Old 5th February 2011, 16:41   #136
Default Re: Re-Mapped Optra Magnum TCDI. EDIT:Dyno Graph on Pg 4
so anyone want to shed more light on why the tcf was changed from 1.00 to 1.26,was is done by people at RRR or was it done by the tuner on demand,please do shed more light,cheers,happy revving..!
dragger is offline   Reply With Quote
Old 6th February 2011, 15:25   #137
brraj's Avatar
Thanked: 354 Times
Originally Posted by crazydiablo View Post
The i20 has just a remap? Man I am getting a feeling I will move to diesels for my next car project.
What all mods is the Cruze running, any idea whats the approx cost? Any handling upgrades on the i20?
Both Cruze & i20 are running on just a remap.
45k for Cruze remap and for i20 i didnt check it.
You have handling upgrades for i20 aswell, Best man to talk to is the tuner.
As mentioned you can check it directly with tuner/RRR guys.
brraj is offline   Reply With Quote
Old 7th February 2011, 00:38   #138
aa_asif's Avatar
Thanked: 42 Times
i20 could act funny while high speed cornering in stock condition.
I would prefer a stiffer suspension and a better rubber when I go for a remap. I guess the stock brake setup should do fine as it comes with all round disc brakes.
Is it possible to do this as a silent setup?? cos I really don't wish to screw up my warranty as the car is only 5 months old.
aa_asif is offline   Reply With Quote
Old 7th February 2011, 10:05   #139
brraj's Avatar
Thanked: 354 Times
True, before remapping i would recommend for a suspension job, good rubber on an i20.
Not many will come to know if you remap your car.
Old 11th February 2011, 12:27   #140
crazydiablo's Avatar
Thanked: 21 Times
Was at RRR yesterday for a dyno run. I got to check out all these car dyno reports. I have to say that TDI racing has set a new benchmark in diesel tuning.
The Cruze and the i20 just blows my mind away. Saw the i20 dyno chart also, i guess its not posted up. I wish you guys all the best and continue churning out more and more fast cars. Please keep a log chart on the kms done also.
crazydiablo is offline   Reply With Quote
Old 11th February 2011, 17:37   #141
crazy diablo,since you were at rrr yesterday and you had a look at the dyno reports,did you happen to ask them as to why the tcf was changed from 1.00 to 1.26 in case of all tdi racing dyno sheets?
Old 11th February 2011, 19:29   #142
Thanked: 21 Times
No I did not. Even my run was was with TCF 1.00.
Old 11th February 2011, 19:58   #143
aa_asif's Avatar
Thanked: 42 Times
Just called up Pete's, PSI Tuning box is not yet out for i20 CRDi 6-Speed. Green Cotton Replacement Filter is also not available.
I want to stay away from CAI option as of now for the warranty reasons.
Old 12th February 2011, 00:52   #144
CPH
Thanked: 34 Times
Tuningboxes can also be detected. The data logger in the ECUs log on a lot more than previous generations. The EDC17 ECUs are getting extremely smart.
CPH is offline   Reply With Quote
Old 11th March 2011, 11:03   #145
brraj's Avatar
Thanked: 354 Times
Can a magnum be made a 4x4?
Currently thinking of placing captiva 4x4 system in magnum.
What are all the issues that may crop up with this mod? what about reliability?
Old 11th March 2011, 14:52   #146
Akshay1234's Avatar
Thanked: 7,243 Times
Its not gonna be that simple. Youll have to get the 4wd system, new gearbox, ECU maybe more parts. Then youll lose gound clearance with the rear driveshaft. Not worth it IMO.
Old 14th March 2011, 10:20   #147
brraj's Avatar
Thanked: 354 Times
True
Spoke to the tuner says - as captiva belongs to the same family it will not be much of a burden.
Compared captiva's 4wd system to other 4wds systems like endeavour, safari.. Captivas has a independent suspension setup like magnums so its easy to install is what tuner says.
How come other cars like lancer evo, audi or any other AWD sedans work without GC issues?
Old 14th March 2011, 11:26   #148
Akshay1234's Avatar
Well if your tuner can do it then thats great buddy. I'd love to see such a conversion.
Well I dont have details about the Captiva's 4WD system but I just thought that since its built for an SUV with much higher clearance if its adapted to a car the clearance would reduce.
With the Evos and all, the AWD system is built for a car itself, hence no GC problems as such.
Just my thoughts.
Old 14th March 2011, 15:28   #149
Psycho's Avatar
Thanked: 95 Times
Don't know if the drivetrain is going to be a bolt and if it will require tons of changes under the body including the floor pan taking away the rigidity of the frame. If so it is not a risk worth taking.
Old 14th March 2011, 16:41   #150
mobike008's Avatar
Thanked: 8,319 Times
Brraj, great to know that you have re-mapped your Optra to a whopping 180PS. And, also seen that a Cruze has been pumped up to 223PS.
Its been a few months now since you got these upgrades. It would be nice to hear your feedback on the difference, issues ( if any) post the re-map. Does the car smoke more now under hard accelaration?
Also, is that Cruze just with a re-map or its clutch and brakes too have been upgraded. Sorry if its already mentioned somewhere on this thread. I am also in particularly keen to know an update on how the Cruze is doing post the re-map. I am not sure if you have an update on it as well.
My Honda City Vtec - RRP Dyno report - Graph included fieroid Modifications & Accessories 29 25th October 2012 16:49
My TURBO-Charged Swift Petrol! And a dyno graph too Sportsmind Modifications & Accessories 43 8th September 2011 02:40
Accord V6, mapped Linea, Fusion & Jetta on the dyno! UPDATE: Comparo on pg3 GTO Modifications & Accessories 69 14th January 2011 18:06
1st ever Dyno Graph of my Turbocharged Hybrid OHC (320+ WHP!) Ford Rocam Modifications & Accessories 316 15th November 2010 19:44
Modded Skoda RS Dyno Graph KS Motorsport Modifications & Accessories 30 21st October 2010 10:59
