's suggestions? |
| | #19 |
| BHPian | The car is on its final stages for mechanical work, Its lot smoother the exhust has been re tuned for a better exhaust note and performance. Videos coming soon. The engine is revving very smoothly till 7k RPM. Tyres have gone back to 12" from 13" as the alloys were causing alot of powerless. A lower tie bar has been added for weight distribution on cornering in the front. The gear box is still the biggest issue. More R&D is required. |
| | #20 |
| BANNED | Id love to see your car launch off the lights and embarrass everything else. ![]() |
| | #21 | |
| BHPian Join Date: Nov 2005 Location: Delhi
| Quote:
Can you also share what tuning in the exhaust were carried out ? Was it a bolt-on free flow exhaust or did you re-route the entire exhaust pipe? Down shifting on the wheel size is a good move. However, are there any wider section width tyres available in 12" ? Maybe you can have wider tyres in the front and regular in the rear (track days only).. Will the tie rod suffice to stiffen up the car ? Any estimate on the torque increase you may be expecting with the swap ? All the Best ! I will surely check out Phil's place the next time am in Delhi.. thanks. | |
| | #22 |
| Senior - BHPian | I had the honour of having a short drive in this car. When you sit in it with the perception of a M800, you are flabbergasted when it takes off. Takes a while to get over the way she moves. Kudos on the build Speedsport & Noidaboy !! Very off-beat & very exciting to see it go ! I hear you have been embarrassing much "larger cars" :-) Cheers |
| | #23 | |||||
| BHPian | Quote:
, Videos for you soon.Quote:
| | #24 |
| BHPian | After a few week of R&D and testing, The car was sent back to workshop. The car performing excellent as per me but according to PHIL the only 4 speed gearbox was limiting the performance. Hence he went back to his lab and finally has redone the car all over again with > High compression pistons, > Ported head > Knife edged crank > Custom 5 speed gear box ratios > Strut brace. > Bigger clutch. > Stiffer suspension. > Beefier drive shafts. Waiting for December and further runs ![]() |
| | #25 |
| BANNED | What carb are you using?? Is it a G13 spec Mikuni or a G10? |
| | #26 |
| Senior - BHPian | Oh wow so now your car will be amongst the killers at the REDLINE or what. Looking forward to see how it comes out. Wonder when my Swifty will get an empty parking slot to get the desired work done. Cheerio |
| | #27 |
| BHPian | Its a MIKUNI carb. @Ricky I hear the goodies for your car have arrived too, the wait seems over Last edited by noidaboy : 15th November 2010 at 00:45. |
| | #28 | |
| Senior - BHPian | Quote:
Oh wow, so you know before I do - eh ? Seems like you have been camping at Speedsport The last I was there, had to park outside, with all the expansion going on.BTW is your car ready yet ? Cheers | |
| | #29 |
| Senior - BHPian | Phil where art thou ? Your phone is not available !! |
| | #30 |
| BHPian | Not as yet, Engine mount modification was taking place yesterday. Here are some more pictures. |
Similar Threads | ||||
| 2lac+ kilometers m800 engine rebuild project. | SirAlec | Modifications & Accessories | 74 | 21st May 2012 11:47 |
| Engine Swap advice: Alto 1.1 in a M800 | noidaboy | Modifications & Accessories | 12 | 6th August 2010 16:14 |
| Engine Swap | need_for_speed | Technical Stuff | 2 | 21st November 2008 13:20 |
| More power from a F10a Gypsy Engine | Nahal | Modifications & Accessories | 1 | 10th November 2008 16:28 |
| m800 vs ikon (what comp can a M800 be?) | manaa45 | Street Experiences | 13 | 31st March 2005 11:06 |
