Old 6th June 2008, 18:23   #1771
funkydevil's Avatar
Thanked: 80 Times
hey gopinathan,
Dont they have a shorter life as compared to the stock lamps?? How long do you have em on, any problems so far??
funkydevil is offline   Reply With Quote
Old 7th June 2008, 00:26   #1772
Thanked: 37 Times
Can i use Osram Night breaker for my safari 2.2? Do i need to put any relay?
Do i need to change the bulb holder? Please somebody message me fast cos i am going to buy one on saturday.
I have spoken to the dealer and its around Rs.1600/-
Deepak
kdeepakk is offline   Reply With Quote
Old 7th June 2008, 08:20   #1773
adityamunshi's Avatar
Someone please post pics of the light spread with silverstar. Are the white bulbs or yellow ?
adityamunshi is offline   Reply With Quote
Old 7th June 2008, 19:52   #1774
Unhappy Help !
Palio 1.6 Narva upgrade (high beams only)
After changing the High beams on my Palio 1.6 to 90/100w I am facing chronic light alignment issues. Took it to Green Tracks, Bangalore to get it fixed. He charged me 56/- bucks and guess what the alignment is all over the place. He said thats all he could do. Nothing against GT but I think they are not very good at this.
The problem is the left high beam lands about 3 feet from my bumper and the right one..I don't know where it lands. Plus the low beams are looking towards the right (dangerous) and are behaving like highs. So I am compensating using the head lamp level adjuster.
I am feeling so depressed that I tampered with factory settings. Is there a way I can wash away my paap. Please help !! Any pro head light adjuster in Bangy?
Gurus bless me !
meremortal is offline   Reply With Quote
Old 8th June 2008, 09:37   #1775
khan_sultan's Avatar
Thanked: 3,466 Times
Similar experience with light adjustment with folks at Green Tracks. They could not get it right.
I then had to do trial & error myself and then eventually it is a lot better than what it was previously.
khan_sultan is offline   Reply With Quote
Old 8th June 2008, 16:14   #1776
tsk1979's Avatar
Thanked: 15,684 Times
meremortal, open up your car manual and adjust the lights yourself. Why do you want to pay someone for it.
As for your problem, I suspect the bulb is not set properly. Do you see light moving when you hit a bump.
Old 8th June 2008, 17:34   #1777
vagabond69's Avatar
Default I'm a Newbie and need your advice.
Hai guys, i am a newbie and this is my first post. I will own a Swift VDi (Azure Grey) in about a week's time. And i need your advice on changing the lights on my car to after market ones.
I'm planning to do these :
1. Headlights to angel eyes with HID.
2. Fog lamps to HID.
3. Tail lights to LED type.
4. Underbody NEON lights (i prefer red).
I need your advice on:
1. Brands, specifications and consequences (of changing from OEM stuff).
2. Prices (in cochin*).
3. Where to buy (in cochin*).
*All replies are welcome, just that those in cochin are easier for me.
I also intend to install Alloys and ICE (15k budget for each). Spoiler, bumpers/skirts and graphics will follow if i have any savings left. Please advice me on these too. I hope i did not break any form rules asking for these in the lighting section. Sorry If i did, MODS.
vagabond69 is offline   Reply With Quote
Old 9th June 2008, 09:54   #1778
sanjaymugur's Avatar
Thanked: 53 Times
try Manipal motors for a change... they had set it right in my 1.2 when i changed from stock to OSRAM silverstar bulbs..
also, could you please tell me where did you buy Narva bulbs...
FIAT, always....
sanjaymugur is offline   Reply With Quote
Old 9th June 2008, 13:17   #1779
jkdas's Avatar
Thanked: 1,424 Times
Nice site for HID comparison etc
HID XENON HEADLIGHT CONVERSION KITS
5000K, 8000K etc difference pic.
High/ Low Beam HID Xenon Conversion Kits
Old 9th June 2008, 14:00   #1780
No the light does not move when I hit a bump. Will try setting it myself. Thanks
Old 9th June 2008, 17:10   #1781
spadival's Avatar
Thanked: 15 Times
The damn headlight relays on my Baleno gets drenched and conk off frequently. It happened once while returning from a long distance trip when a MSRTC bus splashed lake full of water on my car. Luckily only the low beam relay went off and since then I carry a bunch of spare relays . Today, the low beam stopped working again. Had a look and was not surprised to find reason for the failure was that the relay has spoon full of water inside it!!
Coming to the solution, how do I prevent water from seeping into the relays? (Bosch type with 5 pins). For now, I have wrapped the relays in a plastic bag and sealed off one end with electrical insulation tape. But I doubt whether this will be effective, considering that moisture tends to build up inside the plastic bag itself over a period of time.
spadival is offline   Reply With Quote
Old 9th June 2008, 20:32   #1782
thirst4torque's Avatar
Where are the relays placed now? I think re locating them where the chances of getting them wet are less would be the ideal solution.
thirst4torque is offline   Reply With Quote
Old 10th June 2008, 11:24   #1783
spadival's Avatar
Thanked: 15 Times
They are right next to the firewall. Now I have moved them as close to the battery/fuse box as possible, because thats possibly the driest area in the engine compartment. I will also check if water is leaking from the top near the firewall.
Old 10th June 2008, 12:19   #1784
You have got me worried now!The relays in my car are also placed near the firewall
But the water should not have reached there in the first place right?
Old 10th June 2008, 12:47   #1785
gopinathann's Avatar
Thanked: 20 Times
Originally Posted by funkydevil View Post
hey gopinathan,
I had Crystal vision for the past 10 months, still working, however I wanted more light and went for Narva 100/90. It has been 2 weeks I have put them, have to see how long it works. I think if we use more low-high beam for signalling it will blow out soon.
gopinathann is offline   Reply With Quote
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11249 25th December 2017 13:07
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
