Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 19th December 2005, 14:02   #1 (permalink)
Default Custom Job for Petra Suspension ?
Whew! It took me 6 attempts to get the graphic right while trying to register!!
Anyway, I have a question for the guru's here. I have a 1 yr old Petra. Its a great car except for the suspension. It was just OK to begin with. I had high speed tubeless tyres put in to reduce the body roll in curves and it has made the suspension really bad on rough roads and seams between blocks on bridges etc. There is a spine jarring thud at high speeds. BUT, its very smooth over large bumps or big pot holes. Its the small rough patches that really irritate and given bombay roads the ride quality is quite lousy at times. Remember the western express highway after the floods ?
Anyway, I'm looking for some custom job to make the ride much more cushy, to avoid having to spring for a costlier car just for the suspension. The only idea i have had so far is to put a lot of sponge inside the seat cushion. I know that changing the tyres may help a bit, but I'm looking for a big difference. I think softer springs in the seats will help (like 118 NE or Amby).
Does anyone know a garage that will help me with this. I have tried Anuroop and all they are willing to do is to service the stock suspension or replace parts.
thanks in anticipation.
Vinod
dovin4 is offline   Reply With Quote
Old 19th December 2005, 15:34   #2 (permalink)
dovin,
The ride of the Palio/Petra if you are using 175/65 or lower profile tyres, is sensitive to tyre pressure. I normally keep the presure at 27 psi for my S10 (175/65) and the ride does improve. What size boots is your Petra wearing?
Floyd de Souza is offline   Reply With Quote
Old 19th December 2005, 15:49   #3 (permalink)
floyd,
I'm using 185/60 15" Certis tyres. I keep the pressure at 27 PSI. I've tried reducing it to 26 PSI. It does improve the ride a little bit, but I'm nervous about the FE as well as life of tyres.
The ride quality is nice when driving on heavily potholed roads, but on rough patches with caked mud or small 'cuts' in the road due to cracked pavement or covered up digging, the entire 'jerk' transmits right to your spine. I'm so unhappy with this because my friend's esteem has a much softer ride in these situations even though it gets rattled over heavy bumps or potholes.
I want to understand what Maruti (for eg is doing right that I can replicate on the Petra.
Also, the ride is noticeably better at nights!!
Is it possible for the local garage to adjust suspension settings ? make it softer ? or is this set only at the factory ?
Thanks for your reply!
Vinod
Old 19th December 2005, 16:12   #4 (permalink)
speedsatya's Avatar
Vinod
Can you please explain this??????????
speedsatya is offline   Reply With Quote
Old 19th December 2005, 16:18   #5 (permalink)
I know its weird, and i have 2 possible reasons for this..
1) The air in the tyres are cooler, hence softer ride.
2) I have a driver during daytime, but I drive myself when going out at night. The front seat somehow had better ride comfort.
3) Something else ????
Old 19th December 2005, 16:55   #6 (permalink)
Originally Posted by Floyd de Souza
dovin,
Isnt 27psi too low ?.. I have 175/65/R14( Stock) on my Siena 1.6ELX ..28-30 is what is recommended..
I usually keep it at 30 psi...Although as you mentioned..the Rumbling sound on slightly uneven roads at low speeds or on small bumps..is sometimes dissapointing..
__________________
kya !! sab theek hai ???
paharino1 is offline   Reply With Quote
Old 19th December 2005, 17:34   #7 (permalink)
hellspawn's Avatar
even i own a siena 1.6elx and it rides on 175/65 r14....the ride is pretty comfortable over rough roads but small cracks or bumps on the road do make themselves felt.....as u already have fitted even more low profile tyres(185/60 r14),thats where the problem begins.my advice to u wud be to drive somenoes palio nv and see how u feel in terms of ride comfort.if u feel satisfied with it,you have ur solution.the palio rides on 165/70 r13(members pleez correct if wrong).so yo can shift to these higher profile tyres and smaller rims but it is goin to spoil ur cars handling and looks to some extent.
__________________
The trouble with life is there's no background music
hellspawn is offline   Reply With Quote
Old 19th December 2005, 17:45   #8 (permalink)
1) Are you sure about Tyre pressure? Where do you check it (is it reliable enough)? Anything below 28 should be very comfy (front or rear). Suggested tyre pressure is 28.
2) I am very sure that ride at rear is more comfortable than at front. Do you know any other Petra owner (remote possibility)? Sit in his car and compare with yours.
__________________
Drive fast, but drive safe.
RX135 is online now   Reply With Quote
Old 20th December 2005, 22:36   #9 (permalink)
Does anyone know if its possible to change the suspension settings for the Petra if I take it to a garage ?
Old 20th December 2005, 23:18   #10 (permalink)
The Wolf's Avatar
There are loads of custom stuff you can do with your suspension for handling but for a smoother ride you have to get the right set of tyres and pump it with right air pressure. Now, you mentioned that the car glides over potholes and craters but vibrates on rough surfaces, my advise would be minimum 27psi considering your tyres but from a reputed air pump booth. Also, get the allignment & balancing done. Try rubber dampers on your front struts. This should help.
__________________
I cried coz I had no turbo, till I met a man who had no VTEC!!!
The Wolf is offline   Reply With Quote
Thread Tools
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Custom Paint Job For A Black Scorpio DHABHAR.BEHRAM Modifications & Accessories 163 5th August 2008 17:19
Need to get a paint job and Suspension job in Pune for my Santro vinit.merchant Modifications & Accessories 1 16th May 2008 12:52
custom paint job for an alto manikjeet Modifications & Accessories 1 15th October 2007 10:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462
