Old 4th January 2010, 15:09   #3586
Thanked: 164 Times
Originally Posted by shamanth View Post
Recently i had changed to 90/100w with conversion kit. Today after i came back home i was shocked to see my headlight had got switched ON. Opened my car and checked the switch it was off still headlight was ON, and it was in high beam, it was not changing to low beam also. It seems headlight has become direct. Then i removed the bulb holder so that it wont drain my battery. I am planning to take my car tomorrow to place where i got relay installed and get it checked.
Please let me know if any of you have any idea why this happened. I am totally confused and worried, if anything had happened to electricals of my car or just the relay.
Went to Hot Tracks today, and got it checked. Relay cutout had problem. He replaced the Cutout since it was under warranty. No question asked.
shamanth is offline   Reply With Quote
Old 4th January 2010, 17:37   #3587
Thanked: 27 Times
Hi
Does any1 here knows where I can get the Philips Xenon HID?
Also....which should i get for my sx4.[the stock headlight is H4]
d2s or d1s or d2r?
ahmed26 is offline   Reply With Quote
Old 4th January 2010, 18:55   #3588
geeash's Avatar
Thanked: 132 Times
Please set your expectations right A car head light is not supposed to be creating a stadium flood light effect
Thanks for the info mate !!
I have always driven cars which had given me adequate side throw too!!.
I am finding the lack of throw from my stock head bulbs 65/55 during my city drive and also in my highway drive.
especially the side throw. it is very hard to spot the median only with my low beam on.
hope you have read my requirements clearly. I had said that i am not able to locate the median on the middle of the road due to lack of adequate side throw in low beam , that doeast mean that i want my car to illuminate the whole city
but reallity is that side throw and high beam blinds oncoming traffic and provides no special incentive to you
It does. it prevents me from ramming into the median and prevent me from endangering others life
That is why i asked i need a bulb which gives a adequate side throw in low beam and enough focussed throw in high beam. i presume that is a normal requirement for everyone who drives a car
Sorry dude nothing offensive meant!! hope you understand me loud and clear!!
geeash is offline   Reply With Quote
Old 5th January 2010, 11:08   #3589
bnzjon's Avatar
Thanked: 125 Times
Friends, further to the query from Geeash, i have the following query
Linea stock bulbs are h1 55w and h7 55w.
Need your help in choosing the right bulb for Linea
1. Philips xtreme power H4
2. Osram Night breaker H1 and H7
3. Philips Chrystal vision 4300k
I am not sure if Philips xterme power H4 will suit linea's H1 and H7.
Experts, pls advise as i am too ignorant about these. Usage is mainly for highways.
Pardon me if this is a repeat query and have already replied earlier in this forum.
bnzjon is offline   Reply With Quote
Old 5th January 2010, 11:30   #3590
Thanked: 420 Times
Phillips xtreme power is available in H4 and H7 and Osram nightbreaker is in H4, H7 and H11 so I think you can only replace H7 ( as both of these are not available in H1.
I think H7 is used for Low beam and that should be used most of the time so I guess changing H7 alone should fulfill your purpose.
X-treme Power: Maximum performance
OSRAM|Consumer|Automotive Lighting|Products|Headlights|NIGHT BREAKER|index
Actually h1 , h4, H7 etc are specification of the socket and size of the bulb.
amitk26 is offline   Reply With Quote
Old 5th January 2010, 13:32   #3591
Default Ritz head lamps overhaul
I am planning to change head lamps for Ritz because of weak light and unmanageable at night drives. Please suggest me a good options from below
1) Install extra wiring and upgrade to 90/100 Osram or Philips
2) Go with normal 55/60 Osram or Philips.
funda2max is offline   Reply With Quote
Old 5th January 2010, 13:59   #3592
Chevy_lover's Avatar
Thanked: 121 Times
Dear Friend, try upgrading to Phillips Rallye 100/90 or 130/100 halogens. You will need to install a relay also. If you are still not satisfied, try Hella auxiliary driving lamps/projectors. I have been using Phillips 130/100 for over two years now. No issues whatsoever. You can visit my garage to see my projectors. They are brilliant. I have 660 watts of combined light output!
Chevy_lover is offline   Reply With Quote
Old 5th January 2010, 14:09   #3593
Thanked: 121 Times
Hi Shamanth, good to hear that. So my diagnosis was right. I hope you are not using PMP relay. It has a very primitive system and has a tendency of melting. Roots is a much better option.
Old 5th January 2010, 14:42   #3594
Thanks Chevy_lover. I will check with Philips 100/90 halogens. I am not interested to install a auxiliary lamps as it will look odd in my car.
Old 5th January 2010, 16:09   #3595
Thanked: 121 Times
Yes, try it and let us know the result.
Does your car have slots in the bumper for extra lights? You can get a variety of lamps to fit in the bumper. As per my experience, additional lights are a necessity in Indian rural roads.
Old 5th January 2010, 16:52   #3596
Thanked: 164 Times
@Chevy_lover
You were right in diagnosis. I am using Hella Relay kit, which is supposed to be of good quality, could be compared with Roots and Bosch.
Old 5th January 2010, 21:07   #3597
Ricky_63's Avatar
Thanked: 394 Times
I have a query regarding the "bulb upgrade" for the OE projectors on my Grand Vitara. Can I simply upgrade whatever bulb is there (I assume a 55W) to like a 90 or 100 W bulb without damaging any part of the OE light assembly ?
Has anyone done this ?
Would appreciate a feedback.
Old 5th January 2010, 22:30   #3598
Thanked: 121 Times
Hi Ricky, for any type of bulb upgrades to a higher wattage, you will need to install a relay and heavy duty wiring. If not, you risk draining your battery.
Let us know about the wattage and model of the bulb in your projector. We might be able to help you better.
Old 6th January 2010, 22:06   #3599
S.I.N.G.H's Avatar
Thanked: 40 Times
greetings to all,
i need help regarding HID for my alto. my budget is max 5k. pls help me.
S.I.N.G.H is offline   Reply With Quote
Old 7th January 2010, 14:58   #3600
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by S.I.N.G.H View Post
greetings to all,
Don't get it then. What you'll get for 5k is Chinese HID which are S***.
Increase your budget till 9-10k and get a Philips 4300k HID kit. Makes sense. For the time being, you can upgrade to 100/90w bulbs with a relay.
Automobile Insurance Queries? Ask me rjvora_2000 Indian Car Loans & Insurance 4097 23rd June 2018 12:16
The Mobile Phone Thread - Queries, decisions, discussions all here ravi_28_8 Gadgets, Computers & Software 11302 29th May 2018 12:23
The Royal Enfield Mechanics Thread: All mechanics requirements and queries here sreerajunnithan Motorbikes 427 27th April 2018 20:53
