Old 1st December 2005, 21:13   #1
passionpurple's Avatar
Default palio 1.2 to 1.6 conversion
hi fellow team mates..
i was wondering if a palio 1.2L petrol car can be converted to have a 1.6L engine?
also, what all new stuff will be needed to do so.. i mean like the ecm, and other things needed to make the 1.6 engine work well..
passionpurple is offline   Reply With Quote
Old 1st December 2005, 22:02   #2
Thanked: 103,410 Times
The best thing to do would be to sell your 1.2. And then buy a 1.6. Chances are you wont even have to put in any money in the exchange, and end up with a proper factory fitted engine install.
Old 1st December 2005, 22:58   #3
khaadu75's Avatar
Thanked: 11 Times
hey, Agree totally with GTO !! You can easily get a 1.6 for about 2.2-2.4 .. so simply buy that instead of going about plonking a 1.6 engine in the 1.2 .
khaadu75 is offline   Reply With Quote
Old 2nd December 2005, 12:18   #4
desmoquattro's Avatar
but can a palio 1.2 be successfully converted to 1.6 ?
desmoquattro is offline   Reply With Quote
Old 2nd December 2005, 12:50   #5
I dont think such a thing is possible. The best thing to do is to trade your 1.2 with a 1.6 at a near by Fiat dealer as Fiat had started producing the 1.6 again. I am not sure if you would get good 1.6 specimens in the used car market now.
DOHC is offline   Reply With Quote
Old 3rd December 2005, 20:57   #6
thanks will definately think about it..
how much do you think the deal would cost?
Old 4th December 2005, 14:58   #7
Depends On what mileage ur current Palio has ,
But I think it would easily set u back between 1.75 to 2.5 lakhs depedning on the dealer and your car
Old 4th December 2005, 17:41   #8
airfoil's Avatar
Thanked: 67 Times
I'd keep an eye out for a nice used GTX and buy it, rather than plan on buying new (assuming Fiat ever gets around to manufacturing anything in India again, leave alone a GTX!).
airfoil is offline   Reply With Quote
Old 4th December 2005, 20:26   #9
shonn1's Avatar
I totally agree with Airfoil, its better to buy a second hand GTX rather than convert you're existing 1.2 to a 1.6
shonn1 is offline   Reply With Quote
Old 6th December 2005, 19:22   #10
thanks for all the help guys.. not changing any thing now. just wanted to know whether that was possible..
still for my knowledge sake, i want to know what are the different things that are changed under the hood when the engine is changed.. generally..
Problem With The Engine Rpm In Palio 1.6 After Lpg Conversion HAFI Technical Stuff 17 11th November 2010 13:34
CNG conversion on Palio 1.6 GTX bykerdawg Technical Stuff 2 23rd July 2009 19:59
Help Required: Procuring Alloy Wheel nuts for Palio (98 PCD conversion) basilmabraham Tyre & Alloy wheel Section 33 12th July 2009 12:40
Palio Mods (TC, ECM, & Rear Disc Brake Conversion) sbfx Modifications & Accessories 37 25th May 2007 20:11
Fiat Palio 1.2/1.6, Is LPG conversion advisable. Dhanan Hatchbacks 9 27th September 2006 18:09
