Old 22nd November 2010, 11:08   #76
Jaggu's Avatar
Thanked: 8,693 Times
Its best not to compare results between different dynos at different places at widely different times.
I've a more interesting question. If say Bangalore had another shop with a highly regarded dyno (say Dynojet) which consistently gave higher readings, other things being equal (esp. cost) where would you take your car to be dynoed?
Completely agree, lets not get into dyno comparison now. And i would take my vehicle to a dyno which will show consistent readings, with multiple runs
Originally Posted by im_srini View Post
Hi Jaggu, is the shock-dyno meant for use by Red-Rooster's rally & racing teams only ? Can anybody (me, for example) send them a set of dampers to be tested (i.e. have the dyno graphs generated) ?
Not only rally, they use it to tune the dampers they sell to their customers. Am not sure about the dyno at rental mode. You can always give them a call and check.
Old 22nd November 2010, 19:12   #77
kutlee's Avatar
Thanked: 202 Times
Originally Posted by Ford Rocam View Post
Yes, Usually dyno runs are done on 3rd gear pull and will show most accurate reading, I am not sure why they are doing it on 4th gear here, can somebody ask them why? also if u dyno on 4th gear your readings will be low.
to keep things simple since 4 gear close to 1:1 ratio. They are not taking pains to do 3rd gear with correct ratio for each car. Next time i am making sure the guy is making 3rd gear run.
kutlee is offline   Reply With Quote
Old 22nd November 2010, 21:01   #78
Thanked: 2,404 Times
Why? If the dyno rpm is within its design range, and has been calibrated accordingly.
Sutripta
Old 22nd November 2010, 21:12   #79
im_srini's Avatar
Thanked: 399 Times
Question
I'm not sure if this is the only reason they're conducting the runs in 4th gear. True, in almost all cars, 4th is very close to 1:1, but you still have the final drive (on the differential) to contend with. Does this dyno have an option of the operator simply entering the 4th gear & final drive ratios ? That should eliminate all ambiguities right ?
im_srini is offline   Reply With Quote
Old 22nd November 2010, 21:59   #80
'Close to', and 'not close to' should not really make a difference. In older cars, in 'direct top' power was not routed through the gears, thus no losses from that account. Nowadays, gearboxes are all indirect.
Computationally, scaling should not be a problem at all.
Entering the gear ratios might be a good way of checking the cars OE tacho. Speedos overread afterall! On a roller dyno (not the Dynapack), it would be very difficult to preworkout a engine rpm to roller rpm ratio.
Sutripta
Old 23rd November 2010, 13:32   #81
goandude's Avatar
Thanked: 455 Times
Went though the entire very interesting thread. Didn't find a graph of the DDIS engine. Would someone do the needful, thanks.
goandude is offline   Reply With Quote
Old 23rd November 2010, 19:22   #82
Vid6639's Avatar
Thanked: 21,086 Times
Here's the dyno results from the Bangkok taxi.
Peak HP = 95. Notice how much torque is available from 2500rpm.
Open House at *Red Rooster (Bangalore)*. Free dyno run, demo drives and facility tour-altis_dyno.jpg
Old 24th November 2010, 10:51   #83
Jaggu's Avatar
Talking Some teasers for GTO !
The RRR Civic.
Open House at *Red Rooster (Bangalore)*. Free dyno run, demo drives and facility tour-photo-1.jpg
And its exhaust system, some snaps i had taken. What i liked most was the quality, both that of the products and the installation. Truly world class stuff.
Attachment 458467
Open House at *Red Rooster (Bangalore)*. Free dyno run, demo drives and facility tour-photo-3.jpg
Open House at *Red Rooster (Bangalore)*. Free dyno run, demo drives and facility tour-photo-4.jpg
Open House at *Red Rooster (Bangalore)*. Free dyno run, demo drives and facility tour-photo-5.jpg
Jaggu is offline   (1) Thanks Reply With Quote
Old 24th November 2010, 10:59   #84
Ricky_63's Avatar
Thanked: 394 Times
Originally Posted by Jaggu View Post
The RRR Civic.
Attachment 458466
Attachment 458467
Attachment 458468
Attachment 458469
Attachment 458470
Those snaps are a treat. Brilliant workmanship. Hats off to RRP for the quality !!
Thanks for sharing the pics
Old 24th November 2010, 13:20   #85
wildchild4lyfe's Avatar
My oh my!!
what bhp is it putting out ?
wildchild4lyfe is offline   Reply With Quote
Old 24th November 2010, 14:11   #86
Thanked: 103,674 Times
The RRR Civic.
What classy plumbing, those pipes look good enough to eat.
- Running a turbo? Cost?
- Who owns it?
- How much did she put out on the dyno?
Old 24th November 2010, 19:14   #87
Thanked: 11,075 Times
Leela told me it is not running a turbo yet but all the plumbing etc is in place for it
Old 24th November 2010, 21:27   #88
Ricky_63's Avatar
Thanked: 394 Times
After the turbo goes in what Whp should one expect ? 200 or thereabouts ?
Old 24th November 2010, 21:34   #89
Here is my swift diesel dyno readings. sorry for delayed post, swiftD has put on 25,700km on its odometer at the time of she undergoing the dyno test and its a stock.
if i remember correctly leela mentioned honda, toyota were consistent in there bhp out put but not so with maruti
Open House at *Red Rooster (Bangalore)*. Free dyno run, demo drives and facility tour-2.jpg
Dreamy is offline   Reply With Quote
Old 25th November 2010, 08:36   #90
goandude's Avatar
Thanked: 455 Times
Thanks for posting, but the graph is very different from this http://www.team-bhp.com/forum/modifi...tml#post433632 (Pete's Tuning Box for Swift DDiS)
where the peak torque comes on at about 2k rpm
Baleno - now with a Red Rooster free flow spider77 Modifications & Accessories 58 23rd November 2014 21:42
Red Rooster Performance sets up a 2nd shop in Bangalore! suhaas307 Modifications & Accessories 34 21st January 2014 12:49
Bangalore! - A new tuner in town - Red Rooster Performance Harrie Modifications & Accessories 70 28th March 2012 09:57
Open open open Sesame!! VJ_MAVRICK Shifting gears 12 10th January 2008 15:24
