Old 19th November 2011, 01:29   #301
Thad E Ginathom's Avatar
Thanked: 6,593 Times
Default re: "Child Seat" for Babies & Kids
Nothing's perfect. The rear-facing child could still suffer whiplash injury in case of a car being rear-ended --- and lots are. However, we have to do the best we can, with the best gear that we can.
jinojohnt's post about head and neck is very well reasoned. Another factor can be added though, which is that the forward-facing child is thrown forward against the straps of their seat belt. True, this is a lot, perhaps life-savingly a lot, better than being thrown forward without it, but it it still a lot of pressure against a much smaller area than when a child is thrown backwards against its seat, where the whole body takes the strain.
The strain, also, can be minimised by making sure that the child's belts are absolutely snug. It's better if the child is not thrown anwhere, not even a fraction of an inch.
Imagining the following experiment should be enough...
--- Open a door an inch or two. Put your fingers against the door post, and gently flick the door shut with the other hand. You'll just catch the door.
--- Open the same door six or nine inches and flick it too on your hand. This one might get an ouch!
--- Open the same door two or three feet. Shutting it on your hand now would be almost as silly as not wearing a seat belt, or restraining your child properly, in a car.
Thad E Ginathom is offline   (3) Thanks Reply With Quote
Old 11th December 2011, 17:42   #302
vb-san's Avatar
Thanked: 3,441 Times
Saw this Trunki backpack / child seat (4-12 yrs) in the Mothercare store here (in Singapore). Not sure if this is available in India, but I found the concept quite interesting.
http://www.trunki.co.uk/categories/boostapak_9
vb-san is offline   (1) Thanks Reply With Quote
Old 15th January 2012, 04:44   #303
smrtdvl's Avatar
Thanked: 65 Times
Phew finally got a rear / front facing child seat for my angel and to our surprise 90% of the times she doesn't mind sitting on it. I've heard lot of stories about all the tantrums thrown by those little warriors in order to get out of the child seat once they are put in. But for us it was a dream come true and no nightmares
Brand: Chicoo
Cost: 9500 MRP 9990
She is totally comfortable in it and we made sure she gets used to it by making my wifey sit next to her for a few initial drives and now she is all excited once I put her in the child seat as she knows that we are going out on a drive.
smrtdvl is online now   (4) Thanks Reply With Quote
Old 15th January 2012, 07:23   #304
Hayek's Avatar
Thanked: 1,584 Times
Originally Posted by smrtdvl
Phew finally got a rear / front facing child seat for my angel and to our surprise 90% of the times she doesn't mind sitting on it. I've heard lot of stories about all the tantrums thrown by those little warriors in order to get out of the child seat once they are put in. But for us it was a dream come true...
Please persist with it even if she throws the occasional tantrum. it's important, and will become as natural as wearing a seat belt is to us.
Hayek is offline   (2) Thanks Reply With Quote
Old 14th February 2012, 14:44   #305
arvind71181's Avatar
Thanked: 676 Times
I have got a car seat which I am using for my 3 month old. The seat can be used both as a forward and rear facing one. Right now it is being used as a rear facing one. I just wanted to know if there are any general guidelines on when the rear facing one has to be changed to be forward facing. Thanks
arvind71181 is offline   Reply With Quote
Old 14th February 2012, 15:05   #306
bblost's Avatar
Thanked: 6,270 Times
The child seat, I have, has a sticker that recommends using it rear facing till the child weighs at least 10 kilos.
bblost is offline   (1) Thanks Reply With Quote
Old 14th February 2012, 15:18   #307
Thanked: 676 Times
Thank you. One more query which I had. How will I tie the seat belts around the same car seat when it becomes a forward facing one? Right now I am able to take my seat belt around the specific points where I have to fit them but I fail to comprehend how the same can be done when the seat is forward facing. How do we do this?
Old 14th February 2012, 15:22   #308
bblost's Avatar
http://www.team-bhp.com/forum/modifi...ml#post2478250
If you look closely you can see red dots and blue dots.
The seat belt runs thru red dots when seat is forward facing and blue dots when rear facing.
Old 14th February 2012, 15:57   #309
S_U_N's Avatar
Thanked: 375 Times
Good to hear about this.
But, based on the photo, it seems that there is lot of lateral movement of head possible.
I think an inside cushion/ pad would be supplied with the car seat.
Why aren't you using that? It will reduce the free space for lateral movement of head, plus the padding will be very soft compared to the padding at the sides (where the baby's head is resting in the photo).
S_U_N is offline   Reply With Quote
Old 14th February 2012, 18:29   #310
smrtdvl's Avatar
Thanked: 65 Times
Yeah there was a cushion supplied along with it. In fact the cushion is super soft compared to the sides. But it reduces the seating place so I thought it's better to remove it but will give it a try again.
smrtdvl is online now   Reply With Quote
Old 15th February 2012, 08:09   #311
selfdrive's Avatar
Thanked: 1,821 Times
The idea is to fit them babies snug and cosy in the car seat. and not leave any space around
I recommend putting it in there as soon as you can. Once the child is used to the extra space, he/ she may start tugging at the cushion to remove it!
selfdrive is offline   (1) Thanks Reply With Quote
Old 15th February 2012, 10:07   #312
Thanked: 676 Times
Went yesterday and checked out my child seat and saw that it is only a rear facing seat and I can keep my daughter in the seat till she reaches 13kgs. Assuming that the kgs will equate to around a year, I am now having a doubt of whether the child will be able to fit into the rear facing seat for that long. Guess I will have to buy another one for her soon
Old 15th February 2012, 11:36   #313
bblost's Avatar
Most kids are just around 8-10 kilos on their first birthday.
Old 17th February 2012, 11:18   #314
dynomite's Avatar
Thanked: 78 Times
Well my son is about 9 months old and he weighs 9kgs.
The car seat that we have is a rear facing Graco (see below) - problem is not the weight, but that he is getting too long for it.
Each car seat has a particular specification (weight/age range) - he is within the weight range for the seat, but we will still need to get a forward facing one because he is getting too long for it.
I saw a forward facing seat from Chicco that can adjust - from 9kg onwards, all the way up to 16kg. Costs Rs 9k, but worth it IMO.
cheers
dynomite is offline   Reply With Quote
Old 17th February 2012, 12:59   #315
S_U_N's Avatar
Thanked: 375 Times
^Talking about height of child, my kid (3 years, 13 KG, 3 ft) still getting used to the child car seat (after 8 months).
Of late, we find that there is no place to rest his legs which keep hanging in front of the child seat and behind the driver seat.
So, whenever possible, we put a small plastic basket behind the driver seat and below his legs. This gives him some support to rest his legs and is useful for long journeys.
What works for us:
1.He is more comfortable when AC cooling is increased.
2. We put thin cotten towels on both windows to prevent sun rays from getting in (our sunfilms are 5 year old)
3. We put a small square pillow behind his head to give him some head support.
4. We have also removed the inner cushion, but our child is much bigger and really cannot fit in with the cushion in place.
Indian cars to become "Child Seat" friendly from October 2014 mints21 The Indian Car Scene 18 20th May 2016 15:38
Asta la vista babies Asta_la_vista Introduce yourself 5 15th October 2015 19:13
Carkoon- Enhanced Safety Child Car Seat flyingkolors Modifications & Accessories 4 16th January 2013 00:02
Babies Day Out - Hosur OTR Report - 3-Jul-10 svsantosh 4x4 Excursions 42 7th July 2010 18:59
