Old 25th April 2009, 09:48   #2806
Smile
Hi How much did you pay for the lights.
I recently had the lights changed , but am not very happy with the high beam throw. I own honda city. any suggestion to improve the high beam throw?
Originally Posted by ferrari_driver View Post
I have installed the HID Conversion Kit of Philips (Made in Germany) yesterday only. However, the alignment of the two lights was improper which I am trying to get fixed from a GM workshop (hope they agree to do it for my optra given its not originial equipment)
The dealer informed me that there is no warranty given by Philips but he has given me a 1 year warranty (in writing on a proper bill which I got after paying 12.5% VAT) excluding the bulbs.
Would anyone have an idea as to :
a) How much would the bulbs cost in case they fuse?
b) In case GM refuses to align the lights, will the dealer (from whom I have bought it) be able to do it properly?
Also, is there a remote chance of the reflector (not the coupler) melting due to intense heat?
dhir_d is offline   Reply With Quote
Old 26th April 2009, 03:18   #2807
Zahir's Avatar
Thanked: 27 Times
Again, any one know a bulb better than Osram Night Breakers? Is vision plus better? Also is Vision Plus yellow light?
Zahir is offline   Reply With Quote
Old 27th April 2009, 16:39   #2808
dhondusaxena's Avatar
Thanked: 41 Times
Vision Plus is yellow light. Recently upgraded to Vision Plus after using Crystal Vision for almost an year. They are great lights but I feel they are more directed towards the ground even on High beam. Maybe I need to get the headlights adjusted properly. Regarding if they are better than Night Breakers, maybe not, somebody else may like to comment.
dhondusaxena is offline   Reply With Quote
Old 3rd May 2009, 02:27   #2809
Thanked: 26 Times
I had Osram night breaker headlights. Today i noticed that left side low beam stopped working.
Does this mean that I have buy a new one? Or something wrong with wiring?
I bought it only in Aug 2008. I would say very low lifespan.
If I need to buy new one, planning to put 90/100 headlights on my Accent CRDi.
Do I have to put in extra relays? Would the current wiring be able to handle it?
anToNIcHeN is offline   Reply With Quote
Old 3rd May 2009, 08:43   #2810
phamilyman's Avatar
Thanked: 3,454 Times
What about halonix 90/100 in swift after installing relays? I am getting quotes of about 2k - which i know is high.
anyone got it done in gaon? prices?
Also what is the lifetime of reflector - i was warned that it may melt reflectors by Apra staff.
Old 3rd May 2009, 11:35   #2811
Hashim's Avatar
Thanked: 32 Times
Both things are possible, check the bulb first, there are three wires connected to bulb, black one is of ground and then the other two are for low and high beam. Yellow is for low and blue is for high beam (may be different in some vehicle). Attach a multimeter (or a blub) to black and yellow and turn on the headlight on low beam, if multimeter show 12v (or bulb lights up) then wiring is ok.
Regarding Accent, yes you will need to attach relays to handle higher wattage bulb.
Hashim is offline   Reply With Quote
Old 3rd May 2009, 13:53   #2812
ankitahuja's Avatar
Thanked: 46 Times
It's a damn good option to upgrade to that. I prefer Philips Rally over the Halonix +60 but then it depends on what you like.
Both bulbs will increase the light intensity, Rally is much brighter but then you compromise a bit on the throw, and vice versa for the Halonix.
Bulbs and kit will cost you not more than 1.1k with Philips Rally and .9k for Halonix.
There is a ROOTS kits for sale in the classifieds
Oh and yes, the reflectors will NOT melt. There are too many people here running a 100/90 set up on the swift.
Old 3rd May 2009, 14:36   #2813
phamilyman's Avatar
wokay. thanks.
I will go for the bulb that has the maximum throw - even now, its throw which is why I'm considering upgrading - not brightness.
And thanks for the heads up, but i'll see. If you're running 100/90 without the kit, umm why would a swift need it?
Old 3rd May 2009, 14:43   #2814
Eddy's Avatar
Thanked: 4,781 Times
Don't forget telling me BEFORE you do the upgrade. I am in two minds whether to do it or not. Might just tag along.
Eddy is online now   Reply With Quote
Old 3rd May 2009, 15:06   #2815
ankitahuja's Avatar
Thanked: 46 Times
wokay. thanks.
Try both bulbs to see how the Swift's reflectors respond.
I'm not running 100/90 without the kit. I already have a ROOTS wiring kit that used to come with bakelite holders. I bought this other kit only because it had ceramic holders and I wanted to upgrade to 100/130w. Was not sure if the bakelite holders would cope up with the heat (but now I believe they do).
Keeping in mind that my HL assemblies are brand new, I decided against 100/130 bulbs to avoid blackening them out right now. Will probably upgrade further after some more time.
Old 3rd May 2009, 18:31   #2816
Epic's Avatar
Thanked: 359 Times
Originally Posted by Epic View Post
Hi Friends,
I had fitted a HID kit for the headlamps of my Swift. I was advised to go in for the P4 HID kits of 6000K. These were fitted in November 2008 and also LEDs for my parking lamps. However, the LED bulbs fused after a month and so did ballast of the left headlamp. As the HID kit was under warranty, i had the same replaced free of cost and changed the LED to ones of a better quality. After a little more than a month, the LEDs fused again and just yesterday the left headlamp failed. This time the bulb had fused. I had the bulb changed again under warranty.
The HID kit has not even completed 6 months but has failed twice already. The LED parking bulbs always seem to fuse but i never have an issue with regular white bulbs. Again, why does only the left ballast or bulb fuse? Ive asked the distributor the same and he claims that sometimes they have encountered multiple complaints with certain cars only, but otherwise the kits have worked perfectly. He however does not claim the kits to be faulty nor does he claim an issue with the electricals of the car.
Can anyone please help me with this issue? I am also planning to fit HIDs in my fogs but reconsidering due to these reliability issues.
Epic
Hey guys,
I need some help with the above.
Epic is offline   Reply With Quote
Old 3rd May 2009, 19:24   #2817
Thanked: 26 Times
Thanks for the info. I shall check this up.
The reason why I asked. sometime back, I had gone to a car accessory shop looking for upgrade. The person over there told me that, "you dont require extra relays and wires for Accent. Stock wiring in them could already handle the extra wattage". Hence I asked. So, you are saying that I MUST go for relays. right?
Old 3rd May 2009, 19:35   #2818
Hashim's Avatar
Thanked: 32 Times
In that case check the existing headlight relay, there is only one relay to control both headlamps and there should be wattage mentioned on the relay. The realy should be atleast 200W to handle 90/100 bulbs.
These accesories shop people often don't have much technical knowledge, even a lower wattage relay will work but in long run it will melt and headlight will fail to work.
Old 4th May 2009, 13:17   #2819
Yesterday I bought couple of Silverstar + 50% from Swastik something from Desh Bandhu road karol bagh at 160/- per piece. They are in normal carboard box nothing fancy about them, I am yet to see the difference as I have not driven at night after changing the bulbs. One thing that caught my eye is that the date of packing on the package is mentioned as Oct 2005 which I think is too old that is why I only bought one pair from them. They had the big carton kind of thing in which they were having silverstar only, I hope they turn out to be genuine as the guy was saying that they are Osram distributor. Original bulbs that I took out from my Baleno headlights are Philips, Any idea if they would be vision plus or something like that?
Sang is offline   Reply With Quote
Old 4th May 2009, 19:11   #2820
white_vdi's Avatar
Thanked: 17 Times
sang original bulbs are normal halogen. not vision plus or anything else.
white_vdi is offline   Reply With Quote
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11251 23rd January 2018 14:29
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
