Old 25th October 2010, 11:34   #76
sgiitk's Avatar
Thanked: 3,884 Times
@nitrous: Till March the detune made sense, since BS2 was only 88RON. After 1 April 2010, or more precisely 30 September 2010 (given the grace period) with BS3/BS4 we have 91RON across the board. So the detune is a historic artefact.
Also, any idea when will be see BS3/BS4 Premium (at 95RON), or will they continue flogging non-Premium (as per specs), with additives forever?
sgiitk is online now   Reply With Quote
Old 26th October 2010, 18:50   #77
Wow!!! the torque curve looks impressive considering a Naturally aspirated Gasoline Engine.
How much increase in torque you are expecting at the low end. Also u need to seriously consider upgrade in the power train and braking if you are planning to put turbo at the later stages.
TurboGuru is offline   Reply With Quote
Old 26th October 2010, 23:41   #78
cvc2145's Avatar
Thanked: 16 Times
Not significant gains, but in the range of 5 - 8 BHP from a good remap?
If they shift the VTEC point, then it would see gains but just for that part. However, it cannot make alot of any other difference because of the fact that even when you modify the air going/coming from the engine, the MAF sees that and the ECU adds more fuel accordingly. Stock ECU's already maintain a rich afr at WOT. Finetuning that too wouldn't make too much difference, something that might not even be noticeable.
The FIC I installed, I'm still yet to tune. But I've changed the oxygen sensor values for light acceleration. This has really given a new kick to the car. Even at the slightest push of the pedal, the car readily jumps forward. However, acceleration at full has only changed to a point which cannot really be distinguished from the placebo effect.
Ill be tuning the car next week. I had called for the wideband, intake manifold and injectors which I've received, but yet to install. Thought Ill tune it all together so got to wait until I'm done installing it.
This really sucks. I've seen what a set of mean headers could do (in my OHC Vtec). I don't understand why Honda had to take this route when they know enthusiasts will be part of their customer base.
As far as I know, Honda never designed this engine with performance mods in mind. The CAT was integrated to offer lesser emissions because of the quick warm up and higher temperatures. Our engine block isnt designed to handle alot of pressure too. If boosted high, it will crack because of the weight saving measures taken by Honda. I wish that they had launched the k20 version of it here. Would have been a great advantage for enthusiasts like us.
cvc2145 is offline   Reply With Quote
Old 27th October 2010, 00:44   #79
dhanushs's Avatar
Thanked: 4,504 Times
Originally Posted by anku94 View Post
I'd love if someone could clarify the terms torque and power to me.
Please refer http://www.team-bhp.com/forum/techni...ue-vs-bhp.html (Torque vs BHP?)
Old 27th October 2010, 12:24   #80
GForce1980's Avatar
Thanked: 13 Times
The Honda K20 is a 2000cc DOHC iVTEC Naturally Aspirated enging producing a whopping 197bhp & this is available in the US in the Civic Si model.
The bad news is, it produces just a little more torque than the 1.8 SOHC iVTEC that too at much higher rpms. To quantify, 139 @6100 rpm in the 2.0 Vs 128 @4300 rpm in the 1.8 version. Also, it drinks premium fuel only due to its high compression ratio of 11:1. It also drastically reduces the fuel effeciency as compared to the 1.8 version. In the "Average kitna hai" country like ours, there is no market for such an engine.
GForce1980 is offline   Reply With Quote
Old 28th October 2010, 04:44   #81
hey cvc2145,can you please elaborate on the intake manifold and the injector's that you are going to install on the r18a engine,thanks
dragger is offline   Reply With Quote
Old 28th October 2010, 07:29   #82
Hello GTO
Good to see the performance list for your car, iam sure the list keeps going up in variation with time , any plans of upgrading brakes and tyres? Is remap possible for all petrol cars or only to certain brand cars?
challa is offline   Reply With Quote
Old 28th October 2010, 22:19   #83
Thanked: 103,507 Times
My primary expectation (and what I ended up with) is way better throttle response at low rpm. The car is puff cake to drive in traffic now. Of course, the sound is to die for.
That sounds awesome, hopefully I'm going to end up with similar results.
I'm extremely happy with the Civics brakes. Period. If & when I feel a need to upgrade, the after-market support for this car is phenomenal. Bolt on stuff, really.
Yes, wheels & tyres are on the to-do list.
Remaps are possible for most popular cars. The grey area is, how effective they actually are on N/A (non-turbo) cars.
Old 28th October 2010, 23:05   #84
anekho's Avatar
Thanked: 661 Times
Any chance of a video clip?
anekho is offline   Reply With Quote
Old 29th October 2010, 13:21   #85
Thanked: 312 Times
GTO, so its the bolt on end can exhaust that you have installed? please let us know the brand, place and the price ofcourse. Can you also tune it w/o the sound?
The Saint is offline   Reply With Quote
Old 30th October 2010, 20:43   #86
Akshay1234's Avatar
Thanked: 7,242 Times
So the car was dynoed, and im gonna let GTO reveal the rest, and Rehaan can put up the pics. There was also an Accord V6, a VW Jetta, a remapped Linea 1.4, and a Fusion which were dynoed.
Old 31st October 2010, 17:18   #87
Thanked: 212 Times
@GTO, eagerly awaiting the dyno update!
lancer_rit is offline   Reply With Quote
Old 1st November 2010, 12:22   #88
Done. We've taken one at the time of the run. Will take another video that focuses only on the sound.
I got a full free flow exhaust (not just a muffler change) that runs from the engine to the tail. Unfortunately, the Civic's engine cannot accommodate aftermarket headers. Full stainless steel unit cost 20K. Automech is the best in the business when it comes to exhausts. The one I had in the Vtec didn't run a bolt loose in 3 years!
Receiving charts from KS Motorsports this afternoon.
Old 1st November 2010, 12:22   #89
Thanked: 152 Times
When can we see the Video?? Looking forward to the Charts too.
Cyrus43 is offline   Reply With Quote
Old 1st November 2010, 14:45   #90
Amey's Avatar
Thanked: 189 Times
If its not too much of an effort, could you post pics of the engine bay ? I am keen to see how Automech made the downpipe.The mouth where the headers meet the downpipe has a weird shape right ?
Amey is online now   Reply With Quote
My Turbo R18 Honda Civic. EDIT: End of an era... Nikhilb2008 Modifications & Accessories 147 19th April 2018 11:03
Race Dynamics dyno database of Stock cars Racedynamics Modifications & Accessories 82 30th October 2017 18:02
Honda Civic Dyno Run no.2 - With performance exhaust GTO Modifications & Accessories 69 9th October 2014 14:57
Honda Civic Dyno Run no.3 - With K&N Typhoon air intake GTO Modifications & Accessories 41 12th January 2012 10:39
