Old 10th July 2009, 11:53   #3061
KSM-Vtec's Avatar
Thanked: 439 Times
Hi guys!!
I need to install a set of 4(additional)aux lights on my gypsy something like this -
My Questions Are -
1. What is the brightest config i can use keeping in mind that i would like to us the lights for long time spans (2 - 3 hrs) WITHOUT damaging/over loading the alternator(stock) and battery(35 amps)
2. Also i would like to know if i can do something like installing a cut-out/relay or something to increase the brightness without increasing the load on the alt/bat.
3. Will i have to use any specific types of wires and how would the circuit be??
Also i guess we need to keep in mind that I would be using the music system(w/o amp), AC and other stock lights when the 4 additional lights are in use.
KSM-Vtec is offline   Reply With Quote
Old 10th July 2009, 12:22   #3062
Ravveendrra's Avatar
Thanked: 405 Times
Default water on bulb
Originally Posted by sushrutha View Post
Probabaly yes. Apart from it, rain was slightly jittering around, Can this also be a reason ? Water drop on the bulb ?
If the water was on the bulb when it was fixed - normally wont cause a blowout, however if there was water somewhere in the assembly that later fell on the bulb - the bulb will definitely blow.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 10th July 2009, 12:26   #3063
Thanked: 405 Times
Originally Posted by KSM-Vtec View Post
Hi guys!!
My Questions Are -
The best bet is to go in for HID auxullary lights. Lightforce has some but they are very expensive - about 1.25L. HIDs consume less power but give much more light.
You will need to fit in extra relays to take the load off the switches and wiring. Relays and cutouts also increase light output.
Cheers,
Old 10th July 2009, 12:50   #3064
nishantgandhi's Avatar
Thanked: 151 Times
Default Beam/throw adjustment help needed
I have a Getz 1.3. After headlight upgrade, the beam focus and throw have gone haywire. I dont want to go to HASS for such a small job as they will invariably waste a lot of time (read-entire day). My local mechanic (whose electrician did the install) is on a vacation.
I intend to do it myself. So I read up the manual and got the method (screw adjustment). However, I am unable to locate the said screws. Can someone whose done it themself guide me? Pictures (of the location of the screws) would be very helpful!
nishantgandhi is offline   Reply With Quote
Old 10th July 2009, 20:31   #3065
shyamhegde's Avatar
Normally these wheel alignment guys also will have equipement to align headlights. You could try one of them probably. They will be faster than A.S.S as no paper work they do for the work.
shyamhegde is offline   Reply With Quote
Old 11th July 2009, 01:44   #3066
KSM-Vtec's Avatar
Thanked: 439 Times
Cheers,
i dont think i can spend that much on the lights, the setup that you see in the pics dosent cost more than 2k
Old 11th July 2009, 14:58   #3067
bullboy's Avatar
Thanked: 35 Times
Originally Posted by greenhorn View Post
bullboy, why not bite the bullet and go 100/90
If they want to , cops will fine you either way
greenhorn ,afraid about head light damage and warranty
bullboy is offline   Reply With Quote
Old 11th July 2009, 15:03   #3068
tsk1979's Avatar
Thanked: 15,683 Times
Go for 1 pair of Xenons(H3). Buy some good ISI mark local housing(1500rs) + good quality bulbs(5000rs).
You will have excellent lights which will last long and drain only 80W total! less than a headlight
Old 13th July 2009, 10:07   #3069
raj84's Avatar
Thanked: 146 Times
Default Xtreme Power and NightBreaker in Trivandrum
Originally Posted by bullboy View Post
The philips dealer is quoting 1600 for a pair of extreme vision.He also suggested Osram night breakers are bit more better and retails at the same price.
Is this pricing justifiable?
Hi BullBoy,
Philips Xtreme Power and Osram NightBreaker are now available at MotorPlaza.
They never used to have this before. I used to ask Sajan George of Motorplaza for both these bulbs whenever I went there. When I wen there two weeks ago, to my surprise did find both these bulbs.
Osram NightBrekaer H1,H4 are also available.
Philips Xtreme Power H4 - Rs 1200
Osram NightBreaker H4 - 1400
I bought Xtreme Power and removed my Diamond Vision. Now night driving , especially in rain is 50% better than Diamond Vision as Diamond Vision was almost non-existent in rain.
Compared to stock H4, Xtreme-Power is 30-40% better in my opinion
raj84 is offline   Reply With Quote
Old 13th July 2009, 14:18   #3070
bullboy's Avatar
Thanked: 35 Times
Originally Posted by raj84 View Post
Hi BullBoy,
Isn't this price too high as it is available for Rs 800 in bangalore.
Old 13th July 2009, 14:30   #3071
anantnehru's Avatar
Hi guys
I installed 90/130w bulb yesterday with the so-called Hella wiring kit. The box and plastic wrap had Hella written all over it.
However, today noticed while flashing my lights they stay on. They only went off when I put on the headlights and then switched them off. What could this be due to??
Appreciate any help! Thanks.
anantnehru is offline   Reply With Quote
Old 13th July 2009, 14:42   #3072
deepakchiniwal's Avatar
Thanked: 27 Times
Default Bosch or Philips
Hello,
I have a swift DZire VDI and was wanting to upgrade my headlamps. I felt the stock bulbs are only sufficient for City Driving.
I was considering to upgrade to either Bosch Lights or Philips Lights may be a 90/100.
Request everyone to suggest which one is better and what will be the approximate cost.
I stay in Bangalore, please suggest the dealers and contact numbers if you have.
Deepak
deepakchiniwal is offline   Reply With Quote
Old 13th July 2009, 16:58   #3073
slipstream's Avatar
Thanked: 9 Times
Originally Posted by slipstream View Post
have you guys considered the headlamp assembly of the Yezdi Roadking to be fitted onto your cars ? Comes finished in Chrome, is as big as a Hella 3000, has some neat grills on it to prevent damage to the glass area and the best part is that it costs less than 500 bucks a piece !
My questions are :
a) Can this accomodate a bakelite holder that houses a 100/90 or would some modifications be required ?
b) Would the reflectors be capable of handling the heat of a 100/90 ?
c) What would be cost of wiring, brackets, labour etc work out to ? Looking at an instal in my swift
d) Are there any other functional, good looking but cost effective alternatives to this ?
guess this got lost amongst the other posts....cam someone help ?
slipstream is offline   Reply With Quote
Old 13th July 2009, 17:13   #3074
Thanked: 59 Times
Originally Posted by deepakchiniwal View Post
Hello,
Deepak
I got myself upgraded to 130/90 Hella [Lock Stock Barrel ] from Bluraven. Hes located in Cambrige Layout. PM him for more details.
lambuhere1 is offline   Reply With Quote
Old 13th July 2009, 20:53   #3075
nareshtrao's Avatar
Thanked: 337 Times
Nightbreaker is 1400 in Bangalore too. While the box say 1650, some give for 1400. Not sure of the Philips Extreme though.
nareshtrao is offline   Reply With Quote
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11249 25th December 2017 13:07
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
