Old 17th August 2009, 22:29   #3196
Fountainheader's Avatar
Originally Posted by Sportsmind View Post
Finally found the right combination for my swift projector headlamps. The install is finally done. 100 Philips rally on my low beam (projector), 6000K HID on my high beam, and 4300K HID on my fog lamp. Just did a trip to kerala and back, just found it perfect on the highways, and also during heavy rains.
Cheers..
You have a bulb on Low Beam and HID on High Beam ?
Fountainheader is offline   Reply With Quote
Old 17th August 2009, 22:40   #3197
Ravveendrra's Avatar
Thanked: 405 Times
Originally Posted by nilanjanray View Post
The first guy states that they are 6000K. The second guy gives no details in his web-site but the picture indicates at least 6000K. These seem to be importers of the stuff not manufacturers.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 18th August 2009, 10:07   #3198
Sportsmind's Avatar
Thanked: 28 Times
Wink
Its Philips rally halogen 100 on the low, thats what i drive most on the streets, and to keep the Bengaluru cops keep their eyes off my head lamps. They spot white and their eyes pop, and they are running all across the road to hug you..LOL..cheers
Sportsmind is offline   Reply With Quote
Old 18th August 2009, 11:08   #3199
gpa
gpa's Avatar
Thanked: 274 Times
Am puzzled! How can you have a halogen for the low beam and HID on the high beam in the same socket??
Old 18th August 2009, 11:15   #3200
gpa,
Its the Angel Eyes setup. It has 2 slots - One for Low and another for High.
Old 18th August 2009, 11:28   #3201
Sportsmind's Avatar
Thanked: 28 Times
Cool
It is the projector headlamp as clarified by Fountain header. Here is the image to get you an idea of the setup.
Old 18th August 2009, 12:12   #3202
gpa
gpa's Avatar
Thanked: 274 Times
Sportsmind and Fountainheader, thanks for clarifying that
@ Sportsmind: The setup looks cool
Cheers,
gpa
Old 18th August 2009, 16:23   #3203
anantnehru's Avatar
Well, ideally speaking you should have HIDs in the low beams and normal bulbs in the high cos the HIDs take time to light up right? So if you need to flash your lights, you're stuck. Happened to me when I had mine.
anantnehru is offline   Reply With Quote
Old 18th August 2009, 23:27   #3204
nareshtrao's Avatar
Thanked: 337 Times
Originally Posted by DocG View Post
I hope someone can help me with this.
I'm looking for 100/90 Watt bulbs for my headlights in the following sizes:
9005 and 9006.
I need the best visibility, I'd like some cosmetic effect of whitish light, but don't mind it even if the lights are YELLOW. Need better visibility for night driving.
9005 and 9006 are single filament bulbs. 9005 is HB3 - 60 W (High Beam) and 9006 is HB4 - 51 W (Low Beam). Hence you can not get 100/90 double filament bulbs to replace them.
Higher wattage or alternatives in these categories are rare and even Nightbreaker family does not have them. Someone said Narva but not sure if they have.
nareshtrao is offline   Reply With Quote
Old 19th August 2009, 00:51   #3205
ankitahuja's Avatar
Thanked: 46 Times
Aah, makes sense though, but everyone with bi-xenons has to live with this.
I guess now Sportsmind will just have to rotate the HL stalk everytime he needs to "flash" someone (not literally).
Old 19th August 2009, 10:04   #3206
Sportsmind's Avatar
Thanked: 28 Times
Cool
I have got away from the habit of flashing. I observed guys just give me the pass when i have my 8000k high beam on. If there are still guys who dont, then you have solved the problem, one hoot of the Stebel nautilus, and they give me the pass..Thanks.
Old 19th August 2009, 11:23   #3207
funkydude's Avatar
Hi Sportsmind! Can you please guide me to one of the best HID conversion kits for my new ford Ikon? Also, how much would both the HID and the Stebel's cost?
Any specific config I should be looking for?
funkydude is offline   Reply With Quote
Old 19th August 2009, 11:35   #3208
Sportsmind's Avatar
Thanked: 28 Times
Cool
The HID kits costed me around 6k for each pair. The stebels from Ankit costed me 900 Rs. Not too sure with Ikons head lamps. The fog i am sure you can go with 4300k. The headlamp i guess you will need a Bi..
Old 19th August 2009, 19:55   #3209
Epic's Avatar
Thanked: 359 Times
Originally Posted by Epic
Hi Friends,
I had fitted a HID kit for the headlamps of my Swift. I was advised to go in for the P4 HID kits of 6000K. These were fitted in November 2008 and also LEDs for my parking lamps. However, the LED bulbs fused after a month and so did ballast of the left headlamp. As the HID kit was under warranty, i had the same replaced free of cost and changed the LED to ones of a better quality. After a little more than a month, the LEDs fused again and just yesterday the left headlamp failed. This time the bulb had fused. I had the bulb changed again under warranty.
The HID kit has not even completed 6 months but has failed twice already. The LED parking bulbs always seem to fuse but i never have an issue with regular white bulbs. Again, why does only the left ballast or bulb fuse? Ive asked the distributor the same and he claims that sometimes they have encountered multiple complaints with certain cars only, but otherwise the kits have worked perfectly. He however does not claim the kits to be faulty nor does he claim an issue with the electricals of the car.
Can anyone please help me with this issue? I am also planning to fit HIDs in my fogs but reconsidering due to these reliability issues.
Epic
Hey guys. Can anyone help me with the above issue?
Epic is offline   Reply With Quote
Old 19th August 2009, 20:01   #3210
Epic,
I'd sincerely advise you to get rid of the HIDs and go for Philips 100/90 with Relay!
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 3988 18th January 2018 21:48
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11249 25th December 2017 13:07
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 423 7th October 2017 14:31
