Closed Thread
Old 20th December 2005, 18:15   #1
n_aditya's Avatar
Thanked: 2,780 Times
Default Injector Cleaning Fluid
Hi All,
I have a maruti esteem MPFI which used to give me an average FE of 12 kmpl in city... After i got a K&N filter (OE Replacement type) the mileage increased by about a km or two.
Just before the service was due the mileage was around 10-11kmpl in city. Also i was trying out new fuels like Xtrapremium, etc... But all this on empty to full only... Never mixed fuels of different ocatne levels. On the highway though i got 15 kmpl....
Now my car went for a service around a month back and even though my driving has been calm and peaceful the mileage in city traffic doesn't seem to be more than 12 kmpl...... What seems to be the problem?
There is no knocking... the car is very smooth.... Acceleration and pcik up is quick... Do i need to use any injector cleaning fluid as one of my friends said that the injectors may not have been cleaned while serviced....which is why the mileage is bad... His esteem though run only 3500 kms gives him 15-16kmpl in city...
Please do let me know....
P.S. All mileage figures are with the AC on....
P.S. Dear Mod's please move this thread to an appropriate location if i have posted incorrectly.
Waitin for all ur expert comments guys. reply soon.
n_aditya is offline
Old 20th December 2005, 19:20   #2
speedsatya's Avatar
Thanked: 712 Times
new generation fuels like xtra [premium ,speed adn power have additives which claim to clean the fuel system as well as the injectors...but yeah poor quality fuel does clog the minute injectors with time...as it is injector cleaning at MASS is cheaper now ...its just 400rs for cleaning teh 4 injectors...so u can do it every 10-15k kms...i do it every 7 k kms...
abt u getting ppor Fe...check if ur air filters are clogged ,check the plugs ,tire pressure ,brakes....doa search ..u will find many threads on this....
still ...it wont hurt to clean your injectors ocassionally
speedsatya is offline
Old 20th December 2005, 21:09   #3
Thanked: 44 Times
First of all, premioum fuels should give you better mileage, not less. How many km has your car done? make sure you have done all the appropriate service for that much running.
Improved mileage will come from engine in good tune, tyres inflated to correct pressure, and good driving habits.
Check if the brakes are binding, sometimes the rear brakes on Marutis may not disengage fully, jack up the car and rotate the wheel to see if it turns freely
filcord is offline
Old 21st December 2005, 01:56   #4
n_aditya's Avatar
my car was serviced a month back.... just 19300 kms on the ODO.... runs very smoothly... brakes are no problems.... all seems fine.... tires, battery etc are all checked every 15 days.... let me get the injector cleaning fluid and analyse....
i might need to talk to the service guy though... i get the servicing done at lotus motors (sheshadripuram, blore).... seems to do a good job....
guess i hav to wait n watch but please keep those views pouring in guys...
thanks a mil........
n_aditya is offline
Old 19th March 2006, 00:33   #5
Kaizer Sozay's Avatar
I called up a Maruti workshop in bombay they said taht for carbon cleaning & injector cleaning the cost was 2,500. Where are they charging 400??
Kaizer Sozay is offline
Old 19th March 2006, 10:53   #6
aZa
aZa's Avatar
Thanked: 17 Times
De-Carbon treatment is always expensive maybe just the injector cleaning is 400Rs.
aZa is offline
Old 20th March 2006, 15:00   #7
Thanked: 13 Times
Thumbs up
if i am not wrong i thought Injector Cleaning is only for diesel cars...
zulfikar is offline
Old 20th March 2006, 16:00   #8
Rudra Sen's Avatar
Thanked: 4,294 Times
No, gumming happens with petrol also.
n_aditya, you can use IFTEX-G (you'll get it in most of the Indianoil bunks). Cost around 250/- odd, if I'm not wrong. It's a petrol additive and also cleans injectors in the process.
Rudra Sen is offline
Old 20th March 2006, 16:03   #9
Thanked: 11 Times
Does it make sense to use Iftex if you use Xtrapremium?
Boom Shiva is offline
Old 20th March 2006, 16:10   #10
n_aditya's Avatar
Thanks Rudra Sir.... i have used an imported brand but the difference I felt was probably psychological... and the brand clearly states usage once every 5000 kms only and that too on a full tank of gas....
can u please let me know how frequently I can use IFTEX-G? I normally fill my tank from almost empty only....
P.S. I use regular unleaded fuel only from Pure for Sure BP bunks.... any comments on the fuel quality?
n_aditya is offline
Old 20th March 2006, 16:26   #11
ksethuram's Avatar
IFTEX-G is the trade name of BP what they call as "System G" which comes as a standard mix in all high octane petrols(Speed, Xtra Premium and Power). "System G" is being used as an additive to the normal petrol but i dont think anybody uses with high octane. Pls correct me if i am wrong.
Better is to get your vehicle checked by a good mechanic...
ksethuram is offline
Old 20th March 2006, 16:33   #12
Rudra Sen's Avatar
In your case you can use everytime as you fill petrol. Especially when you're using regular unleaded.
There is marked (read scaled) collection chamber on top of the bottle. You squeeze the bottle and it comes up. You need to add IFTEX according to your petrol filling. It's there behind the bottle's back label.
Try this out. It's good. GM (India) recommends it highly.
Old 20th March 2006, 16:40   #13
n_aditya's Avatar
thanks rudra sir... that was a quick reply....
Note from Support: Please continue on this thread. Thanks
http://www.team-bhp.com/forum/techni...es-thread.html (The Fuel Additives Thread)
n_aditya is offline
Closed Thread
My Fuel injector cleaning with carbon clean enigmatictech Technical Stuff 17 15th May 2014 20:36
Advice needed on Injector cleaning nitindangoria Technical Stuff 63 26th December 2013 16:05
"Sucking" sound after Throttle Body and Injector Cleaning abhipuru16 Technical Stuff 14 26th September 2010 20:48
Injector cleaning in mumbai Rice_tuner Technical Stuff 8 1st November 2008 13:08
