Old 5th December 2005, 19:28   #16
speedsatya's Avatar
Thanked: 712 Times
Thumbs up
Originally Posted by viper.
@ Satya - This process works even better on ventilated discs. Only ventilated discs dont solve the fading as most people are facing.
wow...so how long does this whole process take ...and how much does it cost ?????
and this will require skilled labour as when u drill holes,one end of the disc will be rough beacsue of the drill bit coming out ..so it will have to be polished perfectly to remove the rough edges..
speedsatya is offline   Reply With Quote
Old 5th December 2005, 19:35   #17
falcon's Avatar
Just a thought...
Braking works better when the surface area in contact is larger. i.e. larger pads and discs would provide better breaking. This in turn also means more heat being generated.
Now, by cross drilling, we would be reducing the effective surface area of the pads touching the discs... so, cooling would sure be better...
BUT does this mean we are reducing the breaking efficiency ???
meaning Weaker brakes ???
falcon is offline   Reply With Quote
Old 5th December 2005, 19:49   #18
viper's Avatar
Thanked: 9 Times
Hey Satya,
I know thats why I said it almost takes a day. I charge approx 1500 including labour for opening and refitting the discs.
@Falcon - No infact the brakes bite better but you reduce the life of your brake pads by say 5-10%.
Viper
viper is offline   Reply With Quote
Old 5th December 2005, 20:01   #19
falcon's Avatar
Thanks for the clarification Viper.
Wanted to get the brakes on my Contessa overhauled... will ask about this as well when I go to the garage.
Falcon
Old 5th December 2005, 20:08   #20
autopsyche's Avatar
Thanked: 15 Times
As you mentioned brake system overhaul includes new pads and new brake fluid and sometimes new disc rotors if theyre in a bad shape. Ventilated discs do help in quicker heat disspiation.
Brake fluid has a certain boiling point i think it is around 130 or 150 degrees ill check up on exact point later. Old brake fluid keeps getting contaminated with moisture which slowly brings its boiling point down towards the 100 degree water mark thus decresing its capacity to provide efficient force. I have a Brake fluid tester with me which i got from germany for the same purpose.
Also do check what specification fluid your car runs on. Most of the new ones are on DOT 3 which is the first recommended upgrade if your car uses DOT 2.
Arush
autopsyche is offline   Reply With Quote
Old 5th December 2005, 20:09   #21
viper's Avatar
Thanked: 9 Times
Arush
Hey Arush,
I think most new cars are either on DOT 3 or DOT 4. The best being DOT 4.
Viper
Old 5th December 2005, 20:28   #22
autopsyche's Avatar
Thanked: 15 Times
yes viper i guess i goofed up there, dot 3 is standard, upgrade is dot 4. thanks.
2013 Skoda Octavia TDI: Headlight Assembly Fading @2500kms vikramv007 Technical Stuff 46 26th December 2014 17:50
Sports car fad fading away says BMW sales chief Tushar The International Automotive Scene 3 14th November 2014 18:24
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Pulsar 180 - color fading issue asriyazudeen Motorbikes 14 23rd November 2007 19:31
