Old 3rd December 2008, 14:37   #2461
deadguy25's Avatar
Thanked: 42 Times
@DInar: I had the problem in Zen with the relay after fixing 90/100 lights.
Went to a roadside mechanic when i was travelling as i could not switch-off the lights, all he did was gently tap the relay, and presto : the lights went-off.
He said there could be a loose connection in the relay.
deadguy25 is offline   Reply With Quote
Old 3rd December 2008, 15:25   #2462
Default any advice on hid?
hi guys.. needed hid conversion kit for a new honda city.. please tell me some nice brands to go for.. anyone heard of P4 and aiki Xenon ? philips is out of my range..
cargasm007 is offline   Reply With Quote
Old 3rd December 2008, 15:25   #2463
harry10's Avatar
Thanked: 585 Times
Originally Posted by Swifty2008 View Post
A reliable replacement would be Philips 100/90w Rally + Bosch or PMP Relay and wiring. Its cost me 1100rs.
Thanks a lot for the info mate
harry10 is online now   Reply With Quote
Old 4th December 2008, 10:15   #2464
Thanked: 60 Times
Infractions: 0/1 (5)
hi guys need hid kit for my fogs in verna vgt.philips n osram do not make that bulb type?what to do?dont want to risk chineese brands?have hid philips in main beam.pls help.
drchernish is offline   Reply With Quote
Old 4th December 2008, 21:20   #2465
Talking finally got my hid
was getting a little tempted for the conversion kit.. it cost me approx 8000 after fitting .. checked from a few places and got the recommendation of aiki xenon brand its quite nice
Old 5th December 2008, 01:41   #2466
sunilchakola's Avatar
Guys,
Dont know is this the right place to post my issue!!! for my Sierra Turbo i changed the headlights to Philips rally 120/100 W after a week it seems my both Healamp glass is cracked. Shall i need to change the watts to 100/90 or is the issue with my Headlamp assembly...
sunilchakola is offline   Reply With Quote
Old 5th December 2008, 11:25   #2467
Thanked: 60 Times
please help.........
Old 5th December 2008, 13:57   #2468
Thumbs up u might be interested in the hid i have fixed
hi drchenish .. iv just put some hids in mine. its an indian chinese collaboration.. so i was told and i am happy with the lights.. aiki xenon is the one i have put. u might want to have a check
Old 5th December 2008, 17:12   #2469
pshyamsundar's Avatar
Which is better for swift?
Philips Rallye 100/90 + relay setup
or
Philips xtreme power + 80% (60/55)
pshyamsundar is offline   Reply With Quote
Old 5th December 2008, 18:05   #2470
hellstar's Avatar
Thanked: 17 Times
the bulbs that fit intothe verna "fog lights" are H27 / 880 configuration they are available in india last week one of our TBHP members did install 35W 6000K HIDs in his verna in blore but he tells me that it bring around a lot of glare to the other road users shoudl probably be check out his ride sometime.
Philips and Osram do make these bulbs...
hellstar is offline   Reply With Quote
Old 5th December 2008, 21:22   #2471
Thanked: 60 Times
where in delhi can i get them and approx how much is the price?thanks
Old 5th December 2008, 21:52   #2472
Thanked: 52 Times
Originally Posted by leadf00t View Post
Is this relay in the stock wiring? can you help me where it can be found?
It's usually along with the relays for AC and stuff, under the bonnet, cloase to the battery.
Simply follow the wire from you head lights, it will be connected to the replay itself.
dinar is offline   Reply With Quote
Old 6th December 2008, 00:08   #2473
Thanked: 7 Times
Default Help required for Santro stock headlamp replacement
Hi
This is my first post on the forum.. I know similar queries were raised earlier & this is bit out of place in the thread.
Gurus, I need your help. I have a 2006 Santro Xing with stock light setup.
Before an interstate trip some time back, I got the so called 'fog lamps/bumper lights' fitted by the Hyundai Service guys. It's proved to be really useless, except for a bit of looks! At the best it can add to the side spread of main beam. No wonder these are referred as 'Track beams'!. I have noticed that i10 has a larger set of bumper lights but I am not too sure about their efficiency!
I want to replace the original head lamp lights. I have searched through the threads & have come across Philips Crystal/Diamond vision etc. While few really vouch for these, most of them say White/Bluish light is just for the 'looks' & are of no use on highway. Came across few posts on GE & Osram lights.
Hyundai service guys are very clear that they will not do anything that requires change in wiring/addition of relay etc.
1. What are my options if I am to stick to stock setup - i.e. max wattage bulb can i opt for without any change in wiring or relays & which brand.
2. If I am to opt for 100/90w bulbs with a relay & re-wiring thrown in, which brand & type of bulb & wiring should i go for? Is there any place in Bangalore Whitefield area where I can get genuine stuff & quality installation?
3. Finally, will a change in stock bulb mean that the beam leveling in santro becomes redundant
Please help out
kosh4u is offline   Reply With Quote
Old 6th December 2008, 10:53   #2474
shyamhegde's Avatar
Originally Posted by kosh4u View Post
Hi
Please help out
Go to a good accessory shop/installer, ask for headlight bulb upgrade with wiring kit. Kit will consist of thick wires for the higher wattage halogen, ceramic holders, a relay etcetera. Go for a 90/100 Philips rally or some of the good brand with *normal* color temperature. It is a 30 minutes work for some one who knows the job well. The kits allow you to upgrade without having to *cut* the stock wiring.
shyamhegde is offline   Reply With Quote
Old 6th December 2008, 13:43   #2475
Thanked: 7 Times
Thanks a lot Shyam. How much will such a setup cost me?
Hope this won't void any manufacturer warranty, would it?
Hope some one could help me with suggesting a quality installer in Whitefield/Outer Ring Road/ Indira Nagar area. Thanks in advance
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11249 25th December 2017 13:07
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
