Old 18th June 2009, 21:02   #2986
hrman's Avatar
Thanked: 383 Times
Originally Posted by sparkguy View Post
Where can I get Philips Xtreme Power 60/55bulbs in Noida. I saw these bulbs at Car Ranauq at sector 16 Noida but couldn't make out about the originality so backed out. Quoted price was 850/-
That is about the cost they retail for. if you are not sure, I can get the names of the distrubutors for North. You can get it form there.
hrman is offline   Reply With Quote
Old 22nd June 2009, 13:18   #2987
thats the correct price. i got mine from there only
saintsinner is offline   Reply With Quote
Old 22nd June 2009, 13:43   #2988
Thanked: 20 Times
Hi saintsinner; Thanks for reply. How to check if bulbs are original or not. Would you recommend Car Ranauq at sector 16 for simple modifications like changing headlamps, horn, fog lamps etc.
sparkguy is offline   Reply With Quote
Old 22nd June 2009, 13:47   #2989
TomRider's Avatar
I need H7's for my Palio (Philips or Narva). Anyone knows where to get those in Bangalore?
PS: I need white light. Not blue or normal yellow.
TomRider is offline   Reply With Quote
Old 22nd June 2009, 15:16   #2990
he has originals, be warned though - if you flash too much then they will go kaput. though mine are nearly an year old and i flash like crazy.
he is decent for the modifications you have mentioned. Talk to Salim or Mahesh, give him my reference - Paras. you might be able to bargain more.
Old 22nd June 2009, 18:32   #2991
nareshtrao's Avatar
Thanked: 356 Times
Hi Bangalore TBhpians;
Does anyone know a good installer/mechanic who can fit a pair of HELLA AFM headlights on a Indigo. This needs special skills and not the regular welding needed for a SUV type fitting. This needs a flush fit thru the front grill and as camaflouged and neat as possible.
Any one knows someone?
Contact Car Fancy (next to Sharma's on 80 Ft. Road in Koramangala) or Auto Fusion (In the lane opposite Koramangala Club)...
You can also contact the owner Thouqeer on 98450 04858. Both places are owned by him. I have seen some mods similar to ones mentioned by you done on Swift, Zen and Indica's at his place.
nareshtrao is offline   Reply With Quote
Old 22nd June 2009, 23:36   #2992
ported_head's Avatar
I indulged in a pair of Philips Xtreme Power +80% 60/55W H4 bulbs for my Swift. Initial impressions are that they are brighter, but +80% is a long call. It seems more like 40-50% brighter, maybe. Also, the beam is more concentrated, compared to the somewhat wider spread of the OEM Halonix H4 bulbs.
LOW Beam
Size:  32.3 KB Name:  xtreme_low01.jpg
The difference seems in even lesser in high beam.
HIGH Beam
Size:  34.6 KBName:  xtreme_high01.jpg
Though I suspect, the reason for this is the change in the headlamp leveller position. This struck me only when I was looking at the pics at home. Maybe, these bulbs need a slightly different headlamp alignment.
Also the beam is definitely a lot more whiter, not what I wanted. On a highway with street lighting, these headlamps are non existent. I might switch to the stock ones for heavy downpour.
I'm going to be tempted to do a 100/90W once these burn out. Infact my uncle's OEM Indica headlamps are not all that much weaker than these. Must be down to the reflector design.
ported_head is offline   Reply With Quote
Old 23rd June 2009, 05:14   #2993
^^ i find them more practical to the osram night breaker. they do the job well for 60/55
Old 23rd June 2009, 11:03   #2994
NiTviN's Avatar
Default Philips distributor is Bangalore
Many BHPians have PM'ed me to provide the address, phone numbers of A K Traders who is the philips distributor in Bangalore. Below are the details
A.K. Traders
Address:
#22/23
1st Floor
3rd Cross, J.C. Road
Bangalore -560001
Phone: 080-26707295, 080-41143199
How to get there:
On J C Road, lake left on the first signal (Just after the Multi Level Car Park - If you are going there in the car, park here). Take left on 3rd cross. Its on the first floor on the right side.
NiTviN is offline   Reply With Quote
Old 23rd June 2009, 12:53   #2995
TomRider's Avatar
Thanks NiTviN.
I just checked with them. The H7's for palio will cost a bomb. 2200/- for 4 (Crystal vision - 80W - 6000k) bulbs. Normal yellow's (80W) are available for 960/- for 4 nos. I am really confused which one to go for!
Old 23rd June 2009, 19:03   #2996
Hello,
Wondering if someone can help me with some advise on Xenons for Fiat Linea (White) -
- Which Model/Make goes best with Linea?
- Approx Cost (I can go upto 10K)
- Availability in Mumbai
Thanks in advance for your advise!
sumit21580 is offline   Reply With Quote
Old 29th June 2009, 14:02   #2997
karizma_devil's Avatar
Thanked: 16 Times
i Want to have Philips Crystal Vision for my Palio s10 ( head unit + Fog lamps).
PLease suggest availibility im Mumbai ( Preferably in and around Colaba or Thane)
Cheers !
karizma_devil is offline   Reply With Quote
Old 29th June 2009, 16:47   #2998
nareshtrao's Avatar
Thanked: 356 Times
Can any of the users give me a comparison between
1. OSRAM Night Breakers,
2. Philips Extreme Vision and
3. Philips Crystal Vision ?
I see different recommendations here and have not been able to make up which is suitable under what circumstances?
This is for Stock replacement of H4 bulbs in i10.
Thanks to all in advance.
Old 30th June 2009, 10:14   #2999
Thanked: 25 Times
I switched over to Swift from Wagon-R. & it’s about an year old now. ICE, Wheel/Alloys upgrade etc are over. About lighting, I upgraded to Night Breaker & fogs bulb to H7 55W Night Breaker (bought thru e-bay). I’ve gone thru the lighting thread (almost all pages) & now confused more.
I thought of going for Phillips Xtreme. But, I read many reviews/opinions that for best illumination of road switching to 100/90 would be the best option. I found that all these 50+, 80+, 90+ etc. are marketing tricks & nothing like 100/90. I decided to go for Rally 100/90, but I never seen how these are.
Any expert opinion on Phillips Xtreme compared to 100/90?
Among the group which 100/90 is the best? Are there bulbs available in 55/100W?
I know this must ‘ve been answered somewhere in the thread, but I rqst for suggestion & this might be a useful info for new members
Tnks
Post EDITED since it contained various [FONT], [COLOR] and [SIZE] tags.
Posting with such text formatting should be avoided on Team-BHP as it is inconvenient for members to read post.
Kindly go through Announcements section before proceeding.
Thanking You for your anticipated co-operation
The Team-BHP Support
Last edited by Jaggu : 30th June 2009 at 10:19. Reason: Removing font tags, thanks.
ALSUDA is offline   Reply With Quote
Old 30th June 2009, 12:31   #3000
KSM-Vtec's Avatar
Thanked: 440 Times
Ok i have a question here - Can i run these lights AIRCRAFT LANDING LIGHTS / HALOGEN LANDING LIGHTS on a gypsy??
What will be the impact or using a 250watts light?
KSM-Vtec is offline   Reply With Quote
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11264 21st February 2018 22:34
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4012 20th February 2018 10:30
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
