Old 7th November 2010, 12:20   #1
Thanked: 13 Times
Default Illumination for power window buttons etc.
So I bought a 9L rupee Hyundai Verna two years ago. Its shameful that except for the power window button for the driver, none of the power window buttons have lights on them to find them in the dark. This is for both, the switches on the individual doors as well as the driver side master panel with all 4 power window controls.
Similarly, many other buttons don't have lights on them including the ORVM adjusters, inside roof light etc etc.
I have since started using other cars, but my dad for his occasional drives uses the Verna and is mighty pissed about this.
Is there an after-market solution available?
barcode is offline   Reply With Quote
Old 7th November 2010, 12:47   #2
sajands's Avatar
Thanked: 135 Times
I too have a Verna, I guess placing a small LED for all 3 door power window buttons and connecting the wiring to the master panel switch should work, again, easier said than done.
sajands is offline   Reply With Quote
Old 7th November 2010, 13:05   #3
mukundmenon's Avatar
Thanked: 27 Times
it is pity! Even a sub 6L Ford Ikon comes with lights on Power window bottons all around.Try getting the lighting unit from it, ie if it is possible.
mukundmenon is offline   Reply With Quote
Old 7th November 2010, 15:22   #4
wildon's Avatar
Thanked: 1,040 Times
^^ For that i like the Fiat Linea illumination feature. If you lock/disable the power windows button from the driver side, the illumination at the back door buttons also goes off to indicate its been disabled.
wildon is offline   Reply With Quote
Old 7th November 2010, 17:36   #5
Thanked: 71 Times
Get some 'radium' stickers. That's the easiest fix I can think of. If there is sufficient light falling on the stickers during the day, they will do the job for you in the dark.
salilpawar1 is offline   Reply With Quote
Old 7th November 2010, 18:36   #6
rkg
Thanked: 543 Times
Even Indica Vista has them.
but even Innova V version also does not have them
rkg is offline   Reply With Quote
Old 7th November 2010, 18:40   #7
V-16's Avatar
Thanked: 844 Times
Its not possible to fix an led. Well maybe possible but not practical as you'd find out when you set your heart to get it done. Best option so far is Salil's, to get some radium tapes and fix them. Secondly one could get some buttons with the lights inbuilt but that would be hard to source.
V-16 is offline   Reply With Quote
Old 7th November 2010, 20:39   #8
drchernish's Avatar
Thanked: 60 Times
my verna has them.strange?
drchernish is offline   Reply With Quote
Old 8th November 2010, 15:49   #9
Thanked: 89,535 Times
Best avoided. It's too much of a hassle for something that doesn't provide any utility at all.
Even my humble Indigo does.
That's just really cool. One of the "little things" that add to a feel good factor.
Strange indeed. Perhaps its one of the things that underwent the cost-cutting knife as the manufacturer thought no one would notice. My '03 Benz had a height-adjustable driver armrest that's been conveniently removed in the '05 facelift.
Old 8th November 2010, 16:14   #10
anujmishra's Avatar
Thanked: 338 Times
Even TATA Safari LX has this feature. All power window switches are illuminated. If driver disable power window for back windows then illumination also goes off for back windows switches.
anujmishra is offline   Reply With Quote
Old 8th November 2010, 17:25   #11
shyamhegde's Avatar
This is the easiest approach that can be tried.
shyamhegde is offline   Reply With Quote
Old 8th November 2010, 19:15   #12
gautamkhadse's Avatar
Thanked: 153 Times
I dont think such a small feature would help them save costs . If the panel on the drivers side can have one switch lit up I dont think adding 3 more LEDs for 3 more switches would raise costs . Its a perfect example of penny wise pound foolish . Even the humble pulsar has back lit switches .
I guess adding the radium strips should do the job .
I dont mean to offend anyone here , but I can find the switches on my punto with my eyes closed even though they are back lit . After using the car for some time , one kinda gets used to the position of the switches . Its a different story when you drive different cars everyday.
gautamkhadse is offline   Reply With Quote
Old 11th November 2010, 17:50   #13
shyamhegde's Avatar
When you drive with your visitors, relatives in the car, during night it is going to be helpful for them if switches are backlit. Or else, you have to switch the cabin light ON to make them see the switches. Not everyone will be familiar with switch positions of all car. Check, some of us here itself, might find it hard to get to the controls eyes closed, if you ride in the backseat.
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Swift needle illumination- need advice akash_m Technical Stuff 9 24th September 2008 21:01
Every Swift has an Illumination control akash_m Technical Stuff 13 3rd April 2008 13:31
Dashboard Illumination adityamunshi Modifications & Accessories 7 27th June 2007 17:19
What are these buttons meant for ? rr_zen Technical Stuff 4 14th May 2007 15:22
